Group Buy: CH341A Programmer
    • 31294
    Re: Group Buy: CH341A Programmer
    this programmer is for flashing 24 series and 25 series chips only.
    • azizaqa
      • Aug 2016
      • Azerbaijan
      #62
      Originally posted by inkman
      Can i use this programmer to flash kb9012?
      Do i need any more accessory beside this programmer.
      Hi with postal 3
      • frasking
        • Jan 2021
        • syria
        #63
        Hi please help me
        i can read from ch341
        EN25Q32B
        But i can't write new data on it
        Please if any one can help me .
        • Riaz Solangi
          • Nov 2024
          • pakistan
          #64
          latest update plzzz
            • 31294
            all is here
            https://github.com/YTEC-info/CH341A-...main/Programas
            ASprogrammer and NEOprogrammer are probably the better ones for windows
            • what_1282105
              Thinkpad t480s, completely dead after BIOS flash using CH341A programmer
              by what_1282105
              Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
              02-14-2025, 07:27 PM
            • hotcrossedbuns999
              M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
              by hotcrossedbuns999
              My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
              1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
              2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
              3. I could only locate two chips that look like bios chips. Could someone verify this
              01-03-2025, 12:32 PM
            • irfan karatela
              Programming XMC 25QH256C with a CH341a programmer
              by irfan karatela
              I'm able to read and write the chip by selecting a winbond IC of the same size, but when verifying it fails at around 25 percent.
              I've modded the ch341a to 3.3v.
              Can I update the database to include the XMC 25QH256C?
              02-17-2025, 01:54 PM
            • BrentH561
              Elitedesk 800 G6 SFF Bios Password Lock XM25QH128A (3.3v) - Am I doing this right?
              by BrentH561
              Hello everyone, I am looking for help to make sure I am on the right track to remove lost BIOS Admin password on an HP EliteDesk G6 800 SFF. I recently purchased this on ebay and the seller is willing to accept a return but I have already installed my new HDs, NVME, and setup proxmox so I would like to keep it.
              Here is the hardware identification specs:
              HP EliteDesk 800 G6 SFF
              Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
              Serial No: MXL1223499
              Product No: 26S74UT#ABA
              BIOS/IC chip seems to be the 4 pin XMC XM25QH128A (3.3v). However most
              08-23-2024, 08:36 AM
            • notallbad
              LG 55LM6200-TA country group/Area option
              by notallbad
              This is a 2012 LG TV so aware full functionality of the smart functions/apps will be limited however currently unable to get the LG Smart Store.
              Youtube, Netflix and LG Smart store icons briefly appear in the apps list but then automatically disappear after doing 'Initialisation of Premium' via the standard menu, I'm guessing this is due to the Country/Area group its set to is wrong for the UK.
              Unable to change the country group, Area option can be changed which alters the country group but none make any difference. So believe its the country group that needs changing....
              10-20-2024, 11:16 AM
