2in1 rework station
  • jose6326
    • May 2013
    • 707
    2in1 rework station
    i want to buy this since i noticed that having a hot air and a temp controlled soldering iron is necessary to repair electronics
    right now i use a 60watt solder iron non temp controlled
    just wondering if anyone has any thoughts on this one
    http://www.ebay.com/itm/181139781537...%3AMEBIDX%3AIT
    thanks
    • 31196
    Re: 2in1 rework station
    i know someone with that, it works well.
    have to add though, i would be looking for a unit with a fan in the handpiece rather than a pump in the base these days.
    final say - it's still a damned good price if the shipping is low/free, a few years ago those cost something like $150
    just decided to add, that iron is good for small work - dont expect to recap motherboards with it easily.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Been thinking about getting something to rework SMT lately as well, alas dont really want to pay for it, it's for hobby use only (but don't want one that will die in 2 hours.)
      I already have an old temp controlled iron, but it doesn't have a temp readout (but it does have a desolder pump). Think I will find more use in the 2-in-ones due to the temperature readout?
        • 31196
        personally i dont like combination units.
        better to have seperates.
        you can get cheap hot-air for about 40
        • clearchris
          • Dec 2013
          • 687
          36$ shipped for the hot air units with the ffan in the handle. I have been very happy with my hot air so far. 20$ will get you a soldering iron kit with readout if you have a laptop power supply.
            • 31196
            got a link at that price?
            i'm talking about the ones with a base - like this:
            https://www.youtube.com/watch?v=YkGdvCPwFfY
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              My temp controlled solder iron has no readout of current temperature and has an analog control to select temperature.
              I did see a couple $40 or even less hot air in handle guns on ebay, alas I wonder if I should get the solder iron with it and pay a bit more. Another $20 for a separate solder station if I supply a laptop PSU? I don't have any spare laptop PSUs so that would be additional cost...
                • 31196
                any 24v transformer is good.
                use the one from your 60w iron.
                he's talking about the ones that use cloned hakko T12 tips.
                best irons under $150 the T12 based ones!
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  my 60W iron? Don't have one... My 45W iron is direct drive 120VAC and my solder guns are 1V or 3V... Not sure what my temp controlled unit is, but kind of silly to break one to make one...
                    • 31196
                    i'm sure it cant be hard to find an 18-24v supply that can put out 70w
                    • jose6326
                      • May 2013
                      • 707
                      so this one would be better since it has a fan
                      http://www.ebay.com/itm/2in1-Rework-...-/191383368351
                        This one form the same seller with blower in the handle:
                        http://www.ebay.com/itm/Pro-2In1-862...3D181139781537
                        • jose6326
                          • May 2013
                          • 707
                          thanks budm
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8701
                            I use a "paint stripper" heat gun to blast parts off a SMD board, wonder if I should hack up a temperature controller for it, that would be an interesting project instead of buying a SMD station...
                            • clearchris
                              • Dec 2013
                              • 687
                              Might not be 36$ to europe, but searching for "air solder station" brings them up for me in the US.
                              To the OP: if you dont have a PS available, get the combo unit. Budgets are budgets... Hold on to your old iron just in case.
                                • 31196
                                yea, found them in EU now for 29!!
                                damn i cant believe how much these things are coming down in price!
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8701
                                  I wonder if the durability/longetivity has also gone down along with the price... ?
                                  • jose6326
                                    • May 2013
                                    • 707
                                    im not getting rid of my old iron i actually have 2 lol
                                      • 31196
                                      well,
                                      a fan in the handle is better than a pump in the base, and cheaper to make.
                                      that said, the VERY cheap ones could do with better soldering and possibly better firmware in them.
                                      see here.
                                      http://www.eevblog.com/forum/reviews...stom-firmware/
                                      i have the older pump-in-base type.
                                      they have a few problems.
                                      1: if you kink the hose, the handle can overheat.
                                      this can happen without realising it because the hose has wires in it so their is already not much room for the air to flow.
                                      2: if the above happens, you can trash the handpiece or element.
                                      3: they are anoying.
                                      i dont want to use the word "loud", it's more of a penetrating hum that gets on your nerves in a quite place.
                                      • Stefan Payne
                                        • 1267
                                        Why do all thos irons of those cheapish soldering stations look so much like on my Xytronics LF-8800???
                                        • shahnld
                                          wds-580 rework station issue
                                          by shahnld
                                          Good day.
                                          i received used bga rework station wds-580 which was not going above 300c despite the parameter was set to 350c, Everytime beeps at 300c so i did a factory reset and by mistake washed data and log etc. now the station boots to a white screen.
                                          Does anyone has a firmware for this station and want to share with me. i will really appreciate any help possible..
                                          kind regards...
                                          03-28-2024, 01:14 PM
                                        • minimania
                                          Need Schematic for jbc am6800 rework station
                                          by minimania
                                          hi all im looking for a Schematic for jbc am6800 rework station
                                          mine has stopped working fully
                                          it started with turning off when switched on then after a few off and ons it worked sort of for awhile
                                          now it wont turn on at all...
                                          01-28-2025, 03:44 PM
                                          DELL Latitude 9520 2in1 Hybrid (2-in-1) 9000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude 9520 2in1 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9520 2in1 boardview and 9520 2in1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-07-2024, 12:40 AM
