What is a good de-soldiering iron/tool?
    • 31139
    Re: What is a good de-soldiering iron/tool?
    list the dimensions in mm
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      I think it's 12.7mm ID x 38mm L x 1.3 mm T or something like that; however I have to disassemble to measure it.
      • evilkitty
        • Nov 2017
        • 299
        Like I said earlier I would recap the temperature controller board you can reach the pins of the caps because the pins do not go very far on the other side board because of the LCD display
        that is why the caps are not flush with the board
        The easiest way to get the caps off the board is heat the pad and tilt the cap to one side then heat the other pad and gently pull out the cap from the board
        You will know if you have older version is when you turn it on it might turn off then turn right back on and might keep doing this a few times before it will stay on
        The older version was used with the transformer the new version uses the switching power supply
        The difference between the two is that older version the heater comes on right a way on the newer version there is a delay before the heater comes on
        From what it looks like either they had a lot of the older controllers or they did not realize that you can not turn the heater on right a way so they wrote a new version of the program to fix this problem so some of the unit have this problem
        We have a JAKEC 330 uf and a Fencon 100uf cap here, both are 25v
        Do these need to be low esr? i assume they should be upgraded to 35v
        should these be used?
        EKYB350ELL331MH20D 330uf KYB 35v
        EKYB350ELL101MF11D 100uf KYB 35v
        I understand the ones in the PSU should be 35v, but since the psu outputs 18v, shouldn't 25v be good as the voltage SHOULD be regulated and smoothed out at this point?
        does this look like a old or new controller? *points at photo that turned out wonderful*
        • llonen
          • Sep 2014
          • 495
          • hampshire
          #84
          I have a pair of pace SX80 solder extractors, there is the option to use a glass collection tube or or a cardboard collection tube of which I have around 50. Although with care the cardboard solder collectors can be opened and emptied.
            • Jul 2011
            • 6057
            “STJ
            18v output.
            25v caps - hell no.
            for smoothing 18v you want 35v caps.
            old rule, a smoothing cap should be atleast 1.5x running voltage to handle the spikes.
            18+9=27
            that's far too close!
            also, if it pulses the element with DC does it have a reverse protection diode? “
            I would use 35 volt on the temperature controller board
            You will not know which version of the program it is load until you power up the unit the temperature controller board look alike
            • evilkitty
              • Nov 2017
              • 299
              So the only difference on it is the software that can be flashed, given one can get a hold of the new version
              does the voltage regulator not clean out spikes, that is what a voltage regulator does right? or am i thinking too linear
                • Jul 2011
                • 6057
                Most the filtering the voltage to very close to pure DC voltage
                You have not said where you got your ZD-915 from but it might be the new version of software but you know which one you have when power it up
                • evilkitty
                  • Nov 2017
                  • 299
                  from page 2...
                  I would very much like a de-soldering gun, but there is one issue, i hate to spend money
                  I can find a ZD-915 for 119 at amazon
                  I am going to get a zd915 for Christmas, so those links would be useful
                  I know you said you replaced the caps in it's PSU would you happen to have cap part numbers or specs? I will need to make sure the PSU is the same in this unit, but if they are that would be a time saver
                  here was the link: https://www.amazon.com/dp/B07542D82F
                    master hoarder
                    • May 2008
                    • 12175
                    #89
                    “STJ
                    18v output.
                    25v caps - hell no.
                    18+9=27
                    Lol, that's not even close to being "too close".
                    That old "1.5x rule" comes from a time before switchmode power supplies existed. It has mostly to do with the fact that linear power supplies (i.e. a simple line transformer with a rectifier behind it) would output a much higher voltage when unloaded than when loaded. This is especially common with small "wall wart" -type of transformers that have poor load regulation. Hence the 1.5x voltage rating.
                    Also, during the early 2000's, it was common to see caps on many motherboards with much higher voltage that what the circuit needed. This was done because there weren't as many (and as good) types of low ESR capacitors as there are today. When you move to a higher voltage electrolytic cap, its size increases. This increase in the can size reduces the ESR and increases the ripple current handling capability. So in short, you get a cap with lower ESR without having to resort to a higher capacity cap.
                    Both of these design strategies are outdated and unnecessary when it comes to choosing caps for a switchmode power supply today. So there is absolutely NO NEED to go with the "1.5x voltage rule".
                    Thus, for a regulated power supply, the voltage rating of your caps really only needs to be about 20% higher than the circuit voltage.
                    Now, if you want to talk about cutting it close... I repaired an active amp speaker set last month which had 63V-rated caps on its LINEAR PSU filter a voltage rail that was about 59-60V. Now THAT is close. But guess what, even those caps lasted almost 20 years in that spot. And they were CapXon. After nearly 20 years, only one of the four failed. That's not too terrible, IMHO.
                    • evilkitty
                      • Nov 2017
                      • 299
                      Seems i have a U3 controller
                      I had a unexpected job for it this morning
                      Replace relay in a abnormal failure state, while the coil was in the off state the resistance was 50k ohm; conclusion spring failure or weak contact due to AC arc damage
                        • Jul 2011
                        • 6057
                        So how do you like Desoldiering Gun
                          • Jul 2011
                          • 6057
                          What is the voltage of the coil 50k ohm was the coil resistance measurement with coil on the board or off the board
                          • evilkitty
                            • Nov 2017
                            • 299
                            typical cheap ebay blue relay: SRD-05VDC-SLC
                            That was not coil resistance, that was the resistance on the output while the coil is low
                            the coil works fine, when the coil has power on it it functions as intended
                            let me use a diagram
                            50Kohm between C (Common) and NC (Normally Closed)
                            test was done in board, but i have C, NO, and NC all on pin headers, so i just unplugged my wires on it and checked the connectivity
                            It was not able to get every last spec of solder off every pin of the relay (4/5 worked good), but when i put these relays in i had to adjust the pin so they slice into the PCB hole a little, they are just not made for the 2.54mm board, but the pins can be bent a little to make them fit, but it is tight
                            if one of these relays fails like this again i am gonna cut the shell open and try some contact cleaner on the contacts
                            I checked the AC voltage, it is ~27VAC, as for the amperage, idk, but a piece of solid core Ethernet cable wire does not even get warm
                            • evilkitty
                              • Nov 2017
                              • 299
                              The two 2200uf@35 volt caps are a FR series will be the only that will right
                              right now I cannot find the bag tag for those caps that I had used 3300@35 volts I will see if I can find the ones that I used
                              I figured out why you could not find it
                              looks like you used these: https://www.mouser.com/ProductDetail/EKYB350ELL222MK35S
                              Reference:
                              https://www.badcaps.net/forum/showpo...6&postcount=20
                              Attachment #2
                                • Jul 2011
                                • 6057
                                You are right I did buy them at Mouser Electronic because DigiKey did not carry them
                                • evilkitty
                                  • Nov 2017
                                  • 299
                                  note that they are 2200 not 3300 uf
                                  i think that is why you had a hard time trying to find a 12.5mm dia 3300 uf cap
                                  BTW do you have a link so i can pick up some spare tips for the zd-915
                                  i do not think i need to get a full repair kit since i have a glass tube right? just filters right?
                                  i know you prefer the plastic design, and i do agree the it holds the filter better
                                  i kinda want to mod the spring to make it stay in the center to keep from getting puled around the filter (ideas?)
                                    • 31139
                                    spare tips should not cost more than 2$ each - just so you know.
                                      • Jul 2011
                                      • 6057
                                      Here is a link to where I get some of my spare parts
                                      http://www.mpja.com/Desolder-Station/products/496/
                                      https://www.ebay.com/sch/m.html?_odk...d-917&_sacat=0
                                      https://www.ebay.com/itm/40101350659...84.m1436.l2649
                                      • evilkitty
                                        • Nov 2017
                                        • 299
                                        Looks more like 10 everywhere i look one you add shipping, even without shipping it is 3 to 5 each, maybe you meant pounds not dollars
                                        @sam_sam_sam Thanks for the links
                                          • 31139
                                          no, i get them for £1.45 - i translated that into us$
