Group Buy: CH341A Programmer
  • fzabkar
    • Mar 2009
    • 772
    Re: Group Buy: CH341A Programmer
    I'm thinking of cases where the patient PCB is dead and its "ROM" contents need to be transferred to a donor PCB. This frequently happens in HDD data recovery. In such cases the programmer would need to power up the PCB.
    As for contention issues, that happens too. In such cases the data recovery professionals swap the actual ROM, but I've always wondered whether there is a simple in-circuit solution. Most of these people are programmers or IT "techs", so their knowledge of electronics is essentially zero. Basically they are just head swap mechanics and ROM jockeys, so getting them to try anything is often fruitless.
    • fzabkar
      • Mar 2009
      • 772
      Before modifying any read-write \ \ wipe operation, must automatically detect the chip, no detected chip termination
      IIUC, manually specifying the IC part number has been disabled in the latest software release. AISI, this essentially cripples the software.
      I examined the datasheet for one of the newly added devices (MX25L12839F):
      AFAICT this device can be programmed in Mode 0 just like "standard" SPI flash.
      Edit:
      Perhaps I have misunderstood the translation. Does the programmer terminate if the chip's ID cannot be detected, or does it terminate if the ID can be detected but not recognised as one of the supported devices?
        • 31199
        you can deal with contention a lot by shutting down the original bus-master by shorting or removing the clock / crystal
        • fzabkar
          • Mar 2009
          • 772
          This "Kindle mod" demonstrates how to convert a 0V-1.8V LVTTL signal into one that ranges from 0.6V to 2.4V:
          http://img11.hostingpics.net/pics/228167mod18V.jpg
          http://img15.hostingpics.net/pics/217313dku518.jpg
          It uses a 1N4148 diode and 22K resistor.
          Note: The above example modifies a serial LVTTL Tx/Rx interface but the same principle should apply to any 1.8V signal.
          • megaraider
            • Jul 2015
            • 307
            • Portugal
            Become a member a few days ago...
            With ISP (In Circuit Programming) we have to well aware of most likely circuit contentions / conflicts issues.
            As already mentioned, by @japlytic and @stj, these can be easily circumvented according to the circuit:
            a) if not tied up, keep the system in reset / hold state
            b) if tied up, shut down the bus by shorting or removing the oscillator / crystal
            If tied up and strong pull up/down found, then remove the 0 ohm resistor connected between the power bus and the IC power pin (common implementation in circuit boards with programmable ICs).
            AFAICT that ugly patch with a LDO will not work under 1.8V logic level!
            He’s just gambling with the lowest power supply level for the CH341 and added a capacitor, hopping it to work. It might… but be well prepared for very inconsistent results.
            Even the “super simple” level shifter will be more reliable and… simpler!
            I’ve used it a lot back in the early 3.3V logic emergence days.
            The same principle applies for 1.8V with the needed adjustments. Do not forget the Rx line.
            In any case, I strongly suggest you power up the hard drive pcb from any other auxiliary power source, not from the USB port.
            • cjrs
              • Apr 2016
              • Spain
              #26
              Originally posted by mockingbird
              Is anyone interested in participating in a group buy for this?
              https://item.taobao.com/item.htm?&id=39537489315
              Sure, there are myriads of CH341A devices on the market, but the software originates from a single seller (though I assume he is using the PonyProg source as his base).
              I spoke with the seller, and there are two versions of his software. One version goes up to 1.29, which requires a paid license.
              The next iteration of his software (current version 1.32 I think) uses a security dongle (The purple USB device shown in the last picture).
              In order to purchase these, we would need to use a TaoBao escrow service because there's no other way to pay the seller.
              The group buy is to offset the cost of the escrow.
              Please post here if you're interested.
              Yes, you are full right, I have send an email to skygz@qq.com and he said me that the last version for unlocked usb dongle CH341A is the version 1.31 and the latest version for locked usb dongle CH341A is the version 1.33 and I have seen in the website: yadi.sk cracked versions of CH341A, these cracked CH341A versions are: v1.29/v1.30. As the v1.31 was released 1-6-2016 I believe that we will find a cracked v1.31 in the next future
              • cherifmc
                • Jul 2016
                • algeria
                #27
                1.31 cracked version please
                • mockingbird
                  • Dec 2008
                  • 5484
                  #28
                  Why not just pay the author the $5 and have access to the latest versions...
                  • cherifmc
                    • Jul 2016
                    • algeria
                    #29
                    give me attachement adress to have 1.31
                      • 31199
                      just upload it here.
                      click [go advanced]
                      • hienton2
                        • Sep 2009
                        • 183
                        #31
                        click [go advanced]
                        I can not find it STJ . Please help
                        • Behemot
                          • 4845
                          • CZ
                          #32
                          Scroll down, under the Repply to thread form. See Additional Options, than click Manage Attachments, the rest is pretty straightforward.
                          • ZokaSoft
                            • Jun 2013
                            • Croatia
                            #33
                            Ch341a v1.30
                            • hienton2
                              • Sep 2009
                              • 183
                              #34
                              Thanks Zokasoft
                              • knappster
                                • Jan 2016
                                • 21
                                I just tried to e-mail skygz@qq.net and it bounced back. Is there some other way to contact the developer of this software?
                                • mockingbird
                                  • Dec 2008
                                  • 5484
                                  #36
                                  Send me a PM please.
                                  • jackbd81
                                    • italy
                                    #37
                                    hi you can send me a pm with version 1.31.
                                    i'cant find on the forum
                                    • hit1
                                      • Nov 2015
                                      • rostov-na-dony
                                      #38
                                      скиньте и мне пожалуйста (CH341A version 1.31)
                                      • hit1
                                        • Nov 2015
                                        • rostov-na-dony
                                        #39
                                        вот немного другой софт Colibri.rar http://**************/forum/90-46716-4
                                        • shh200438
                                          • Mar 2017
                                          • china
                                          #40
                                          I had upload CH341A v1.31 trail version, who would crack it?
                                          http://www.mediafire.com/file/bq8zb1...341A_v1.31.zip
                                          • what_1282105
                                            Thinkpad t480s, completely dead after BIOS flash using CH341A programmer
                                            by what_1282105
                                            Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
                                            02-14-2025, 07:27 PM
                                          • hotcrossedbuns999
                                            M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                                            by hotcrossedbuns999
                                            My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                                            1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                                            2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                                            3. I could only locate two chips that look like bios chips. Could someone verify this
                                            01-03-2025, 12:32 PM
                                          • irfan karatela
                                            Programming XMC 25QH256C with a CH341a programmer
                                            by irfan karatela
                                            I'm able to read and write the chip by selecting a winbond IC of the same size, but when verifying it fails at around 25 percent.
                                            I've modded the ch341a to 3.3v.
                                            Can I update the database to include the XMC 25QH256C?
                                            02-17-2025, 01:54 PM
                                          • BrentH561
                                            Elitedesk 800 G6 SFF Bios Password Lock XM25QH128A (3.3v) - Am I doing this right?
                                            by BrentH561
                                            Hello everyone, I am looking for help to make sure I am on the right track to remove lost BIOS Admin password on an HP EliteDesk G6 800 SFF. I recently purchased this on ebay and the seller is willing to accept a return but I have already installed my new HDs, NVME, and setup proxmox so I would like to keep it.
                                            Here is the hardware identification specs:
                                            HP EliteDesk 800 G6 SFF
                                            Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
                                            Serial No: MXL1223499
                                            Product No: 26S74UT#ABA
                                            BIOS/IC chip seems to be the 4 pin XMC XM25QH128A (3.3v). However most
                                            08-23-2024, 08:36 AM
                                          • notallbad
                                            LG 55LM6200-TA country group/Area option
                                            by notallbad
                                            This is a 2012 LG TV so aware full functionality of the smart functions/apps will be limited however currently unable to get the LG Smart Store.
                                            Youtube, Netflix and LG Smart store icons briefly appear in the apps list but then automatically disappear after doing 'Initialisation of Premium' via the standard menu, I'm guessing this is due to the Country/Area group its set to is wrong for the UK.
                                            Unable to change the country group, Area option can be changed which alters the country group but none make any difference. So believe its the country group that needs changing....
                                            10-20-2024, 11:16 AM
