revenue
  • harsh
    • Aug 2008
    revenue
    can anyone please tell the market stats of major test and measurement instrument manufacturing companies in india.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: revenue
    didnt know anything was built there other than crappy crt's and tech nonsupport boilerrooms.
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      Re: revenue
      and curry. i like curry
      this funny
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        Re: revenue
        Roflol!
        • valvashon
          32" Philips PAL TV from India- should I get it or leave it for somebody else?
          by valvashon
          I know this isn't troubleshooting related but thought it was the best place to ask. There is a supposedly working 32" Philips flat screen originally from India for free near me on FB Marketplace. It's a PAL receiver but will do NTSC (?) from the HDMI inputs. Will add the model number later. I like quirky stuff but have plenty of TV's/monitors around so I don't really know what to do with it. Should I get it and see if there is a compatible NTSC/ATSC tuner board that could be swapped in?
          Val
          09-12-2025, 11:09 AM
        • alloverme
          Texas Instrument Datasheet TPS51486RJER
          by alloverme
          i have an issue with my laptop, i troubleshoot and i think i have some issues with this chip, i would like to understand how it work and wich voltage i should have output but i cant find the datasheet
          The chip is TPS51486RJER
          The input 13v and 5v are good but i have strange output 4.5V and i should have 1.2V and 2.5 V
          My post about my issue join
          thanks
          Hello, I have an HP 15-eh0001nf with a start issue, First it didnt start at all power button blinking blue and no screen, but seems a boot loop* I tried to remove most component - > same issueI see some little corroded component, clean them with isopropyle alcool and resamble all -> it worked during less than one
          07-20-2025, 10:08 AM
        • JayPoorJay
          Glueing Two Sided Flex Ribbon,Jaguar XJS Instrument cluster.
          by JayPoorJay
          Hello All.
          I'm working on the printed flex circuit board (flexible type) of a 1990 Jaguar XJS Instrument cluster. If you Google that you'll be able to get a general idea.
          In areas, the plastic has come apart allowing the copper strip to kinda flop around and be exposed to the elements.
          What can I use to glue the 2 faces of the plastic material together trapping the copper ribbon inside...
          Again - thank you all for you help. This will be the 4th or 5th time now that I have come here to receive AMAZING advise and directions. Thanks so...
          05-03-2022, 09:56 AM
        • ivtec
          Instrument Keyboard Faulty Screen Graphics help
          by ivtec
          Hi guys; i own an Instrument keyboard Technics KN2000 that costed me a fortune back in 2000, and latley I have a Blue screen with no Graphics although still can have limited change to sound controls but but no in full do not seeing full control graphics, is there anything a can check,i notice some time i have faded graphic that soon disappear
          https://technicskeyboards.com/techni...chnics-kn2000/
          06-14-2019, 12:48 PM
        • CapLeaker
          Fender Acoustasonic 100 / 150 repair
          by CapLeaker
          Got this Fender Acoustasonic 100 in for repair.
          Complaint: Supposedly does strange things, the instrument channel goes pop, crackle, no audio then all of the sudden works again?
          Well... Open this 15 year old sucker up and I am greeted with leaking capacitors. I changed these out, cleaned the board and no audio out of the instrument channel, but some weirdness is gone and sounds now clean on the second channel. So I put my laptop on there and cranked the music full tilt. Sure enough, it goes crackle and pop with the bass in rhythm. Put my signal geni on it and sure...
          07-26-2025, 02:06 PM
