so I got a Sony Viao, I fixed once by keeping the heatsink off the southbridge for a few minutes. Its barely broken but I want to try to do a good reflow (she just texted me it won't come on again). What reflow flux do you suggest? just any ebay flux? Not sure if I want to go as far as reballing or not. I have a good heatgun, should I bother getting an actual hot air rework station? I'm sure I can reflow this with tin foil and my heatgun, but I want to use some flux
reflow flux and other shit
^If you have datasheets not listed PM meTags: None
Re: reflow flux and other shit
I've used MG Chemicals rosin liquid flux before (not entirely sure on details, though) and Kingbo gel-type RMA-218 flux. The Kingbo seems to work pretty well.
Genuine Amtech is supposed to be really really good. But most on eBay are fake. They will work too, but probably nowhere near as good.
In any case, any flux is probably better than no flux at all.
yeah I use MG chemicals paste flux for regular soldering. Too pasty to pour under the chip obviously.
I have an ir temp gun coming. I've been thinking about getting a rework station. Newegg has like two brands, and they all look pretty much the exact same casing, just with different wording outside. Whatya reccomend?
I've also seen these cheap, small IR rework stations, I can't find the damn links now, they have a single, small IR heater that more or less stays still, and I don't think does an immediate melt. they were like less than $100 bucks or soCap Datasheet Depot: http://www.paullinebarger.net/DS/
Originally posted by Uranium-235 View Postyeah I use MG chemicals paste flux for regular soldering. Too pasty to pour under the chip obviously.
Just line the edges of the chip you're trying to reflow with the paste flux and start heating the board. As the chip gets hotter and the flux starts "melting", the chip will suck the flux under it. I don't know what are the physics behind this for this to happen, but I know it works.
Unless I am mistaken, the stations I see on newegg are all of the hand-held hot air types. Not sure how easy it would be to do a reflow just with that or if it is even possible. If it's a small and very thin laptop motherboard - maybe. Anything bigger usually requires a little more heat flow (not necessarily hotter temperatures, but just bigger quantity of heat per unit of time).
If you have a heatgun, you can use that on the low setting to heat the board from the under side and then use hand-held hot air to heat the chip on top.
An alternative to the heatgun would be an electric stove. Just place the motherboard so that it is above the heating element on the stove (but not touching it), and when you hit around 150C, start using the hot air to heat the motherboard from the top.
If anything, one of the things you should definitely get before attempting any of that above is a type-K thermocouple. If you're willing to wait a little, you can get them on China-eBay as low as $5. The TM-902C is probably the most common one you'll see on there. They are inexpensive, but work pretty good and come with everything you need. The thermocouple probe they come with is a little bit big, so the temperature readings on the meter usually lag a little behind the actual temperature the probe is trying to measure. I know my friend has the smaller thermocouple probes, but I don't know where he got them from. They respond much quicker. But either way, a thermocouple would be very very helpful.
What you will want to avoid is heating up the board too quickly or overheating the chip - those will usually cause delamination, at which point the chip and/or board can be considered dead (whichever develops the delaminations, that is). Another cause for delamination is humidity. If the board has been staying in a fairly humid environment, I would recommend baking or heating the board to around 100C for at least 30 minutes. A few hours would be better, though.Last edited by momaka; 10-06-2013, 09:24 AM.
http://www.youtube.com/watch?v=VTAU647jzzk
fascinating. Seemingly tedious, but fascinating.Cap Datasheet Depot: http://www.paullinebarger.net/DS/
If he had the proper reballing stencils that extend all the way, this could have taken a lot shorted - at least for the reballing part. With those shims, you just pour the balls on the chip, move the entire thing back and forth a few times, then angle, and remove excess balls. About 2 minutes at the most to do. And those bigger reballing stencils are usually similarly priced to the ones he has too.
The lifting/flowing part isn't that hard. I've done RAM chip removal on a nVidia 7600GT on an electric stove top. Plenty of heat and if I had a proper hot air station with me at that time rather than a clumsy heatgun, it could probably have been even easier.
how did you know what chip it was?Cap Datasheet Depot: http://www.paullinebarger.net/DS/
For the 7600GT?
All 4 of the RAM chips were bad except for 1. Shorted Vdd to ground. Sacon FZ caps can obviously cause quite a bit of havok. The RAM Vdd was only filtered by one Sacon FZ cap, and when it went bad, the buck regulator circuit probably sent a huge voltage spike to the RAM.
Still don't know if that could have damaged the GPU chip as well. Resistances seemed okay with the RAM chips removed, though. So I am hopeful.
well I practiced on a bad GF 9400, heated under the chip to 100C, got foil, and cut the square for the chip, slowly got it to 220C...but i'm not sure I did it right. I'm not sure the flux got even under the chip, there was probably a few gaps. In the end, a small ball rolled out under the chip. Probably not a good sign. just guessing.
I have a few other bad laptop motherboards to mess with.
what it is is the MG chemicals rosin flux mentioned above, put in a syringe, and injected to one side of the chip, with the board leaning a little to let it move down, then putting it the next side and let it go down again
all I know is it takes only a few seconds for the flux to smoke into nothing. Should I have the foil block the air from getting under the chip?Cap Datasheet Depot: http://www.paullinebarger.net/DS/
Originally posted by Uranium-235 View Postwell I practiced on a bad GF 9400, heated under the chip to 100C, got foil, and cut the square for the chip, slowly got it to 220C...but i'm not sure I did it right.
Originally posted by Uranium-235 View PostI'm not sure the flux got even under the chip, there was probably a few gaps.
Originally posted by Uranium-235 View PostIn the end, a small ball rolled out under the chip. Probably not a good sign. just guessing.
Before doing that, though - did the board work? Or is it still dead?
Originally posted by Uranium-235 View PostI have a few other bad laptop motherboards to mess with.
Originally posted by Uranium-235 View Postall I know is it takes only a few seconds for the flux to smoke into nothing. Should I have the foil block the air from getting under the chip?
maybe that one wasn't suitable. I still have a DV 9000 given to me with pieces lost that i'm sure isn't leaded.
problem with not using foil, sometimes there are plastic connectors close enough to the NB to melt
I still haven't touched the sony yet
and yet the temp drops immediately afterCap Datasheet Depot: http://www.paullinebarger.net/DS/
well I got the motherboard out. There seems to be an electrolytic cap on it, it looks like a polymer casing but its got a vent. Probably 105 max. Not sure what I should do. Still cooking it at 100C is awful close to max, and its close enough to the chip to get hit by the gun
also, what is the melting point of all these plastic connectors?Cap Datasheet Depot: http://www.paullinebarger.net/DS/
helloo?Cap Datasheet Depot: http://www.paullinebarger.net/DS/
100C is quite safe as long as the oven doesn't go much over that. It takes a lot more to pop a cap. At 105C, you will just shorten the life of the cap by a small amount (probably too small to even matter in the useful lifetime of the laptop). I think 150C and over is where they may start to pressurize quite a bit.
If it's just that cap, you can try removing it for the reflow and then putting in back on after it. Normally when there are a lot of caps around, I just cover them with aluminum foil and/or aluminum tape, along with any large copper traces they are connected to on the bottom side.
For reballing some method need bake the board fisrt before lift and place back bga. If use ir rework machie this must do for remove bga moisture. Different with hot air rework machine no need bake the board. The airflie from hot air remove moisture bga and board. Agree ?
Cover the capacitor with aluminum foil if you're worried about it.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.
Originally posted by sasser View PostFor reballing some method need bake the board fisrt before lift and place back bga. If use ir rework machie this must do for remove bga moisture. Different with hot air rework machine no need bake the board. The airflie from hot air remove moisture bga and board. Agree ?
But again, I don't know. What do you think of that theory?
Also, for really small chips, I don't think it matters. I just removed 4 dead RAM chips from another E-VGA 7600 GT on the stove yesterday. With the hot air wand blowing on top of them for a few seconds, the slid off like butter. With bigger chips, you need more heat, so I can see how that can be a problem.
Originally posted by Th3_uN1Qu3Cover the capacitor with aluminum foil if you're worried about it.Last edited by momaka; 11-10-2013, 05:30 PM.
Originally posted by momaka View PostI don't know. My thinking is, regardless of whether you use IR or hot air, the board will be heated above 100C, and when that happens, moisture should evaporate all by itself (unless there is just too much).Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.
