Looking at picking up the UNI-T 81b (any thoughts?)
  • The Performer
    • May 2013
    • 60
    • United states
    As the title says, Im in need of a new portable scope. Previous one was the dso nano v2 which got fried.
    I've used the TPI440 and it seems to be a decent meter as well, but much more expensive.
    As of right now my scope usage is very primative, I'm an autotech at best buy and the most extensive use for me is testing wiring to find can networks, and viewing sine waves to set clip levels of amplifiers. That's pretty much what I use a scope for on a day to day, however Im also hoping to get into college to study electronics engineering if I can get my grades up, maybe it will be handy to have a scope meter for that as well.
    Reason Im looking at the 81B is it's a mix of scope and DMM which would be right up my alley of usefulness. I currently have my main meter a fluke 117.
    So that being said, has anyone used one? Likes, dislikes? Better options?
    Thanks in advance!
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Looking at picking up the UNI-T 81b (any thoughts?)
    Martin did a review.
    https://www.youtube.com/watch?v=9SPcgNGTiOA
    --- begin sig file ---
    --- end sig file ---
    • The Performer
      • May 2013
      • 60
      • United states
      Originally posted by retiredcaps
      Yes, that video was a great review. Still just curious if anyone had anything to add.
      • ngml
        Repair of an LG split AC system indoor unit PCB
        by ngml
        I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
        This indicates an error in the communication between the outdoor and the indoor unit.
        The outdoor unit is fine, so the problem is the indoor PCB.
        The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
        I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
        Does anybody have the schematics of this board,...
        02-01-2025, 12:55 PM
      • bauto601
        KDM 480W PSU upgrade succes! (opinions?)
        by bauto601
        Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
        A "nice" YoungYear unit? - Badcaps
        The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
        12-26-2023, 03:05 PM
      • repair-it
        Need advice testing a samsung power supply board with scope
        by repair-it
        I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
        07-12-2025, 11:00 AM
      • jason123
        Agilent 33220A 20 MHz Function Generator
        by jason123
        I can't find a forum to discuss "instrumentation Troubleshooting", but PS maybe the closest.
        So, I'm having an issue with about 13 year old Agilent Function Generator. it works, passes self-test, but it has an annoying "audible" noise, that changes as I change the output frequency setting of the instrument. Prominent around 600 Hz and up (at least that's what my ears are picking up.) I saw on some forms that it could be fan, linear regulator, dried up caps,... I can't seem to find the source of audible noise. Here is what I tried:
        1. Turn the output off - still...
        07-01-2025, 08:12 AM
      • nobbnobb1
        Bose Companion 5 - Unit Powers On then Cuts Off Shortly After
        by nobbnobb1
        Hi guys,
        Trying to salvage a Bose Companion 5 computer speaker system that powers off shortly after powering on. It's got a primary USB input (built in DAC) and an aux 3.5mm input. The USB appears to be the primarily source that tells the unit to power on (control pod LED goes green) as the unit has no power switch.
        When I first connect power to the unit, plug in the USB, it will play audio nicely for a minute before it drops out and the unit appears to go into standby (control pod LED goes red). It stays in standby and I cannot seem to power it back on without physically...
        02-03-2022, 11:14 AM
