Just recapped me first board!
  • hunter4u
    • Mar 2007
    • 3
    Well thanks to all the info here,I believe I just breathed some life back into an MS-6570.
    My test board is still just that currently as I never could clear one of the holes, but that also happened on the MSI board.
    Just a tip to anyone who might need it, I culd not find anything lying around that was stainless to push thru the holes, ended up making me a tool.
    I used a old spinner bait---lol--- clipped the ends off of it and it worked just fine as I assumed it would, for it was old and well used and not a bit of tarnish on the finish--must be stainless I thought... it is..
    Just a quick question though, will running memtest overnight be a sufficient enough tst on it, or are there certain programs I need to run to test it prior to installing in its new home?
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: Just recapped me first board!
    Best test, throw an OS on it and use it. If it's stable, you got it. I have some diagnostics utils that are very particular, but I've seen failed caps boards run memtest for days without any errors.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • gonzo0815
      • Feb 2006
      • 1600
      I am used to use the Ultimate Boot CD (UBCD) for sutch tests.
      First i use Prime95, wich should runn at least for a few hours.
      Then windos memory diagnostic and memetest are good tools too.
      ATM i think WMD is a little better then memtest.
      • gdement
        • Jan 2007
        • 690
        I'd also make note of the voltages, while using a PSU which you know should be able to power the board. Make sure nothing is sagging too much for comfort.
        But definitely try beating on the board inside a full OS. Memtest doesn't seem to put as much electrical load on the board since it isn't stressing as many components. A marginal board can pass memtest but choke under heavier loads.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          wanna beat it up good?
          download folding at home and enter team 49813
          and a quick preliminary test is to boot a knoppix live cd.
          if it gets to the desktop without errors its likely ok.
          • hunter4u
            • Mar 2007
            • 3
            ok Thanks guys, will use other tests this evening, as it ran all night with no errors with memtest.
            • hunter4u
              • Mar 2007
              • 3
              oh well, seems to not take a liking to something, as it will load the ubuntu live , but never complete the booting of the graphics display, guess either I fubar'd the recapping (possilble for sure) or the board had other illness on top of the 1 bad cap.
              this board was from where I work, it had been having issues with the floppy drive for some time, cant remember if she pooped before we replaced the system or not, i just know i had to order a new one to replace it.....
              any ideas on what else that cap may have took out? it is in the line of caps beside the cpu and the backplate. Guess I can save her for a rainy day project, unless u guys know where i can get a replacement socket a 400 fsb mb, and not a pcchips one..
              thanks guys
              • Fizzycapola
                • Oct 2006
                • 423
                For testing I use something that uses as many devices as possible.
                One of these new free to play online games uses alot of devices if you can run one : puts full load on all system components at the same time: CPU, Graphics, Network, Sound, Hard Disk. If I can leave such a game running for a few days without a glitch I consider the system acceptable and more reliably reliable than from passing a simulated test.
                I also use Speedfan to show voltages over time. And MBProbe after calibrating set a 5% or less tolerance in voltage settings with log enabled (under constant - as opposed to rapid variable load - I achieved constant <2% tolerance with overnight testing using Rubycon ZL and CPUVoltage undervolted to achieve lower CPU temperature). Whilst these programs read from board sensors, I take their ripple/fluctuation/deviation readings as accurate enough to be useful data. When viewing PC Health in BIOS voltages should hardly change, (especially considering all devices are at a constant workload as compared to in Windows), (I use arrow keys to force faster refreshing) ofc they should read what they're meant to also.
                Rubycon Rubycon Rubycon
                • bgavin
                  • Jan 2007
                  • 1355
                  Every single one of my KG7 boards fail Memtest with the classic Athlon test failure. I've run the test on more than a dozen, and none will pass. All have been in service error free for a long time.
