Capacitor testing
  • JorgeHernan
    • Apr 2006
    • 42
    Capacitor testing
    can i test a motherboard low ESR capacitor using a digital multimeter so i can tell if it's good or bad?if so, how?
    Thanks in advance
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Capacitor testing
    No,,, and yes,,,, mostly no.
    ESR is a frequency related thing.
    The device is called and ESR meter.
    It's basically the same as a DMM but the voltage sent to check resistance is AC at around 100kHz.
    DMM can be used to find shorted caps which an ESR meter won't tell you for sure.
    Mann-Made Global Warming.
    - Dr Seuss
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      This is the one most people use.
      http://www.flippers.com/esrktord-form.html
      Been around a while.
      Bob Parker, the guy that designed it upmteen years ago, is a member here.
      I just built one from the kit version. Nice little meter.
      This is a new one based on the same design.
      http://www.anatekcorp.com/blueesr.htm
      I heard about it like TWO DAYS after I bought mine of I may have gotten it instead.
      They are both the same electronically.
      The one I have uses 6 AAA batts and is room for some mods.
      (There are mods/upgrades out for them. I did a couple of them.)
      The new one uses a 9V but I doubt there is room for some of the mods.
      - Dr Seuss
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        https://www.badcaps.net/forum/showth...&highlight=ESR
        https://www.badcaps.net/forum/showth...ight=ESR+Meter
        - Dr Seuss
        • MORETTIGIAN
          by MORETTIGIAN
          Title:
          Description:
          Procedure performed:
          - Removed backplate
          - Reapplied thermal compound
          - Reassembled card
          09-18-2025, 12:14 PM
        • chth96
          by chth96
          03-09-2024, 10:03 PM
        • genuineguy
          Microwave Oven Capacitor Testing
          by genuineguy
          Hello Experts
          Need help with my experiment to test a Capacitor from microwave oven
          Its a High voltage capacitor. 1mfd, 2100V AC.
          A DMM test across its terminals show infinite/open resistance.
          The capacitor has a 10Mohms shunt resistor internally.
          1. Connected 100w bulb in series to the capacitor. AC supply 230v connected. The bulb did not light up. This proves the capacitor is NOT shorted
          2. Connected capacitor in series with a diode and 10ohm, 10W resistor. Connected AC supply 230v. I was hoping DC voltage reading...
          09-21-2020, 12:56 PM
        • Prolog
          by Prolog
          12-01-2024, 08:27 PM
          Has anyone used this before Signstek MESR-100 V2 Auto Ranging in Circuit ESR LCR Meter Capacitor
          I wanting to know if anyone has used this capacitor tester and what they think about it and weather or not it is worth the money or not...
          02-27-2024, 06:57 AM
