Philips PM5508 Pattern Pictures
  • japlytic
    • Oct 2005
    • 2086
    I am not sure what the "DELAY", "PHASE" and "MATRIX" patterns look like on a Philips PM5508 TV pattern generator.
    However, the service manual specifies them as:
    "DELAY"
    4 vertical bars:
    146º (G-Y) = 0
    180º (R-Y) = 0
    90º (B-Y) = 0
    Grey 40%
    NTSC encoded, however with PAL A-B burst.
    "PHASE"
    Same bars as "DELAY" with PAL A-B burst.
    However, upper half: PAL encoded with half the saturation and lower half: only chroma during the "positive" PAL lines where burst phase = 135º
    "MATRIX"
    Same as "DELAY" with PAL A-B burst, however, completely PAL encoded.
    Where can I find pictures of those patterns?
  • alro7779
    Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
    by alro7779
    Hello, guys!
    The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
    09-14-2025, 12:25 AM
  • G33RT
    Philips 8200 series 65PUS8204/12 stuck at Philips Logo
    by G33RT
    Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
    It does power up when pressing the power button.
    I already try the power button while plugin the plug with no result.
    Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
    Could this be an PSU or eMMC issue ?
    07-19-2025, 03:43 AM
  • double_DD
    Philips curling iron - is this a common AC cable?
    by double_DD
    Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
    As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
    Not sure if this is something Philips proprietary, or a standard, but the cable plug...
    08-18-2025, 10:04 AM
  • janos6662000
    Philips 47PFS7509/12 LCD TV problem
    by janos6662000
    Hi
    I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
    When i applied cable signal to check image, i had normal picture, but TV was restarting.
    I downloaded original firmware and applied the update, but the problem remained.
    From a colleague i received a "factory package software" which is a lot bigger.
    I made another firmware update, but still did not solve the problem.
    Somewhere on the way the error got worse, because at the moment the...
    08-12-2025, 12:54 PM
  • ktmmotocross
    Asus X512FF disable onboard memory pattern
    by ktmmotocross
    I have different BSODs when load. i want to disable onboard memory. have BV but dont have schema to check tab for stappings DIMM_SEL 0/1/2
    Others have pattern 101 original and 010 for ram disable, but i have pattern 010 original.
    any hint what pattern to use? may i try 101
    Asus X512F
    sn - k7n0cv07x551299
    03-10-2024, 08:25 AM
