CPU socket replacement soldering profile
  • Geomih
    • Oct 2023
    • 7
    • United Kingdom
    Hi All - I am hoping someone can help with some pointers (complete noob here!)
    I have recently purchased a Scotle HR460 BGA reball machine (it's a bit old and I think the company no longer exists either), but as far as I can tell it is a competent and unmolested machine that should be good enough for my needs.
    My biggest problem is that it came with no profiles, and I must re-create all of them from scratch, something that is very scary for someone that doesn't really know what they are doing.
    The simple stuff like a small memory module isn't a big deal because there are a few example profiles in the manual – but for more than that the manual is no help as it is very basic. Also, it does not contain any of the advanced features, so I have no idea if the fan speed that is programmed in is fast or slow or if it needs to change based on the application.
    Primarily I bought this style machine to do socket replacements on AM5 and LGA1700 boards, but after what looked like a promising start with a profile that worked well for desoldering, I am afraid I might have become overconfident and ruined a Strix Z690 board as the same profile was not OK for soldering a new socket back.
    This is the complete profile that I used:
ID:	3160983Click image for larger version
    The last number in the corner that is in glare is 250C.
    Unfortunately, I am not 100% sure how the board died, it still turns on at it doesn't trip OCP, but all the diagnostic LEDs stay off while before it would show that it got stuck on RAM (the missing pins were RAM-related). It might be that I overcooked it or when I tried to turn it on first time it had an internal short and that was that. Regardless with nothing to lose I un-soldered the CPU socket again and it was immediately clear that only the corner balls had melted and made good contact while all the others were untouched. I do not believe the board is warped so I don't think that was the issue. I have read some older posts on here with someone else complaining of the same issue, I don't know if they fixed it or not - I did send them a PM.
    At this point I am just hoping that the test CPU and memory did not get damaged in the process…I will know for sure in two days' time when I get a new motherboard delivered as instead of buying a Celeron or something I used an I7 13th gen for testing.
    Does anyone have a similar machine and have you developed your own profile that you know works for various applications? Obviously, a socket soldering profile would be amazing but even a 50 x 50 GPU or large SMD profile I think would be immensely helpful in diving what sort of settings I need.
    I can set 6 stages for my machine and the temperature, rate of climb and hold time can be set independently for the top heater, bottom heater and additional IR heaters.
    The other advanced parameters such as fan speed and segmentation parameters I do not know how to adjust so I left them alone – if they are the same as they left factory, or the previous owner has changed them I have no way of knowing. I was tempted to factory reset the machine hoping that the profiles would show up, but thankfully I checked online, and it seems other people that have done that ended up with a “blank” machine without any software so I won't be doing that.
    Sorry for the long post and thank you for reading!
  • jasko_jacker
    • Oct 2014
    • 1140
    • italy
    From the specifications I saw that it has an air top and bottom + IR bottom. However, if it has a top IR and a bottom IR, the profiles change.
    In general, if you have to replace the plastic socket of the CPU it is very important (do not apply this rule to BGA chips) that the profile is as slow as possible because we are not interested in keeping it within certain time limits but we are interested in the temperature rising slowly. in order not to damage the motherboard it is important that the temperature of the part under the socket (bottom layer) does not exceed 205 210 degrees centigrade (in the final phase of the soldering process when the top also interferes) while as regards the temperature of the top obviously it must not be lower than the melting point of the alloy used (remember that it is important to place one or two thermocouples near the socket which must touch the board and must be placed in such a way that the air is not directed, some machines refer to the temperature of the air and not of the card and this must be considered). For this type of intervention, however, air is better than IR due to a question of heat absorption also linked to the color of the socket. The process should last no less than 6 or 7 minutes. if you tell me what type of top and bottom you have I can try to recommend a profile or how to create it.​
    • Lisa Su
      Badcaps
      • Apr 2021
      • 216
      • Taiwan
      This might give some insight on LGA1700 socket replacement.
      • Geomih
        • Oct 2023
        • 7
        • United Kingdom
        Thank you so much for the replies and insights Jasko_jacker and Lisa Su - I can't tell you how much this helps for someone like me who starts from a complete blank slate and please be patient if any of my questions/thoughts sound ridiculously naive (its because they are..).
        Jasko_Jacker - my machine has a 800W top heater, a 1200W bottom heater and 2700W IR heating elements all around. Unfortunately it does not have any optical aliment, but i am hoping i can get around that with careful placement.
        Again - any help and tips are greatly appreciated! Also with regards to applying the solder paste on the motherboard - any clue?
        Lisa Su - The manual is amazing - i am shocked as it seems i am missing the curcial step of applying solder paste on the motherboard (!?!) I am so confused about this one because the socket comes with balls pre-applied; do the sockets that OEMs use not come pre-balled?
        It sort of makes sense to put solder paste on the board, but i am worried that could create blobs when the socket balls and solder paste both melt.
        The sockets I got look like this:
        Each pin is balled, but I did notice that the balls do look like to be barely sticking below the plastic ribs and was a bit worried they would not make contact - if i needed to bridge the gap with 0.5mm solder paste it would make a lot of sense 🤦‍♂️. I did a quick google search and found LGA 1700 stencils, but no AM5 ones.
        I liked the bit at the end about socket storage and handling - all the sockets I ordered came wrapped in tissue paper!
        At the moment i am on a technical break and can't experiment because while trying to tinker with a profile i set the rate of climb to 10C/s instead of 1C/s and this happened
        The bottom 1200W heater simply exploded (it was quite spectacular - large orange whoosh and sparks). I did manage to get it out of the machine after some ticnkering and ordered a (hopefully matching - at least the dimensions match so it shoudl fit + its the right wattage, but the coils look completely different which i am hoping does not matter as they have the same rating) replacement and now i am waiting for it to arrive from Aliexpress.
        • diif
          • Feb 2014
          • 6978
          • England
          No, don't use solder paste. You don't have the space.
          Watch this https://www.youtube.com/watch?v=Tal1Isw-HUQ
          • double_DD
            Transformer replacement for a dead coffee machine
            by double_DD
            Hi guys,
            I have a dead coffee machine, and it seems that the culprit (no 1, at least) is a dead trafo - primary coil seems to be blown open (type shown on the picture below).
            Now, I'm unable to find direct replacement anywhere on ebay or aliexpress, and all similar that I' was able to find are rated too low (<1A).
            If someone knows a shop to buy replacement (EU/CH), that would of course be my 1st option.
            My other ideas:
            - to buy 220/20Vac trafo with 30VA, and to "manually" create secondary 12V output just via resistor
            - to buy...
            06-23-2025, 05:43 AM
          • Fam787
            HELP! A1398 Dead,
            by Fam787
            I bought a second hand Mid 2014 A1398 MacBook Pro when I lived in Australia. I'd bought it as a back-up machine because I had a Mid 2014 MacBook Pro, and realising it might one day fail, I wanted a backup machine because I don't like change.
            Two weeks after buying MBP2, the seller called me to check if everything was OK with the unit, which I thought was odd. At that stage I might have turned it on a couple of times, but I'd not used it when he'd called. Over the last few years I used the machine seldomly because my original mac has been pretty OK. Every 3-6 months I'd charge it...
            12-27-2024, 05:19 PM
          • mrsdsdsdsd
            4G LTE router sim socket replacement
            by mrsdsdsdsd
            hi everyone i hope you all doing well.
            i'm trying to replace a sim socket in my 4g router, i found similar parts on aliexpress and i'm not sure if it will work on my device (Huawei b593s-22)
            here's the original one:
            and here's the links of the one i found on aliexpress:
            1-
            https://www.aliexpress.com/item/1005...yAdapt=glo2vnm
            2-
            https://www.aliexpress.com/item/4001...yAdapt=glo2vnm
            if anyone knows if it is possible to replace it with either one please let me know.
            thank you...
            06-02-2024, 12:49 PM
          • AJ847.63e
            LGA 1700 Socket Replacement Tips & Tricks
            by AJ847.63e
            Hi All,
            Just wanted to see if I can get some advice on techniques and equipment I should use to try replace the socket on a Gigabyte H610M h v2ddr4 I have.
            I was planning on using a heat mat I have that's used for phone, tablet screens, as a base heater than use hot air with a square nozzle on top. Yes I should get a proper preheater but I'm not in the position to go spend 300+ bucks on something I will use every 6 months if I'm lucky. Next expense I need to get is a decent programmer like the RT809H but again it would get used infrequently so hard to justify.
            07-24-2025, 06:57 PM
          • dicky96
            PCIe x16 socket replacement / desolder / rework
            by dicky96
            I sometimes see expensive motherboards sold spares/repair with damaged or burnt PCIe x16 sockets
            So I started to wonder, it is possible to de-solder the faulty socket and fit a replacement? At least for the non-armoured type
            To this end I thought I would try to desolder a PCIe 16x socket from a scrap board - without damaging the board. The thought was, if I can remove the old socket and clean out the through holes, then fitting a new one should not be a problem
            From googling - According to people responding to questions asking about doing this on computer/tech...
            04-14-2021, 04:06 PM
