CH341a and logic level converter
  • megaraider
    • Jul 2015
    • 307
    • Portugal
    #41
    Re: CH341a and logic level converter
    Originally posted by wall
    (...) and the mentioned 1.8V SPI converter, but the software can't detect the chip, I programmed it twice anyway but the tablet still doesn't turn on, this was with the BAT+ desoldered, by the way.
    (...) what puzzles me is that everywhere I looked nobody removed the battery or desoldered the chip from the motherboard and they were all successful wih those sh*tty clips.
    Hope you're *not* insisting on using the 1.8V SPI converter you've posted images earlier!
    As suggested along the way you should use this one:
    2nd. Forget the clip and that tricky voltage level converter;
    3rd. Use the CH341A programmer and a suitable voltage level converter, e.g. this 1.8V SPI Flash adapter around €4;
    later found in this tutorial they're using the some converter, btw
    Therefore, if you're not comfortable removing the BIOS chip you should, imo:
    Forget what puzzles you... get the tools you need and follow the tutorial
    The tutorial mentioned above is quite complete and has detailed images.
    [BAT+ has to be desoldered, and the BIOS chip has to be correctly detected in CH341 programmer before anything good can be accomplished].
    • wall
      • Apr 2016
      • 37
      • Portugal
      #42
      I'm using the recommended 1.8V adapter, I didn't notice I had to put the clip on the latch's side, opposite of the ch341. It detects now, thank you.
      • wall
        • Apr 2016
        • 37
        • Portugal
        #43
        BIG THANK YOU TO ALL WHO HELPED ME!
        My tablet lives again.
        Thank you thank you thank you.
          • 31198
          you see it helps to follow the instructions
          • megaraider
            • Jul 2015
            • 307
            • Portugal
            #45
            You're welcome. Happy to know you succeed
            • heart_taker
              • Mar 2018
              • Sweden
              #46
              can you please help me i have the same issue. what adapter you are talking about. and latch side?
                • 31198
                the socket on the programmer is 16pin,
                8pins at one end for eeproms, 8pins at the other end for flashchips.
                • fredas58
                  Mentat
                  • May 2018
                  I have a very similar situation, I can open a separate thread but I thought it's too much similar.
                  Let me explain:
                  • I need to flash W25Q64FW on the motherboard of a chromebook
                  • I have already unplugged the battery
                  • I plan to use a TXB0108 to bring voltage from 3.3V to 1.8V
                  • I will also use a CH341A, black version
                  Ideally I would do this on Linux, but I am already planning to use Windows to reduce complexity (as that is anyway the most used way and I should encounter less issues).
                  Can you foresee any problem with the setup and/or the TXB0108? I really do not wish to order another part as I have a few days left to do this. I have read mixed reviews about the TXB0108 in a SPI scenario.
                    • 31198
                    this may work in Linux.
                    it supports the programmer.
                    https://www.flashrom.org/Flashrom
                    • fredas58
                      Mentat
                      • May 2018
                      Nice! thanks, will try
                      • md500
                        [Question] Ch341a and 5v to 3.3v with logic converter
                        by md500
                        zz0.8tpitu4y0i8zzI bought a ch341a (I'm waiting for it to arrive) and I noticed that the programmer has a bug that the data pins go to 5v when the VCC pin is at 3.3v (which is the voltage I'm looking for).
                        Instead of doing the 3.3v mod, I'm thinking of converting the 5v to 3.3v with an 8 channel TXS0108E through the ZIF socket but I don't know if that would work, because it has to circulate voltage and also information.
                        What I am looking for is something that will convert from 5v to 3.3v but without modifying the ch341a.
                        I can't buy the ch341a 1.6v that has...
                        05-24-2024, 06:51 PM
                      • ohren
                        by ohren
                        09-08-2023, 05:24 PM
                      • korben_dallas
                        Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
                        by korben_dallas
                        Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
                        I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
                        I'm new to soldering but the only feasible way to fix this issue is to do something myself.
                        MY QUESTION:
                        I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
                        02-14-2024, 12:23 AM
                        MPS NB670 NB670GQ Switch Mode Converter for Laptop Computers Datasheet
                        The NB670 NB670GQ is a fully integrated high frequency synchronous rectified step-down switch mode converter with 3.3V fixed output voltage. It offers very compact solution to achieve 6A continuous output current and 9A peak output current over a wide input supply range with excellent load and line regulation. The NB670 operates at high efficiency over a wide output current load range. Constant-On-Time (COT) control mode provides fast transient response and eases loop stabilization.
                        Under voltage lockout is internally set as 4.65V. An open drain power good signal indicates the output...
                        10-23-2024, 03:23 AM
                      • gizmo1990
                        What is this PSW1 part on a circuit board? Trying to fix a Canopus ADVC-300 DV/VHS Converter
                        by gizmo1990
                        I'm trying to fix this Canopus converter so that I can convert lots of old VHS cassettes. The problem is that it turns on for a split (and I mean split!) second, the fan jerks and then.. nothing. I've checked the power brick works. I've opened up the converter itself and been testing for shorts.
                        The image attached shows the on/off switch (which I've checked works) to the left of the yellow socket. Below the yellow socket is a green block marked 26 with a strange symbol at the front. Putting my probes either end of this block, on the silver parts, gives an open short...
                        10-21-2024, 08:02 AM
