Thoughts on Solomon SL-30CMC/Tenma 21-1590 Soldering Station?
  • Almighty1
    • Apr 2014
    • 222
    Re: Thoughts on Solomon SL-30CMC/Tenma 21-1590 Soldering Station?
    Same here, the tips for mines is hollow and sits over the element.... Do you think this is the same iron just in a different base as this can use Hakko 936 tips from a search on Google...
    http://www.maplin.co.uk/p/48w-lcd-di...-station-n16ch
    the replacement tips are here:
    http://www.maplin.co.uk/p/spare-48w-...ron-tips-n72cw
    These are the Hakko 900 tips which are also for the 936 which looks similar to the ones I have:
    http://www.ebay.com/itm/10pcs-Solder...item2a450e194a
      • 31196
      the maplin base is the one that replaces mine, those bits are correct.
      although they are something like 4 times the price of the ones i linked at rapid electronics.
      amazing that the base unit is £20 though - it was going for over twice that.
      they must be trying to clear them now they stock Tenma bases.
      i dont know anything about the hakko tips though.
      if they are compatable, they will be cheaper from china.
      • Almighty1
        • Apr 2014
        • 222
        Hmm, interesting. Maybe the thing is everyone is basically using the Hakko sized tips for a given wattage like 48W so they don't have to design their own. Seems like all the sellers are Europe based and I'm in the US so China may actually be cheaper.
        Reply #12 here actually talks about the Maplin and how it's just a clone of the Hakko and can use Hakko tips.
        http://forum.arduino.cc/index.php/topic,89508.0.html
          • 31196
          that guy in reply #12 is refering to the Tenma 60w iron, he didnt read the whole fucking thread before jumping in.
          • Almighty1
            • Apr 2014
            • 222
            I kept thinking he was talking about all 3 of the stations or at least the two on the top.
              by sam_sam_sam
              07-01-2024, 06:34 AM
            • chth96
              What soldering station should I purchase for 900M-TJ-I tip?
              by chth96
              hello.
              A few months ago,I have purchased 0.1mm Soldering Iron Tip of below aliexpress link,But I noticed that It is totally impossible to use this 0.1mm iron tip in the T12 soldering station
              https://ko.aliexpress.com/item/4001275635593.html
              Is there any good soldering station which is possible to use 900M-TJ-I tip and have inexpensive or reasonable price in aliexpress?
              Any reply would be appreciated.
              11-24-2023, 05:08 PM
            • caprider
              Recommendations of quality soldering station and (separate) hot air station
              by caprider
              Hey,
              I'm looking for some recommendations of a decent quality soldering station and a separate hot air station. I'm just a hobbyist, so even if (ultra)premium tools are not required, I still want some good tools. They should be available in Europe.
              I now have a TS100 and some soldering irons and looking for some better tools.
              1. Soldering station, budget around 200-240€
              JBC BT-2BWA seems to be a good product in the budget.
              2. Hot air station, budget around 200€
              Up to now I've found ATTEN ST-862D to be a good option....
              01-15-2022, 02:05 AM
            • mkbehbeh
              KSGER C245 Soldering station PSU 220V only?
              by mkbehbeh
              I purchased this soldering station when it was on sale at amazon. It had a slew of one star reviews, but the price was low enough that even if the controller and PSU were toast, the handle tips and stand were worth more than the price. All of the reviews mentioned that the unit was either DOA, or died on the first use. I looked on Aliexpress and the first clue was that KSGER still sold the 220V version of this station, but all of the 110V versions had been discontinued. I figured That there was a problem with the 110V on the power suppply and the controller would be fine.
              I am...
              04-17-2023, 03:11 PM
            • Peter_1402
              Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
              by Peter_1402
              Hi Everyone,
              I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
              1. Soldering iron works great
              2. There is a burnt mark on the hot air gun handle.
              I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
              Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
              Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
              Reed switch tested ok with a magnet.
              From the above test, I can conclude...
              07-12-2025, 11:50 AM
