I was given two unused spools of this still in little faded red and white boxes. No corrosion at all on the wire, looks brand new. It doesn't say what the alloy is. I can barely get it melting at 360c with a 2mm tip on my 70w iron. With my 100w gun it seemed to melt around 360c tip temp too. Any ideas?
OLD Spartan 2mm solid wire solder
Tags: None
Re: OLD Spartan 2mm solid wire solder
Could be. I got it from my mom-in-law who used to have a boatload of craft supplies in her garage so I'm guessing it might also be craft solder. Since it is very old and shows no sign of corrosion I'm guessing it is lead free as well. I have a spool of pretty thick (1/16" dia) 60/40 solder that has gotten dull grey over time and I am pretty sure this stuff is much older than that and it shines like new.
edit - I have no intention of using it for electronic/electrical work, I am just curious of it's actual composition.Last edited by SteveNielsen; 05-24-2014, 11:33 AM.Comment
Yes it does. The lowest melting point lead/tin solder is the eutectic 63/37 with 183C. Lead alone or tin alone will have higher melting points. High lead solder (5Sn/95Pb) melts at 350C.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
Melting points is weird (swiped from Wikipedia)
Pure Lead: 328 C
Pb90 Sn10: 270-302 C
"non electronic" PbSn 60/40: 183-242 C
50/50: 183-214 C
Electronic/Cheap PbSn 40/60: 183-189 C
Eutectic PbSn 37/63: 183 C
Pb5 Sn95: 238 C
Pure tin: 232 C
Something seems wrong the temperatures reported, though Wikipedia may be wrong too. However for sure that the melting point of any mixture of lead and tin should be lower than of pure lead.
That being said I have heard of 100% lead solder before and it's very possible. But lead is very dull gray so if it's shiny, it's probably not 100% lead.
Recently I've been working on my car's antifreeze and the Ethylene Glycol-Water mixture behaves similarly due to crystal formation interference. Water freezes at 0C, Pure Ethylene Glycol at -13C, but if you have a 30:70 mixture (the eutectic of water:ethylene glycol) the freezing point drops down to near -70C... Strange behavior? Nah, that's how it works...Comment
360c was the soldering tip temp measured with a type K probe when the solder melted. I understand having to get the tip much hotter than the melting point to get enough heat built up to override the heat-sinking properties of the rather thick (2mm) solder wire though. It wasn't meant as a particularly scientific measurement.Comment
REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
- No Clean Formulations
- Low residue
- Range of activity to deal with different component solderability
- Halide free
- Suitable for dispensing
- Compatible with solder coatings and/or No Clean flux cored solder wire product range
Both products are supplied in syringes or cartridges for application by dispensing....-
Channel: Common Parts Library - Datasheets
10-07-2024, 06:02 AM -
by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
There are some specialty tools needed to do this task. The replacement MEC1503 chips can be acquired from Aliexpress. Do not buy the bare chips as... -
by wnlewisOK. I got the rocker switch figured out thanks to the good advice on this forum.
Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
This is a Whirlpool RDE3340 electric range.
The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
Where may I find parts... -
by re-atariHello all,
Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...-
by petemanukSo I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder... - Loading...
