Oscilloscope Selection - Hantek DSO2D15
  • FALKLAN
    Madman
    • Nov 2023
    • 14
    Howdy all!
    I'm a newb concerning electronics repair and I'm looking at a Hantek DSO2D15 oscilloscope. It's on sale for a good price IMO. I'm asking any feedback concerning this device and a few power supplies if anyone is willing the help an old tech.
    The Hantek seems like a decent machine for $175 new. I'm also looking at a 60v 24a power supply for $60. Sound like a good deal?
    • 31051
    Hantek are junk.
    save up and get the new 12bit Rigol DHO804
    https://www.eevblog.com/forum/testge...nbox-teardown/
    it's already been hacked from 70 to over 200MHz
    https://www.eevblog.com/forum/testge...o800900-scope/
    • Francesc V.
      Tempus fugit
      • Nov 2022
      • 231
      • Catalonia
      That junk you mention has 150Mhz 🤣
      If he is going to use it for repairing amplifiers and PSUs it's more than decent..............for other high frequency signals, there are better options.
      I own a FNIRSI 1014d and this is really junk..........it claims 100Mhz but average maybe it's 30Mhz. 🙄
        • 31051
        i had a hantek, the electronics are fine but the software in them is a joke.
        compare the trigger options in a Hantek to a Rigol or a Siglent
        and this is the first 12bit scope in the price range of average people too.
        if i didnt have a rigol DS1000z series i would have already ordered this new one.
        • FALKLAN
          Madman
          • Nov 2023
          • 14
          Thanks for the feedback! 👍
          Everything I get will be used for testing and checking automotive control module circuitry. I'm starting with automotive power distribution.
            • 31051
            well the DHO804 can be hacked to decode CANBUS
            but if you dont need that then you may be better off with a pocket scope from zeewei
            • FALKLAN
              Madman
              • Nov 2023
              • 14
              I'm working on a Mercedes and yes I will be working on the CANbus occasionally. I've been troubleshooting the Xenon headlamp power circuit. No voltage from the AAM to the EAM so that's where I'm working atm.
              The red lines are where the current stops and the green area has voltage throughout that area. I need a power supply for bench testing and that's why I requested some feedback on equipment. Testing that while it's in the vehicle is not fun because that module lives just beneath the engine compartment fuse box.
              Click image for larger version Name:	11.28.2023 AAM Xenon Circuit1080.jpg Views:	3 Size:	417.4 KB ID:	3156157
                • 31051
                good luck,
                car companies work really hard at making modules hard to repair
                • FALKLAN
                  Madman
                  • Nov 2023
                  • 14
                  This may not be a faulty circuit. I was studying about a specific DTC concerning the headlamp zero leveling and I have the same problem one person had a while back. He took some measurements, adjusted the front suspension to +1 inch lift to match the rear and poof! Fixed. WTF I'm going to take measurements tomorrow while installing a new a s-belt to see if there is a height difference.
                    • 31051
                    do you have acess to a STAR or some equivelent?
                    a lot of merc stuff is programmable
                    • FALKLAN
                      Madman
                      • Nov 2023
                      • 14
                      I use a 2023 Launch CRE for Benz and it does almost everything needed. I've programmed replacement used TCM, reset adaptation data and even learned new key fob transmitter with a tool that was a buck twenty. BTW resolving the out-of-spec leveling didn't resolve the headlight problem but I believe I know why and a few simple tests will confirm the theory.
                      Thanks for the feedback concerning my first scope purchase. I'm going to take that advice and get a Rigol DH0814.
                        • 31051
                        headlight leveling must be based on feedback from the suspension ride heights so maybe a sensor is dirty or worn
                        • FALKLAN
                          Madman
                          • Nov 2023
                          • 14
                          The front suspension -1" when compared to the rear so I increased it to match the rear. I d/c the rear sensor looking for corrosion or anything in the connector. Everything was clean and both front/rear sensors did respond to the adjustment. Still no low beams.
                          I was considering the DHO814 but since 804 can be hacked and decode CANbus comms, the 804 will suffice and be more than I'll ever need.
                          It's been a CANbus 101 weekend for me.
                            • 31051
                            the only difference between the 804, 814 and 824 is a software setting
                            the only differences between the 804 and the 900 series is the signal generator and logic analyser circuits - and a software setting
                            so an 804 becomes a 924 250MHz scope with canbus, just no sig-gen or logic analyser - or does it?
                            becausde the logic part is on the board - you potentially just need to add the socket!! this is being activly looked into.
                            go look at eevblog forums
                            • Sus256
                              HISENSE 65E7KQ PRO - no boot
                              by Sus256
                              Hi all!
                              HISENSE 65E7KQ PRO
                              RSAG7.820.13512 - chassis
                              MT9618BAATAB - cpu
                              RSAG7.820.12059 - power
                              HD650Y3U77 - panel
                              KLM8G1GETF - emmc
                              The TV does not turn on, the standby indicator is on. All voltages are present.
                              Emms is dead. Not readable, not detected.
                              Replaced emmc.
                              But with another dump there is no launch
                              Terminal log
                              UART
                              AC_ON
                              RPMB key is not yet programmed
                              HASH1_VERSION=0x00000000 64bit
                              E-B
                              FDE enabled
                              layout pattern onebin by SAR7,0...
                              06-01-2025, 02:11 AM
                            • Tarot Superstars
                              How not to Damage an Oscilloscope
                              by Tarot Superstars
                              Hello.
                              I have jut got my first analogue oscilloscope. An Isotech 620 20MHz.
                              I want to learn how not to damage it, and I found instructions on the internet obscure.
                              They talk about ground, earth, floating ground, this, that....
                              But they don't actually say anything anything useful so far.
                              I want to know:
                              Don't connect exactly this to exactly there or it blows up.
                              For example, I am tracing a signal from a function generator in an audio amp, or testing for voltages in different parts of a circuit.
                              I want to know what not to connect...
                              08-29-2023, 02:27 PM
                            • Evets
                              Dynamco analogue oscilloscope
                              by Evets
                              I have recently acquired a Dynamco D7100 analogue oscilloscope without a user manual. As this is the first time I have owned or used an oscilloscope I would like to try and find an instruction book. The manufacturers no longer hold any information and a Google search only found one site but when I downloaded a 'service manual' all I got was gobbledegook. Any help would be gratefully appreciated or even pointers to a generic manual where I could learn more.
                              08-30-2024, 06:54 AM
                            • SolomonMan
                              Vintage BK Precision 1403 Oscilloscope....
                              by SolomonMan
                              All,
                              Some of you have helped me in the past and I am very appreciative of all the help! (I have fixed TVs/Stereos/ and other small appliances with your efforts...Thanks so much!!!
                              Today I went to a local HAM Radio Festival. It was one of the smaller ones in our area. My stepfather is the HAM operator. I tinker in electronics but am a Software Programmer (27 years now).
                              I was looking for a few odds and ends for some electronics work I have to do for the household/farm. Typically these type of shows have the grab bags or a electronics vendor...
                              12-03-2023, 10:39 PM
                            • Bartoloni
                              Lenovo S145 -15iwl vcore inductor warm.. looking with oscilloscope there is a spike.
                              by Bartoloni
                              Hi, i have a Lenovo S145 that after 20 seconds shutdown and restart (it's working correctly on thse 20 seconds)
                              everything seems ok, but on Vcore inductor ( this is an i3 with just 1 switching power supply for CPU)
                              there is an output to teh CPU with a spike.. seems that inductor can't handle the input...
                              replaced the capacitor (330) and the inductor (R15) without any change
                              any idea? very thank you!
                              input of the inductor seems as usual... only strange thing is that the upper/lower voltages seems to be 21V (main power line is 19.3) ... but not sure this...
                              12-09-2024, 12:42 PM
