How good is the UNI-T UT612 LCR meter?
  • primetime
    • Oct 2014
    • 12
    I'm looking to get an LCR meter so I can test ESR of capacitors. The UNI-T UT612 looks decent and the cheapest unit I have found that can test at 100 KHz. Given that most capacitor data sheets state the ESR at 100 KHz I thought I'd get a meter that can do 100 KHz. Any of you have an opinion on this unit? Ebay has it for around $150.
  • mariushm
    • May 2011
    • 3799
    Re: How good is the UNI-T UT612 LCR meter?
    You can find some reviews and comparisons to other multimeters on eevblog forum.
    I'm too lazy to find the threads but here's a good starting point: https://www.google.com/search?q=ut61...GdLYfJOevVgdgM
    The first results should have some information.
    My opinion, it's a good lcr meter. I would say worth the money, but you can get some other lcd meters with about same specs a bit cheaper (closer to $100).
    • chth96
      by chth96
      03-09-2024, 10:03 PM
    • carrzkiss
      Cyberpower cps1500avr not charging batteries
      by carrzkiss
      Hello, all.
      Cyberpower Battery Backup Unit.
      I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
      When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
      In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
      Checking the voltage, it was down to 22v.
      I quickly removed everything...
      06-15-2024, 02:10 PM
    • bauto601
      KDM 480W PSU upgrade succes! (opinions?)
      by bauto601
      Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
      A "nice" YoungYear unit? - Badcaps
      The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
      12-26-2023, 03:05 PM
    • CDNBrewer
      Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
      by CDNBrewer
      Hello Everyone,
      I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
      Symptoms:
      • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
      • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
      • I swapped the Left and Right surround
      08-05-2025, 09:29 PM
    • quickname
      Cyberpower 1500AVR UPS repair
      by quickname
      I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
      I decided to verify that the batteries were...
      11-12-2023, 09:57 AM
