DMM leads with clips?
  • mikay786
    • Aug 2014
    • 765
    Anyone know what the leads with tiny clip things on the end allowing to clamp on to components legs and other fine things are called?
    It's a pain and dangerous trying to probe stuff on a live board using standard leads. I shorted a filter cap a few weeks ago with the power on which scared the crap out of me and don't want to be anywhere live parts if I don't have to.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: DMM leads with clips?
    Franky, over at eevblog, is a honest seller. He has an ebay store and sells
    http://www.ebay.ca/itm/200979921195
    http://www.ebay.ca/itm/200906287163
    I have purchased from Franky before and stuff comes from Hong Kong and usually arrives in 2 weeks. I get no kickbacks or discounts from Franky.
    Other variations
    http://stores.ebay.ca/99centHobbies/...-Accessories-/
    Other name brands include Ponoma.
    http://www.pomonaelectronics.com/ind...P&getDetails=1
    Yep, I use the above or similar when probing anything on the live side. I also use a reputable multimeter on the live side in case I make an oops.
    --- begin sig file ---
    --- end sig file ---
      • 31010
      spring hooks.
      http://uk.rs-online.com/web/c/test-m...st-connectors/
      • diif
        • Feb 2014
        • 6978
        • England
        I use probes with a fine tip and then put heatshrink over the probe so just the end is showing.
        • spleenharvester
          Making a Handskit hot air station a bit less stupid
          by spleenharvester
          I bought one of these as it was the only one I could find that is compact enough to fit in my toolbox (though I've since found KSGER make a substantially safer looking one). It's one of those fan-in-handle things that has the 230V element in the handle. Quecoo briefly sold a similar unit but discontinued it.. maybe they couldn't find solutions to these problems. I'm aware these fan-in-handle things are garbage compared to a good air pump station but I only really use this for occasional QFN work etc.
          I did not realise at the time of buying that its design is... interesting, to say...
          05-09-2024, 09:09 AM
        • LemoneyF
          Socomec ITY2-TW100B ITYS 10KvA UPS
          by LemoneyF
          Blokes Im not even sure where to start looking.
          I have a broken Socomec 10KvA online single phase UPS, specifically an ITY2-TW100B.
          Does anyone have any experience with these? 6KvA ITYS units also share a mainboard, I believe.
          There is an issue with the bypass circuit on the mainboard- out of ten intial error codes Im down to one (yay aliexpress components), but after four months im ready to give up. 140kg boat anchor.
          I need to find a complete mainboard.
          Socomec have stonewalled me and wont give me any schematics. The manual has...
          02-14-2025, 10:09 PM
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
        • NolesFan
          Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
          by NolesFan
          Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
          10-24-2024, 06:36 PM
        • Arfizato
          JBL live 650BTNC Schematics/ Datasheet/ Repair Help
          by Arfizato
          Hello everyone, I'm looking for schematics or datasheet for my JBL live 650BTNC headphones so that maybe me and my friend could stop flying blind trying to fix it. Here's a youtube video of the same headphones if you need any specific model number or better idea about the product.
          Situation(if interested to help me troubleshoot):
          my headphones were water-damaged due to heavy rain. at first, it stopped working but then after the hair dryer treatment, it came back to working with little finicky Bluetooth behavior which eventually went back to normal.
          Then when I charged it...
          10-20-2022, 04:37 PM
