Will my soldering iron be good for motherboard recapping?
  • blown_caps
    • Apr 2016
    • 6
    • CA
    I have this iron: https://www.amazon.ca/Weller-WLC100-.../dp/B000AS28UC
    What worries me is that the iron plugs into the 3 pronged plug on the station but it doesn't have a ground, just a 2 pronged plug.
    To be clear, the station plugs into the wall with a 3 pronged plug. But then the iron plugs into the station itself which has a 3 prongs plug on its side (seen on the last picture on the Amazon listing). The soldering iron that plugs there only has 2 prongs, i.e. no ground.
    Is it dangerous to attempt fixing the motherboard by replacing 4 caps on it with that iron?
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    Re: Will my soldering iron be good for motherboard recapping?
    The inexpensive Weller soldering irons are terrible products. Especially the irons with the tip that is screwed on the iron. The tip gets damaged too easily.
      • 31197
      i'm pretty sure that's just a $10 mains iron with a lamp-dimmer in the base.
      • blown_caps
        • Apr 2016
        • 6
        • CA
        So... Will I damage my board or not?
          • 31197
          hard to say, you cant "set" the temperature.
          • acedogblast
            by acedogblast
            11-02-2024, 05:13 PM
          • Geeker007
            Friend messed up my laptop motherboard while working on my bench
            by Geeker007
            Hi All,
            So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
            So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
            I have not tried putting...
            06-16-2025, 01:40 PM
          • glovecaps
            by glovecaps
            11-25-2024, 04:23 PM
          • kalemaroni
            Opinions on particular soldering iron tip maintenance product
            by kalemaroni
            Has anybody tested this product? Posting this question on a Facebook tech group I'm in got a few responses like "that kind of thing corrodes the tips" and "just using normal solder paste is much better" so I'm not looking for generic responses like that, but rather, does anybody know for certain whether this exact product is good or bad for soldering iron tips?
            04-12-2024, 03:52 AM
          • tony359
            Kaiweets USB soldering iron
            by tony359
            I am testing a USB powered soldering iron. It's made by Kaiweets but I believe it's also sold under other names.
            As a standard test, I checked whether there was any voltage leak from the tip - that said the thing runs on USB-C power delivery so am I correct that the whole unit is floating and not grounded? If I check, I measure 90V at the tip but I have a feeling that that is not relevant? Maybe caused by that capacitor between primary and secondary inside the PSU? I do not see current flowing at all.
            In other words, do you think it's expected and...
            02-06-2024, 12:51 PM
