How do I remove the chip from the board
First, pile some lead-tin material on the chip pins, and then use a hot air welding gun to heat it and it will be easy to blow it off. -
Thank you very much for the information. However, during the measurement, some parts jumped off and I didn't fit them anymore. I have to order new ones. I'll get back to you later.Leave a comment:
On schematic R8155 is 22x4 on ic pin #75, so four paralel resistor each of 22 ohms, and R8138 on ic pin powmax/realpcpower atx psu is 33x4...Leave a comment:
You are on the wrong track, check it, that 8 leg thing is not ic from schematic... probably resistor array if resistance between sides of each is the same, eg 4x1k... if is near zero - filter... may be fitted on anyway side. The components are enough large to mount it with soldering iron, to minimize temp stress to ic and pcb...Attached Filesif you find these attachements useful please consider making a small donation to the site
I mainly need to find out the terminals on the stepdown converters Q8102 and Q8103 (see picture).
Scheme page 13Attached Filesif you find these attachements useful please consider making a small donation to the site
You'll have to measure each component and check against the schematic to see which one goes where. The 8 leg components are probably resistor or inductor ladders and can be placed either way round.
You probably have too much air on your hot air workstation, or the temp isn't what you think it is.
I'd mask off the area first and always apply flux around the area to speed up the solder melt.
I return to the problem again
Here are the pieces that were swept away by the hot air.
I can't find out which output is number 1 on the stepdown converter, etc.
I want to solder the parts to their placesAttached Filesif you find these attachements useful please consider making a small donation to the site
I think you aren't using any low melt / quality solder and flux.I don't like it at all
I heat the chip with hot air and nothing happens. I set the temperature to 380°C and heated for 10 minutes. Then I increased the temperature to 400°C and heated for another 10 minutes. I don't see any solder melting. I increased the temperature to 420°C and nothing even after 10 minutes.
After 30 minutes I resigned.
Am I making a mistake somewhere?
I was already warned that the metal surface can be soldered to the board from below. However, I have bought new chips and there is no metal surface on the chip.
Specifically, it is a chip (see picture above) ADV 7623. It is an onkyo home theater page number. 13
I cook a meal in my air fryer faster than 30 mins.Leave a comment:
Thanks, now I understand what you meant.
I desoldered the chip, but many things went wrong. Some copper roads are destroyed. I managed to partially fix it, but it wasn't perfect. I soldered a new chip today, but it turned out even worse.
I don't want to comment on that. I want to forget about it.Leave a comment:
but I don't understand what you wrote. ?............... the 30 minute on high temperature is a lot so it is reasonable to be suspicious... I sugest you method to just be sure that that particular chip on board is not soldered or glued to pcb. Use a thin wire to see if it is freely go under ic.Leave a comment:
I soldered about 5-6 chips. Some were successfully unsoldered, others not.I always add soldering flux, leave the blower without the nozzle and use stronger air flow. Turn on the station, wait 1 minute to warm up better and then make circular movements around the IC. Use tweezers to check if the IC has come loose. Furthermore, you need to practice a lot until you improve your technique.
I will try according to your instructionsLeave a comment:
Sorry, I use google translator, but I don't understand what you wrote.Can you confirm that a thin wire like 0.1mm go from one corner to another diagonaly, like red drawing. If you have trouble putting it after chip, drag it behind legs like green drawing and pull up it to straight. You can determine if on center has barier observing lenght of wire.Leave a comment:
I always add soldering flux, leave the blower without the nozzle and use stronger air flow. Turn on the station, wait 1 minute to warm up better and then make circular movements around the IC. Use tweezers to check if the IC has come loose. Furthermore, you need to practice a lot until you improve your technique.Leave a comment:
Can you confirm that a thin wire like 0.1mm go from one corner to another diagonaly, like red drawing. If you have trouble putting it after chip, drag it behind legs like green drawing and pull up it to straight. You can determine if on center has barier observing lenght of wire.Attached Filesif you find these attachements useful please consider making a small donation to the site
Specifically, it is a chip (see picture above) ADV 7623. It is an onkyo home theater page number. 13Leave a comment:
I already bought a replacement chip (2x to be sure) and it doesn't have a grounding pad.Leave a comment:
Whenever you see the bunch of via grupped behind chip, it indicate that that ic probably have ground plane pad on center connected to board... so you expect trouble. Make a very good photos of that area, and do some measurements, note, say value od caps, shorts and soic8 all leg in diode mode and write that on picture... this value can use to compare it after work was done.................. When solder liquified, its surface tension hold component on place. In that state you must be very careful to do not touch any component, run hotair excessively on it or shake the board. If the board lay on desk on component side, you have to do some support that lift board from desk to not interference with bottom component. Do not cover it with anything on back side, but from heating side protect with metal shield (can of cola) electrolitic caps and connector and other valuable stuff.Leave a comment:
by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
There are some specialty tools needed to do this task. The replacement MEC1503 chips can be acquired from Aliexpress. Do not buy the bare chips as... -
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
Assuming...7 Photos -
by reessiHello:
I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
I started on the ACER:
Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
- Loading...
