How do I remove the chip from the board
  • harp
    • Jun 2022
    • 648
    • Planet Earth
    After 30 minutes... my meal is done! (:
    • Mr.Pc
      • Jan 2023
      • 42
      • Brasil
      I always add soldering flux, leave the blower without the nozzle and use stronger air flow. Turn on the station, wait 1 minute to warm up better and then make circular movements around the IC. Use tweezers to check if the IC has come loose. Furthermore, you need to practice a lot until you improve your technique.
      • gusto
        • Oct 2024
        • 34
        • Czech Republic
        Originally posted by harp
        Can you confirm that a thin wire like 0.1mm go from one corner to another diagonaly, like red drawing. If you have trouble putting it after chip, drag it behind legs like green drawing and pull up it to straight. You can determine if on center has barier observing lenght of wire.
        Sorry, I use google translator, but I don't understand what you wrote.​
        • gusto
          • Oct 2024
          • 34
          • Czech Republic
          I soldered about 5-6 chips. Some were successfully unsoldered, others not.
          I will try according to your instructions​
          • harp
            • Jun 2022
            • 648
            • Planet Earth
            but I don't understand what you wrote. ?............... the 30 minute on high temperature is a lot so it is reasonable to be suspicious... I sugest you method to just be sure that that particular chip on board is not soldered or glued to pcb. Use a thin wire to see if it is freely go under ic.
            • gusto
              • Oct 2024
              • 34
              • Czech Republic
              #26
              Thanks, now I understand what you meant.
              I desoldered the chip, but many things went wrong. Some copper roads are destroyed. I managed to partially fix it, but it wasn't perfect. I soldered a new chip today, but it turned out even worse.
              I don't want to comment on that. I want to forget about it.​
              • CapLeaker
                Leaking Member
                • 8352
                Originally posted by gusto
                I don't like it at all
                I heat the chip with hot air and nothing happens. I set the temperature to 380°C and heated for 10 minutes. Then I increased the temperature to 400°C and heated for another 10 minutes. I don't see any solder melting. I increased the temperature to 420°C and nothing even after 10 minutes.
                After 30 minutes I resigned.
                Am I making a mistake somewhere?
                I was already warned that the metal surface can be soldered to the board from below. However, I have bought new chips and there is no metal surface on the chip.
                Specifically, it is a chip (see picture above) ADV 7623. It is an onkyo home theater page number. 13
                I think you aren't using any low melt / quality solder and flux.
                I cook a meal in my air fryer faster than 30 mins.
                • gusto
                  • Oct 2024
                  • 34
                  • Czech Republic
                  #28
                  I return to the problem again
                  Here are the pieces that were swept away by the hot air.
                  I can't find out which output is number 1 on the stepdown converter, etc.
                  I want to solder the parts to their places
                  • kevingill
                    • Jun 2013
                    • 152
                    • England
                    #29
                    You'll have to measure each component and check against the schematic to see which one goes where. The 8 leg components are probably resistor or inductor ladders and can be placed either way round.
                    You probably have too much air on your hot air workstation, or the temp isn't what you think it is.
                    I'd mask off the area first and always apply flux around the area to speed up the solder melt.
                    • gusto
                      • Oct 2024
                      • 34
                      • Czech Republic
                      #30
                      I mainly need to find out the terminals on the stepdown converters Q8102 and Q8103 (see picture).
                      Scheme page 13
                      • harp
                        • Jun 2022
                        • 648
                        • Planet Earth
                        #31
                        You are on the wrong track, check it, that 8 leg thing is not ic from schematic... probably resistor array if resistance between sides of each is the same, eg 4x1k... if is near zero - filter... may be fitted on anyway side. The components are enough large to mount it with soldering iron, to minimize temp stress to ic and pcb...
                        • harp
                          • Jun 2022
                          • 648
                          • Planet Earth
                          #32
                          On schematic R8155 is 22x4 on ic pin #75, so four paralel resistor each of 22 ohms, and R8138 on ic pin powmax/realpcpower atx psu is 33x4...
                          • harp
                            • Jun 2022
                            • 648
                            • Planet Earth
                            #33
                            This "auto-corect" is stupid, i wrote similary but for pin nr.90... wtf node nr.90?!?
                            • gusto
                              • Oct 2024
                              • 34
                              • Czech Republic
                              #34
                              Thank you very much for the information. However, during the measurement, some parts jumped off and I didn't fit them anymore. I have to order new ones. I'll get back to you later.
                              • harp
                                • Jun 2022
                                • 648
                                • Planet Earth
                                #35
                                Then, just use more flux...
                                • xiaodongchem
                                  • Oct 2023
                                  • 中国
                                  #36
                                  First, pile some lead-tin material on the chip pins, and then use a hot air welding gun to heat it and it will be easy to blow it off.
                                  • acedogblast
                                    by acedogblast
                                    11-02-2024, 05:13 PM
                                  • howardc64
                                    by howardc64
                                    Problem
                                    08-04-2024, 10:36 PM
                                  • reessi
                                    Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                                    by reessi
                                    Hello:
                                    I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                                    I started on the ACER:
                                    Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                                    All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                                    I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                                    10-29-2024, 11:31 AM
                                  • howardc64
                                    by howardc64
                                    07-24-2025, 05:17 PM
