Measuring ripple on Fluke 123 Scopemeter
  • Cohibaman
    • Jan 2015
    • 66
    Either I'm doing it wrong, or a Fluke 123 Scope meter can't show descent resolution of AC ripple on a DC line.
    I set it to VAC & 5V/d. As expected, I see a nice 12VDC line with very little ripple resolution. I then increase resolution to 2V/d and the trace moves up and off screen, so I move the trace back into view. Still not a lot of AC ripple resolution at 2V/d so I try 1V/d. Now it moves off screen and I can't move the trace back into view.
    So...how do you set the Fluke 123 to measure AC on the DC line with any amount of resolution?
    • 31199
    Re: Measuring ripple on Fluke 123 Scopemeter
    what happens if you set it to DC ?
    i had a PM97 years ago and i know you can see ripple, but cant remember how.
    • Cohibaman
      • Jan 2015
      • 66
      Same thing.
      • SteveNielsen
        Retired Tech
        • 2327
        I thought the AC setting should decouple DC from the scope input. As I recall in the olden days we used a cap on the end of the proble to remove DC offset.
        • Cohibaman
          • Jan 2015
          • 66
          I've done that as a workaround, but thought (and was hoping) the meter should without a cap.
          • Cohibaman
            • Jan 2015
            • 66
            Thanks btw
            • SteveNielsen
              Retired Tech
              • 2327
              I would think it should.
              "AC/DC select. When this is set to "AC" the DC part of the signal is filtered out by a capacitor placed in series between the signal input and the scope. When the selector is set to "ground", the beam will move to zero volts. When the selector is set to "DC", the entire signal will be displayed on the scope. "
              http://hyperphysics.phy-astr.gsu.edu...opec.html#c316
                The AC ripple voltage will be in the mV range and will increase as the more load is connected.
                Set the scope to AC because you are looking at AC signal riding on top of DC.
                what is the power supply switching frequency?
                • Cohibaman
                  • Jan 2015
                  • 66
                  Yes, that's exactly what I AM doing - I set to meter to AC auto and I see a thick line (the ripple on top of the DC). The problem is when I manually increase resolution (a lower voltage / division) from 5V/division to 1V/division, the trace moves off the screen. I can measure the ripple with the cap in place.
                  • Cohibaman
                    • Jan 2015
                    • 66
                    The trace looks identical whether AC or DC is selected. The only thing that changes is the digital numeric display and AC or DC (depending on which is selected).
                      Looks to me you have it set to AC+DC mode, see page 17 of the user manual for example. it should be on AC only.
                      Do you have user manual?
                      • Cohibaman
                        • Jan 2015
                        • 66
                        Argggg! You were right, kinda. There's two places to select VAC+DC; 1) Under measurement (where I always select either AC or DC; never vac+dc), then 2) under meter options as coupling. Meter coupling was set to AC+DC rather than AC only. It defaults to AC+DC coupling when I hit auto. Doh!
                        Thanks all!
                        • chth96
                          Is it possible bridging tiny broken trace
                          by chth96
                          When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
                          cutting tiny trace.
                          This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
                          Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
                          But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
                          12-03-2022, 11:32 PM
                        • chth96
                          Is it no harm to replace with capacitor without ripple current rating?
                          by chth96
                          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                          Rubycon YK DataSheet (b...
                          04-19-2024, 05:19 AM
                        • Antonynl
                          What are typical ripple voltages on a laptop motherboard?
                          by Antonynl
                          I have here a HP pavilion hp 15-cs2975nd with a 1.095v power supply that is driven by a FDMF3035. I do see about 80mV of ripple on my scope. I searched through the datasheet to find possible values of the ripple but I don't understand the datasheet well enough.
                          So I have two questions:
                          1) what is the typical ripple voltages of gpu/cpu on a laptop or pc mobo?
                          2) what would be the max ripple of a FDMF3035 that drives an output of 1.095V?
                          Would be nice to have a rule of thumb of say a percentage of the supply voltage to be an acceptable ripple voltage....
                          12-09-2022, 06:51 AM
                        • OOF DIO
                          ASUS FX505DV no power shorted at PWM controller Pin 3 VREG3 TPS51225C, need pinpointing of the short.
                          by OOF DIO
                          (If anyone has a functional boardview file of FX505DV/DU that would be helpful)
                          (Had 3 problems, now just 1)
                          I have no experience or knowledge and usage of tools to repair devices besides the entire past 12-10 days of researching, watching YouTube repair videos and troubleshooting this laptop motherboard. ChatGPT was used as a guide to ask questions.
                          I used boardviews of mostly FX505GD-M, and some FX505DU, FX505DD. Used schematics of FX505DU.
                          I had originally intended to replace the BQ24780s first (due to previous battery removal while benchmarking) but I...
                          04-19-2025, 05:03 PM
                        • Ady2017
                          Is there a manufacturers tolerance for ripple?
                          by Ady2017
                          Hi all
                          I need to replace a 680uF 35V SamYoung NXB cap which has got a ripple of 1820. Whilst passing my local little electronics shop I picked up what they had in stock which was a 680uF 35V Panasonic FC with a ripple of 1655.
                          As the ripple rating is only 9% below what the original was I am wondering whether to risk it and fit it.
                          The catalogues specify a capacitance tolerance of +/-20% but state nothing about the ripple. If there is a similar tolerance for ripple then I might be worrying about nothing. Does anybody know?
                          11-13-2021, 11:46 AM
