Has anyone Used Cold Heat Solder iron
  • MadCow
    • Jul 2007
    I have one of these new Cold Heat soldering iron
    See article:
    http://www.msnbc.msn.com/id/6151688/
    So far I have tried it for removing some caps from some old boards that I have and it works very nicely. I have not tried an install yet.
    I was wondering if anyone here has any experience with using the device.
    Jay
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Has anyone Used Cold Heat Solder iron
    not recomended for mobo repairs.can apply voltage to parts and destroy them.
    imho its a p.o.s
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16955
      imho its a p.o.s
      Yup. Cold heat is an electronics disaster. just forget you ever saw that thing.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • gastorgrab
        • May 2007
        • 320
        Most tutorials promote the use of a grounded soldering iron for anything sensitive. I assume this is so that static charges dont move back and forth between the the iron and the component as you solder each joint.
        I'm not sure if was here that it was posted but somewhere there is a picture of the cold heat iron with a LED across its contacts.
        The LED is glowing in the picture.
        It may be fine for general purpose soldering (i dont know) but there are definately warnings out there about using 'Cold-Heat' for sensitive electronics.
        • Logistics
          • Apr 2007
          • 721
          Lol, cold heat soldering irons are basically little arc welders. Does it sound like it's good for electronics, now?
          And HEY... TOPCAT, I see you're around! You'z gots'a problim wit yer PM's ur'wut?
          • starfury1
            • May 2006
            • 1256
            Never a good idea unknown voltages on an Electronics PCB...
            Ideally not only iron but you and PCB should be at the same potential
            (usually grounded together to prevent static build up ,discharge)
            Yeah TC you can run but you cant hide.....Logistics is on to you and needs your help
            So contact him before he has a break down
            Cheers
            • Junk Parts
              Court Jester
              • Jun 2006
              • 8953
              It don't sound good to me for use on electronics at all. Send it to me and I will use it to fix old brass/ copper car radiators Mate! There are no I.C's in 57 chevy belair radiators....LOL
              Mark Twain
              John Paul Jones
              Rod Serling
