HQ SMD Rework station soldering iron repair
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    Re: HQ SMD Rework station soldering iron repair
    i fix that, but back on begining. No heating unless i put aditional 50ohm resistor between sensor.
    ...the quieter you become the more you are able to hear...
    • rtstorm
      • Feb 2012
      • 971
      • Croatia
      so i have 58ohm from sensor and station wont start heating. But when i add 50 ohm i get total of 28-29 ohm, and it is heating. why is that?
        • 31197
        what chips are on the board?
        i had a bad hot air unit like your station, it had a lm386 i think it was - green corosion on the legs!
        it also had a 555 timer with green crap on the legs too!
        you need to see what amplifier chip is linked to the sensor.
        • rievax_60
          • May 2012
          • 897
          • australia
          I can add to the confusion. There are 2 basic types of heaters used in Hakko clones. One is actually the original Hakko heater which has a 50ohm PTC thermistor.
          The other is a Chinese made heater that has a thermocouple. It must be a type K because when I connect my Fluke 87-5 to it on temperature range, I get an accurate temperatue reading of the day.
          My Aoyue 936A uses the original Hakko type heater.
          With the hand piece unplugged, I measure 6V at the socket pin holes for the thermistor.
          If a station needs the Chinese type heater with thermocouple, I would expect to measure no voltage.
          Tell us a lot about the PCB so we might figure it out.
          • rievax_60
            • May 2012
            • 897
            • australia
            This is a schematic for a thermocouple type station. http://s020.**********/i706/1304/f7/f05b997dbf33.jpg
            Actually there will be some voltage at its input. See how well this schematic matches your station. Look for the TL431 first.
              • 31197
              i suspect it's using a ptc,
              but either way, i'd try replacing any op-amps.
              and inspect the entire board too - after seeing in mine, i would never trust one of these Aoyue type units without a full inspection!
                • 31197
                @rtstorm.
                can you post good foto's of the pcb(s)
                if your station isnt digital, you could upgrade the controller btw.
                http://dangerousprototypes.com/forum...hp?f=19&t=3475
                • rtstorm
                  • Feb 2012
                  • 971
                  • Croatia
                  #28
                  here it is
                  the IC is LM358.
                  • rtstorm
                    • Feb 2012
                    • 971
                    • Croatia
                    #29
                    Originally posted by stj
                    @rtstorm.
                    i woud love to upgrade but where can i make PCB
                      • 31197
                      they sell it
                      http://www.seeedstudio.com/depot/ope...html?cPath=174
                      or use stripboard!
                      • rtstorm
                        • Feb 2012
                        • 971
                        • Croatia
                        #31
                        ok thanks, but i cannot find the part list for this board. do the sell whole board ready to use or just PCB? I will first like to see part list to check if i can find all of them.
                          • 31197
                          it was all in the first link.
                          http://dangerousprototypes.com/docs/...v1_development
                          http://dangerousprototypes.com/docs/...ng_Iron_Driver
                          the microcontroller is easy to program,
                          and i'm sure you can source an lcd display from some junk like a fax machine.
                          or ebay one from china.
                          • rtstorm
                            • Feb 2012
                            • 971
                            • Croatia
                            #33
                            well i almost build it. Will post after i finished.
                            • rtstorm
                              • Feb 2012
                              • 971
                              • Croatia
                              #34
                              Almost done
                                • 31197
                                that's nice.
                                the only thing i would have done different is use connectors instead of screw terminals.
                                are you going with the "buttons" version or the "rotary encoder" version software ?
                                • keeney123
                                  Lauren
                                  • Sep 2014
                                  • 2536
                                  I do not know if this is your particular model number Hakko 936 but here are schematics, component layout and parts list. With troubleshooting procedures.
                                  • keeney123
                                    Lauren
                                    • Sep 2014
                                    • 2536
                                    Sorry did not see second page.
                                      • 31197
                                      yes, it is going through "evolution"
                                        by sam_sam_sam
                                        07-01-2024, 06:34 AM
                                      • acedogblast
                                        by acedogblast
                                        11-02-2024, 05:13 PM
                                      • shahnld
                                        wds-580 rework station issue
                                        by shahnld
                                        Good day.
                                        i received used bga rework station wds-580 which was not going above 300c despite the parameter was set to 350c, Everytime beeps at 300c so i did a factory reset and by mistake washed data and log etc. now the station boots to a white screen.
                                        Does anyone has a firmware for this station and want to share with me. i will really appreciate any help possible..
                                        kind regards...
                                        03-28-2024, 01:14 PM
                                      • caprider
                                        Recommendations of quality soldering station and (separate) hot air station
                                        by caprider
                                        Hey,
                                        I'm looking for some recommendations of a decent quality soldering station and a separate hot air station. I'm just a hobbyist, so even if (ultra)premium tools are not required, I still want some good tools. They should be available in Europe.
                                        I now have a TS100 and some soldering irons and looking for some better tools.
                                        1. Soldering station, budget around 200-240€
                                        JBC BT-2BWA seems to be a good product in the budget.
                                        2. Hot air station, budget around 200€
                                        Up to now I've found ATTEN ST-862D to be a good option....
                                        01-15-2022, 02:05 AM
                                      • rmjimenez455@gmail.com
                                        Sumsour station 8586D error H-E
                                        by rmjimenez455@gmail.com
                                        Hello everyone, next I have the following problem with the Sumsour 8586D 110v dual station I bought it a year ago and it worked wonderfully, now it presents the H-E error on the soldering iron side, the hot air side works correctly..... I disassembled the soldering iron head because the manual tells me that this error is due to ceramic resistance problems, in effect, I measured it and it is open, I bought a new one that is working verified in a soldering iron and nothing.... The same error continues, I proceeded to open the station and check visually, I found a totally damaged 1R00 surface mount...
                                        09-07-2024, 09:33 AM
