What traditional cable testers can't do
  • japlytic
    • Oct 2005
    • 2086
    There are a number of low cost cable testers (including those which test HDMI cables), but there is a limitation with these units.
    Such units can only check DC continuity on each conductor in the cable but cannot do any real world testing, especially at high frequencies; a HDMI cable may pass the continuity test but would not work between a TV and a normal HDMI source.
    So therefore, such cable testers only do static tests and not dynamic tests.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: What traditional cable testers can't do
    I think the vast majority of cable problems that change over time is becoming open circuit or shorted. Though AC characteristics can change over time, this is rare... though qualitatively testing cables requires specialized, and likely expensive equipment unless you know how to generate and read the results...
    • Longbow
      • Jun 2011
      • 623
      That's exactly right. Cable testers are not R&D lab equipment. Even if you had an exotic cable analyzer you would need lots of manufacturer data and previous test data to make use of the information. A tester with an assortment of common plugs/jacks is essential when you are maintaining a complex system you must have a tool that identifies open or intermittent connections, or gives you connection information such as on a crossover cable.
      Is it plugged in?
      • Patch2
        Cable Repair
        by Patch2
        I have a broken connector (believe it's a 6 pin mini-DIN) on a cable. The metal shroud and all but one of the pins are separated from the cable, and just stuck together for the photo. The other end is an unknown rectangular connector. The cable is for the foot pedals on an Italian made electronic piano, and the company is out of business. Looking for ideas on how to fix it. I have a soldering iron, but I'm not very skilled at soldering, so getting a retrofit for the broken end may be beyond my ability. The other end would be easier to replace, if I could get a mini-DIN cable with the same number...
        01-02-2025, 06:04 PM
      • Tr0ll
        by Tr0ll
        Original T-con:
        First replacement T-con:
        10-07-2023, 07:48 PM
      • fweonea
        HP-Pavilion x360 Laptop Dead After USB-C Cable Connection
        by fweonea
        While at university, I connected my HP-Pavilion x360 14-dw0156ng laptop, running Windows 10, to a monitor using a provided USB-C cable. Immediately after this, my laptop's screen turned black and the device stopped working entirely. There are no signs of life such as fan noise or LED indicators, holding the power button does nothing. I've previously used this same monitor model and cable without issues, the cable typically charges the laptop as well.
        I've attempted holding the power button for over 30 seconds, removing and reinserting the battery, and trying to power it on with only the...
        01-16-2024, 11:35 AM
      • marce002
        Help me make charger USB C cable with no cc pins!!
        by marce002
        Hi all, please
        I just want to make a "usb c" charging cable from 5V power supply (have cut cable w/ red black green and white pins connected from factory.... i just want to use 500mah max !
        How do I connect this ? if I do not have CC1 /2 physically wired, how to proceed?
        NOTE: an identical new (not cut) USB A to USB C cable charges my phone but not the remote control!
        here is a picture of the remote, the cable to be used and a picture of what are the factory connected pins
        thanks in advance!!
        11-17-2023, 09:16 AM
      • paparazzo79
        Hannspree HT 273 HPB USB cable type A to type B?
        by paparazzo79
        Hi guys.
        I purchased the monitor from the link below:
        https://www.hannspree.eu/product/ht-273-hpb/
        Since I will be using monitor from bed, I'd need longer usB type A to type B plug cable.
        I got one which is 4.5m long, regular one
        May I use it without harm to the monitor?
        I suppose cable which came with monitor is regular type A to type B,not some speical cable.
        I could picture what is labeled on the cable, if it matters for assistance.
        08-12-2023, 05:28 AM
