DMM leads with clips?
  • mikay786
    • Aug 2014
    • 765
    Anyone know what the leads with tiny clip things on the end allowing to clamp on to components legs and other fine things are called?
    It's a pain and dangerous trying to probe stuff on a live board using standard leads. I shorted a filter cap a few weeks ago with the power on which scared the crap out of me and don't want to be anywhere live parts if I don't have to.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: DMM leads with clips?
    Franky, over at eevblog, is a honest seller. He has an ebay store and sells
    http://www.ebay.ca/itm/200979921195
    http://www.ebay.ca/itm/200906287163
    I have purchased from Franky before and stuff comes from Hong Kong and usually arrives in 2 weeks. I get no kickbacks or discounts from Franky.
    Other variations
    http://stores.ebay.ca/99centHobbies/...-Accessories-/
    Other name brands include Ponoma.
    http://www.pomonaelectronics.com/ind...P&getDetails=1
    Yep, I use the above or similar when probing anything on the live side. I also use a reputable multimeter on the live side in case I make an oops.
    --- begin sig file ---
    --- end sig file ---
      • 31019
      spring hooks.
      http://uk.rs-online.com/web/c/test-m...st-connectors/
      • diif
        • Feb 2014
        • 6978
        • England
        I use probes with a fine tip and then put heatshrink over the probe so just the end is showing.
        • spleenharvester
          Making a Handskit hot air station a bit less stupid
          by spleenharvester
          I bought one of these as it was the only one I could find that is compact enough to fit in my toolbox (though I've since found KSGER make a substantially safer looking one). It's one of those fan-in-handle things that has the 230V element in the handle. Quecoo briefly sold a similar unit but discontinued it.. maybe they couldn't find solutions to these problems. I'm aware these fan-in-handle things are garbage compared to a good air pump station but I only really use this for occasional QFN work etc.
          I did not realise at the time of buying that its design is... interesting, to say...
          05-09-2024, 09:09 AM
        • ResoluteHawk
          Connecting an LVDS/eDP cable into a live motherboard
          by ResoluteHawk
          Could anyone explain the reasoning behind why connecting an LVDS or eDP cable into a laptop motherboard, with the battery still connected, kills the CPU/PCH/SuperIO/GPU?
          Today I had a customer with a Lenovo Legion 5 that I diagnosed as a dead iGPU inside their Ryzen 5900HX. They told me that they connected their screen to the motherboard without first disconnecting the battery.
          I want to understand the nitty gritty behind why it kills components if power is not disconnected first.
          08-04-2025, 04:39 PM
        • varunviolin007
          Looking for someone to recap Dell XPS T450 motherboard (Live in suburbs outside of Philly)
          by varunviolin007
          Hi guys,
          I’m looking for someone in the Northeast to do a full electrolytic capacitor recap on a working Dell Dimension XPS T450 motherboard (it's an Intel 440BX, Slot 1). The board runs mostly fine but is beginning to freeze after warm reboots (turns back on for 30 secs or so and then freezes up but is perfectly fine after 12 hr cool down).
          I’d be sending just the bare motherboard (CPU, cards, bracket, battery all removed). I’m located in Chadds Ford, PA and happy to ship within the US.
          Looking for someone experienced with older PC boards who uses...
          07-29-2025, 11:53 PM
        • LemoneyF
          Socomec ITY2-TW100B ITYS 10KvA UPS
          by LemoneyF
          Blokes Im not even sure where to start looking.
          I have a broken Socomec 10KvA online single phase UPS, specifically an ITY2-TW100B.
          Does anyone have any experience with these? 6KvA ITYS units also share a mainboard, I believe.
          There is an issue with the bypass circuit on the mainboard- out of ten intial error codes Im down to one (yay aliexpress components), but after four months im ready to give up. 140kg boat anchor.
          I need to find a complete mainboard.
          Socomec have stonewalled me and wont give me any schematics. The manual has...
          02-14-2025, 10:09 PM
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
