Google Earth & Bad Caps
  • Bob Parker
    Technician
    • Feb 2007
    • 182
    Google Earth got more and more unstable on my PC until I couldn't use it any more. I read all kinds of forums about what might be causing it, changed program versions and video card drivers, and nothng helped.
    I finally pulled out the Gigabyte Nvidia FX5200 video card and checked the electrolytic caps. The 1000uF 6.3V with the swollen top had an ESR of 13 ohms. The others measured 0.03 ohms each so I left them alone.
    I replaced it with a pair of low ESR 1500uF 10V caps I had (using the existing cap's solder pads + two spare pads in parallel with it), and suddenly Google Earth is perfectly stable again. The weird thing is that the video card was working OK with all other programs.
    My final act was to install a small fan to blow air over that board. It used to run too hot to touch and now it's just quite warm and I'm happy.
    It is a good shrubbery. I like the laurels particularly...
  • i4004
    • Oct 2006
    • 2029
    Re: Google Earth & Bad Caps
    https://www.badcaps.net/forum/showpo...54&postcount=5
    for me google picasa and earth ment hdd thrashing...
    this seems to be different issue, perhaps because google earth uses opengl and pushes the gpu over the limit...
    (then again, i doubt u use directx much either, as that's games and simillar)
    look at that fet being almost completly burnt by the bad cap!
    look at other two being completely normal, as caps near it are ok.
    yeap. caps eat fets....
    • Wizard
      • Mar 2008
      • 2296
      Oh, hi Bob Parker!
      Still using ESR meters of your design years now, own two. Saved much time and paying money at TV shop.
      Next time try to use one of loaded games (like doom III) to load down the GPU to stress.
      The "crispy" look on that "transistor" could be regulator and heated flux that got more brown as time goes.
      Cheers, Wizard
      • jpdoe
        • May 2007
        • 237
        The FurMark application is a good way of testing GPU stability.
        http://www.ozone3d.net/benchmarks/fur/
        Too bad it doesn't work with older integrated graphic chips.
        But I guess it would do just fine with an fx5200.
        • Bob Parker
          Technician
          • Feb 2007
          • 182
          Originally posted by Wizard
          Oh, hi Bob Parker!
          Cheers, Wizard
          Hi there Wizard! It's nice to know your ESR meters are still doing their job for you.
          I don't have any games installed but I tried the Furmark program and it was stable though very slow.
          Yeah that device has been running extremely hot ever since I installed the card a few years ago. It's an STD1703L and I finally found a data sheet for it. Yes, it's a DPAK MOSFET probably functioning as a linear regulator. Even with the new fan blowing air over it, it still gets too hot to hold my finger on it for more than a few seconds.
          Thanks for telling me about that. I gave it a run for 5 minutes without any problems. The GPU heatsink got warmer but not hot and the STD1703L heated up even more. I couldn't figure out how to create/read the GPU temperature log but it's not very important. Maybe the FX5200 doesn't have the ability to show its temperature.
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            what series were those nichicons?
            that hot mosfet is likely to blane for the cap failure.
            the plating on the tab has turned colors from the heat.
            • jpdoe
              • May 2007
              • 237
              You're welcome.
              I googled around, and it seems the FX5200 doesn't have a temperature sensor. At least that's what these guys say:
              http://forums.nvidia.com/lofiversion...hp?t52891.html
              http://www.nvnews.net/vbulletin/arch...p/t-15223.html
              • Bob Parker
                Technician
                • Feb 2007
                • 182
                Yeah, the cap which failed was closest to that device. Some photos of the cap should be attached to this so you can work out what series they are...
                • Bob Parker
                  Technician
                  • Feb 2007
                  • 182
                  You're welcome.
                  I appreciate your research for me.
                  The FX5200 is pretty old these days so I suppose it's not surprising that it doesn't have any fancy features. My >6 year old PC doesn't do anything any more graphics-intensive than running Google Earth so I'll hang onto it for a while longer.
                  • Krankshaft
                    • Jan 2007
                    • 2328
                    The Nichicon HM bad batch curse is still in full effect I see.
                    The instant I saw the Nichicon logo in the first pic I knew that they were HMs. A04 so they have a 2004 manufacuring date. Right at the cutoff point when the mistake was corrected. The overfilled caps were manufacured between 2002 and 2004.
                    Kind of like the Samxon GF series a good company that just goofed up.
                    Unfortunately though they left the manufacturers to deal with the mess.
                    • Bob Parker
                      Technician
                      • Feb 2007
                      • 182
                      All three electrolytics have been getting heated too hot to touch by other components for more than half of the last 3.5 years, but the one which burst its top was getting even hotter from being next to that discoloured MOSFET. I was amazed that they lasted this long and that the other two were still reading 0.03 ohms of ESR, especially if that series of Nichicons is known to have problems!
                      • Paxman_Swede
                        by Paxman_Swede
                        Hello!
                        01-14-2025, 09:51 AM
                      • captain150
                        by captain150
                        03-16-2025, 07:34 PM
                      • Foetuss
                        Gigabyte GA-6OXT :: caps question
                        by Foetuss
                        Good evening
                        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                        But I was also suprised about the bigger boys, which are 330µF 25V.
                        Could it be they used 25V caps because they were cheaper / available at that time?...
                        02-11-2025, 12:22 PM
                      • madscientist750
                        Replacing electrolytic caps by solid caps on old motherboards
                        by madscientist750
                        I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
                        I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
                        I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
                        10-19-2025, 06:10 AM
                      • black6host
                        Replacement caps for Samson Resolv studio monitor 65A Amp board.
                        by black6host
                        Good day!
                        I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                        I'm going to replace the caps and I'll be the first...
                        02-06-2024, 08:22 PM
