Poor solder joints
  • SonicSteve
    • Oct 2005
    • 54
    Poor solder joints
    Hi guys,
    I've been meaning to ask this for some time now and just haven't.
    Why do some solder joints not bond well. Often I will replace 5-8 caps at a time. Some joints are harder to solder though. It seems that the solder doesn't fill the hole on these ones. With a little wiggling I can literally cause the joint to come loose.
    I then have to pull the capacitor off clean the hole and keep trying till I see the solder fill the hole.
    Does anyone know why some of the joints do this?
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Poor solder joints
    what iron are you using, what temperature
    what solder
    • SonicSteve
      • Oct 2005
      • 54
      what solder
      I'm using a weller wlc100 with the spg40 with a chisle tip. The iron base is set to slightly more than 4 out of 5. So I don't know exactly what temp it is.
      The solder is light duty rosin core. 60/40 .8mm or .032"
      Should anything like rubbing alcohol or water be used to help clean the yellowish residue?
      • Rainbow
        • Aug 2005
        • 1375
        The solder joint is bad usually because of low temperature. Both parts that needed to be soldered together must be hot enough.
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          the iron should be ok for soldering. i was thinking if it is defective but if you can remove caps easily then it must be hot enough.
          i would suggest to try a different solder. otherwise you will have to modify your technique.
          • dood
            Deputy dood
            • Mar 2004
            • 2462
            I use that same iron, and on most joints I leave it right between 3 and 4. However, if you have a joint that's located on a large grounding plane, the ground will soak up a lot of the heat fast, so you need to bump up the temp and work faster to get a good joint.
            Ludicrous gibs!
            • SonicSteve
              • Oct 2005
              • 54
              Here is my technique,
              1. remove bad cap (using a desoldering iron with pump)
              2. clean the holes out with a pin
              3. scrap off any yellow residue from old solder joints
              4. Clean with Rubbing alcohol
              5. replace caps
              a. put solder on iron tip, heat the capacitor lead with iron and solder.
              b. apply solder to joint area till hole fills.
              Any tips?
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                no you must heat up both the lead and the pad around the hole with the iron and touch the solder to the pad.
                basically if you dont heat both, the flux will form on the cold part and the solder will form around the flux.
                • SonicSteve
                  • Oct 2005
                  • 54
                  I do try to heat up the pad, I'm just a bit paranoid as to damaging the board by leaving the hot iron too long.
                  • willawake
                    Super Modulator
                    • Nov 2003
                    • 8457
                    • Greece
                    its very doubtful the board would get damaged while soldering. more likely to get damaged while removing caps.
                    i guess its 3-5 seconds to make a nice joint.
                    • SonicSteve
                      • Oct 2005
                      • 54
                      Thanks,
                      I'll give it a go with that advice. The flux explanation does explain a few things. I guess the pad just wasn't quite hot enough. The iron I know is plenty hot, it will melt the solder on contact without delay.
                      Is there a definite rule as to how long is too long to leave the iron touching the boards pad?
                      • abajor
                        x1 Carbon Gen 9 HYG60\HX4B0 NM-D341 Rev: 1.0, CSD87501L Failed solder Joints.
                        by abajor
                        I had a x1 Carbon Gen 9 come in with a no charge and no USB C power up problem (the machine would turn on with a new battery until it lost charge).
                        I noticed lifting the protective black membrane near the USB jacks that two little BGA chips were stuck to the adhesive and had fully released from the mother board, one of them looking fully scorched. Q261 and Q263 power MOSFETS.
                        I found the schematic and diagram for the board here.
                        https://www.badcaps.net/forum/troubl...e-devices/sche...
                        07-20-2024, 04:46 PM
                      • corrize
                        Best way to solder LVDS connector for beginner (and qfn) ?
                        by corrize
                        Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                        I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                        I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                        See the test :
                        https://youtu.be/bNAzC-EvqHs?t=1767
                        With hot air from bellow the board, that's...
                        03-09-2023, 02:57 AM
                      • jm1234
                        Solder joints on heat sinks matter?
                        by jm1234
                        solder joints on heat sinks - how much do they matter? Could poor joints on heat sink cause issues if they are not properly joining to hot ground?
                        I'm looking at power source module of Panasonic plasma TV and I see many of these having visually poor quality, but could they matter? In general I would guess no, but I saw a video where someone was stressing out the importance of tightening the screws when fastening the power source board specifically for the ground to be connected properly.
                        04-28-2024, 04:38 AM
                      • petemanuk
                        BGA solder balls not connecting - help pls
                        by petemanuk
                        So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                        I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                        I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                        11-16-2022, 05:21 AM
                      • myth77
                        UV solder mask - high temp resistent, recomendation?
                        by myth77
                        Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                        Is there any solder mask...
                        03-28-2022, 04:04 AM
