HQ SMD Rework station soldering iron repair
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    Hello, i need some help. On my soldering station solder iron died (heater) So i order new one and when i get it it wont work.
    So i check it, disassemble it and i cant read the resistance of heater! Am i doing this right?
    On pins from the picture i can read 28V AC so i think the heater is dead?
    ...the quieter you become the more you are able to hear...
  • bukurat
    • Sep 2014
    Re: HQ SMD Rework station soldering iron repair
    You should be able to read the resistance of the heater if its intact.
    28V seems reasonable for a heater. It first guess I would say its open circuit.
    • rtstorm
      • Feb 2012
      • 971
      • Croatia
      yes i order new heater then we will see
      • rtstorm
        • Feb 2012
        • 971
        • Croatia
        hello i noticed that i have 28V between red and blue wires. So i think this hakko soldering iron have different wiring.
        • rtstorm
          • Feb 2012
          • 971
          • Croatia
          i have check by this link
          https://cdn.badcaps-static.com/pdfs/...9e73bfb1cb.pdf
          and i have pin 4 and 5 - 3ohm, pin 1 and 2 - 54ohm, and pin 3 and tip - 2 ohm. i measured output from station on pin 4 and 5 i have 3VAC
          • rtstorm
            • Feb 2012
            • 971
            • Croatia
            ok i am stuck at this and cannot get this thing to work. I changed heat element and i cannot get 24V on heater. I disasseble the station and i see a crap of soldering. Please tell me how this this work? What shoud be connected to sensor and what to heat element?
              • 31046
              before you do anything else,
              check the cable with a meter to make sure there are no broken wires.
              every iron i'v had has eventually needed a new cable/needed a section removed.
              • rtstorm
                • Feb 2012
                • 971
                • Croatia
                i did, and this is a new iron. wire is ok
                  • 31046
                  a new iron?
                  are you sure it's wired the same as the old one?
                  these cheap units keep changing the wiring around, that's probably why you have that mess where the pcb connects to the socket.
                  • rtstorm
                    • Feb 2012
                    • 971
                    • Croatia
                    hmm you think i shoud try to swap sensor and heater wires?
                      • 31046
                      no, i'm saying may you should look at how the old one is wired.
                      btw, the sensor is usually a thermocouple - those have polarity.
                      • rtstorm
                        • Feb 2012
                        • 971
                        • Croatia
                        i do not have old one
                        • rtstorm
                          • Feb 2012
                          • 971
                          • Croatia
                          i notices when i shorted sensor pins the heater instantly go really hot. i think that something is wrong on board.
                            • 31046
                            reverse the sensor wires and see what happens.
                            the sensor normally generates a voltage that rises with temperature on most irons,
                            although a few use a temperature sensative resistor.
                            try connecting the sensor to a voltmeter set to read millivolts, then heat the sensor with a lighter.
                            if you see a rising voltage then it's a thermocouple.
                            • rtstorm
                              • Feb 2012
                              • 971
                              • Croatia
                              when i connect a heater it wont work but when i shorted the sensor wire with 50ohm resistor temp rises. So my guess is that thermocouple if fail. I have 58Ohm on it but function of thermocouple is fail. I try what STJ suggest and i do not have any reading.
                                • 31046
                                try heating the sensor with the meter set to read resistance.
                                • rtstorm
                                  • Feb 2012
                                  • 971
                                  • Croatia
                                  yep i try the resistance raise when i heat the element, so i think polarity would not have any effect
                                  • rtstorm
                                    • Feb 2012
                                    • 971
                                    • Croatia
                                    ahh i going crazy, now main filter capacitor i blown every time i turn on soldering.
                                      • 31046
                                      then a rectifier diode is shorted.
                                      • rtstorm
                                        • Feb 2012
                                        • 971
                                        • Croatia
                                        hmm, i test and it's OK. But now i see that i put 16V cap the voltage of board is 28V AC. I think that is the reason why it was blown
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
                                        • caprider
                                          Recommendations of quality soldering station and (separate) hot air station
                                          by caprider
                                          Hey,
                                          I'm looking for some recommendations of a decent quality soldering station and a separate hot air station. I'm just a hobbyist, so even if (ultra)premium tools are not required, I still want some good tools. They should be available in Europe.
                                          I now have a TS100 and some soldering irons and looking for some better tools.
                                          1. Soldering station, budget around 200-240€
                                          JBC BT-2BWA seems to be a good product in the budget.
                                          2. Hot air station, budget around 200€
                                          Up to now I've found ATTEN ST-862D to be a good option....
                                          01-15-2022, 02:05 AM
                                        • shahnld
                                          wds-580 rework station issue
                                          by shahnld
                                          Good day.
                                          i received used bga rework station wds-580 which was not going above 300c despite the parameter was set to 350c, Everytime beeps at 300c so i did a factory reset and by mistake washed data and log etc. now the station boots to a white screen.
                                          Does anyone has a firmware for this station and want to share with me. i will really appreciate any help possible..
                                          kind regards...
                                          03-28-2024, 01:14 PM
                                        • rmjimenez455@gmail.com
                                          Sumsour station 8586D error H-E
                                          by rmjimenez455@gmail.com
                                          Hello everyone, next I have the following problem with the Sumsour 8586D 110v dual station I bought it a year ago and it worked wonderfully, now it presents the H-E error on the soldering iron side, the hot air side works correctly..... I disassembled the soldering iron head because the manual tells me that this error is due to ceramic resistance problems, in effect, I measured it and it is open, I bought a new one that is working verified in a soldering iron and nothing.... The same error continues, I proceeded to open the station and check visually, I found a totally damaged 1R00 surface mount...
                                          09-07-2024, 09:33 AM
