Decent DMM for around $250?
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Long story short, i was trying to figure out why my washing machine was dead and full of water, i had put my meter in continuity mode across the (open) thermal cutout. I forgot to unplug the machine... DMM dead.
    Any suggestions?
    Follow the white rabbit.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Decent DMM for around $250?
    Originally posted by goontron
    DMM dead.
    1) If you want to try and fix your existing dmm, I can make suggestions if you post clear focused pictures of the pcb (both sides). Show a picture of the make and model as well.
    2) If you don't want to fix it, then I can make some suggestions (well under $250).
    --- begin sig file ---
    --- end sig file ---
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      Its an old otc multimeter plus 3391. Plastic is brittle and cracked. I don't want to sink time into it.
        • 31017
        what do you want it to do, how many digits?
        handheld, or desk?
        if i was shopping for a new meter, it would start with a UNI-T UT61E
        then end with a Rigol (and a lottery win)
        there's lots in between.
        one thing, i would buy new probes - i'v never been impressed with the ones you get with handheld meters.
        • goontron
          5000!
          • Dec 2011
          • 4108
          • US
          handheld, or desk?
          I would need current measure, voltage, resistance, continuity, the basics. Frequency counter or capacitance would be nice, but i don't need, need them. Handheld.
          and anywhere from 4.5 to 5.5 digits is fine.
          • retiredcaps
            • Apr 2010
            • 9271
            I wrote this in January 2015 ...
            https://www.badcaps.net/forum/showpo...7&postcount=17
            Some will claim that the free or $3 meters will just be as accurate/good and they are welcome to use it on 120V AC or 240V AC as they see fit (knowingly or unknowingly).
            • clearchris
              • Dec 2013
              • 687
              do you have any suggestions? One of my probe tips was... melted.
              • goontron
                5000!
                • Dec 2011
                • 4108
                • US
                I will have to look into the BK.... Anything you know of in the $200 range?
                  • 31017
                  depends on your budget.
                  i would say 10-20 is reasonable for decent cables, probes etc.
                  something like these:
                  http://www.rapidonline.com/Test-Meas...obe-Set-525174
                  http://www.rapidonline.com/Test-Meas...ads-Set-532677
                  http://www.rapidonline.com/Test-Meas...ads-Set-532664
                    • 31017
                    http://www.uni-trend.com/en/product/2014_0729_802.html
                    http://www.dx.com/p/ut61e-2-6-lcd-di...battery-113306
                    only about $50 leaving change to buy decent cables!
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      There is a huge difference between a $3 multimeter and a $50 multimeter in terms of build quality, reliability, accuracy, precison and safety.
                      There is a noticeable difference between a $50 and a $100 multimeter, but not as much as the above.
                      There is a noticeable difference between a $100 and a $200 multimeter, but not as much as the above.
                      In another words, spending more reaches a point of diminishing returns. Everyone's different requirements will determine when this point is reached.
                      Some people would rather have two $100 multimeters versus one $200 multimeter. There will be times you need to measure current and voltage at the same time or you need to measure two voltages at the same time. For example, I often will use a multimeter attached to the large filter capacitor, possibly 400V DC, in a SMPS using hands free probes/attachments and another multimeter probing voltages somewhere else. When I power off, I can safely look at the multimeter measuring the large filter capacitor to ensure it is fully discharged.
                      $200 range.
                      1) new Brymen BM257S aka Greenlee DM-510A => roughly $150 USD
                      2) new Brymen 860 series aka Greenlee DM-820A
                      3) Amprobe AM-140-A - another Brymen rebadged meter
                      Agilent/Keysight also have meters in the $200 range, but I have no hands on experience with them. I would love to get one, but finding them in my strict price valuation parameters requires a lot of patience.
                      • Per Hansson
                        • Jul 2005
                        • 5895
                        • Sweden
                        Yes the UNI-T UT61E is nice, I bought it at a sale from Elfa.
                        Wrote a small blurb about it at the last paragraph in this post.
                        Kind of interesting result compared to a 10 times more expensive Fluke meter...
                        I do agree with stj's recommendation about probes, the included ones are quite cheap...
                        Actually the ones I got where intermittent, so I sent a mail to Elfa and they next day shipped me some Fluke probes no questions asked!
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          The specs for ACV on the Uni-T 61E is 45Hz to 10kHz. The Fluke 28 II specs for ACV is 40Hz to 30kHz.
                          • goontron
                            5000!
                            • Dec 2011
                            • 4108
                            • US
                            Well, ive settled on the UNI-T UT61E and a set of FLuke leads....
                              • 31017
                              http://www.ultradmm.com/
                              bookmark that.
                              • fzabkar
                                • Mar 2009
                                • 772
                                I have a Fluke PM97 scopemeter which I bought new for AU$2750. It's been a POS since day 1.
                                Nowadays I stick with cheap DMMs and test their accuracy with a cheap precision reference (5.000V +/- 5mV).
                                  • 31017
                                  i have one of those, it was good till a fet shorted and the charge circuit blew about a dozen parts off the power-board!
                                  • fzabkar
                                    • Mar 2009
                                    • 772
                                    I ordered a service manual for it. It came with one page missing -- the PSU circuit. When I received a photocopy of it, notes had been pencilled on it.
                                    The batteries never held a charge.
                                    The probes went O/C within a short time (no physical damage).
                                    The AC adapter didn't adapt for very long and Fluke wanted $120 for a replacement when all I needed was the DC cable (which was easily replaceable).
                                    One of the PCBs failed due to leaky smd crapacitors.
                                      • 31017
                                      that's a long list!
                                      was it the meter probes that oc'd or the scope probes?
                                      • fzabkar
                                        • Mar 2009
                                        • 772
                                        One of the scope probes went O/C. Not cheap to replace.
                                          ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
                                          This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 03:28 PM
                                        • mon2
                                          Suggestions for machine for Apple Configurator 2
                                          by mon2
                                          Hi. I think we have a candidate for our first DFU macbook with a 'critical update error' message (A1706).
                                          With regret, we do not seem to have a machine to mate to a suitable host to run the Configurator 2 tool.
                                          Any suggestions on such a box ? The latest models are quite expensive on Ebay and such.
                                          We do have a macbook with the older style Thunderbolt connector - can we purchase a Thunderbolt to USB C cable and run the same tool ?
                                          The system details does show a THUNDERBOLT controller on this other macbook.
                                          Does the host need to have...
                                          05-06-2022, 10:59 AM
                                        • Soulzink
                                          Samsug washing machine. Power supply DC41-00189a board issue
                                          by Soulzink
                                          I am trying to fix a samsung washinmachine power supply main board.
                                          I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                          Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                          The power supply board reference is the following: DC41-00189a
                                          I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                          04-19-2025, 06:26 AM
                                        • unimatrix93
                                          How to stabilize AC voltage to CNC machine
                                          by unimatrix93
                                          Hello there everybody, I'm not sure if it's the right topic to ask this but I hope so.
                                          I have a CNC machine wired to 3-phase 230V AC.
                                          It's a smaller CNC machine with a 3500W motor, do it does not uses much power.
                                          The problem is, when the residents come home and put load on the network, the voltage can drop to around 207V which is fine for most household items but by CNC machine stops working from this.
                                          I contacted the electricity company but they refuse to help me solve this problem.
                                          So I started to look around for some DIY...
                                          03-17-2025, 05:52 AM
                                        • xdever
                                          820-01700 not booting, 4V PP2V5_NAND_SSD0 but 2.5V when the machine is off.
                                          by xdever
                                          I got a 820-01700 of a friend that doesn't turn on. I read that a typical issue with these boards is the TPS62180 generating the NAND voltages, so this is where I started looking. Sure enough, PP2V5_NAND_SSD0 is 4V when the machine tries to turn on (I try to determine this by measuring PP2V5_NAND_SSD1, which is 2.5V as it should in this case. The PP0V9_SSD0 and PP1V8_SSD0 power supplies for the SSD are on at the same time when PP2V5_NAND_SSD0 is 4V). The extremely weird thing is that when the machine is off (PP2V5_NAND_SSD1=0, PP0V9_SSD0=0 and PP1V8_SSD0=0), PP2V5_NAND_SSD0...
                                          01-15-2025, 08:44 PM
