reflow flux and other shit
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    so I got a Sony Viao, I fixed once by keeping the heatsink off the southbridge for a few minutes. Its barely broken but I want to try to do a good reflow (she just texted me it won't come on again). What reflow flux do you suggest? just any ebay flux? Not sure if I want to go as far as reballing or not. I have a good heatgun, should I bother getting an actual hot air rework station? I'm sure I can reflow this with tin foil and my heatgun, but I want to use some flux
  • speedypro
    • Feb 2013
    • 561
    Re: reflow flux and other shit
    Its best to reball; or remove any epoxy (glue) around the chip completely then reflow up to 220 degrees celsius. That works for me. If issue returns then you must reball.
    Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
      master hoarder
      • May 2008
      • 12164
      I've used MG Chemicals rosin liquid flux before (not entirely sure on details, though) and Kingbo gel-type RMA-218 flux. The Kingbo seems to work pretty well.
      Genuine Amtech is supposed to be really really good. But most on eBay are fake. They will work too, but probably nowhere near as good.
      In any case, any flux is probably better than no flux at all.
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        yeah I use MG chemicals paste flux for regular soldering. Too pasty to pour under the chip obviously.
        I have an ir temp gun coming. I've been thinking about getting a rework station. Newegg has like two brands, and they all look pretty much the exact same casing, just with different wording outside. Whatya reccomend?
        I've also seen these cheap, small IR rework stations, I can't find the damn links now, they have a single, small IR heater that more or less stays still, and I don't think does an immediate melt. they were like less than $100 bucks or so
          master hoarder
          • May 2008
          • 12164
          Not really.
          Just line the edges of the chip you're trying to reflow with the paste flux and start heating the board. As the chip gets hotter and the flux starts "melting", the chip will suck the flux under it. I don't know what are the physics behind this for this to happen, but I know it works.
          Unless I am mistaken, the stations I see on newegg are all of the hand-held hot air types. Not sure how easy it would be to do a reflow just with that or if it is even possible. If it's a small and very thin laptop motherboard - maybe. Anything bigger usually requires a little more heat flow (not necessarily hotter temperatures, but just bigger quantity of heat per unit of time).
          If you have a heatgun, you can use that on the low setting to heat the board from the under side and then use hand-held hot air to heat the chip on top.
          An alternative to the heatgun would be an electric stove. Just place the motherboard so that it is above the heating element on the stove (but not touching it), and when you hit around 150C, start using the hot air to heat the motherboard from the top.
          If anything, one of the things you should definitely get before attempting any of that above is a type-K thermocouple. If you're willing to wait a little, you can get them on China-eBay as low as $5. The TM-902C is probably the most common one you'll see on there. They are inexpensive, but work pretty good and come with everything you need. The thermocouple probe they come with is a little bit big, so the temperature readings on the meter usually lag a little behind the actual temperature the probe is trying to measure. I know my friend has the smaller thermocouple probes, but I don't know where he got them from. They respond much quicker. But either way, a thermocouple would be very very helpful.
          What you will want to avoid is heating up the board too quickly or overheating the chip - those will usually cause delamination, at which point the chip and/or board can be considered dead (whichever develops the delaminations, that is). Another cause for delamination is humidity. If the board has been staying in a fairly humid environment, I would recommend baking or heating the board to around 100C for at least 30 minutes. A few hours would be better, though.
          • Uranium-235
            Comrade Glimmer
            • Aug 2007
            • 5042
            • US
            http://www.youtube.com/watch?v=VTAU647jzzk
            fascinating. Seemingly tedious, but fascinating.
              master hoarder
              • May 2008
              • 12164
              If he had the proper reballing stencils that extend all the way, this could have taken a lot shorted - at least for the reballing part. With those shims, you just pour the balls on the chip, move the entire thing back and forth a few times, then angle, and remove excess balls. About 2 minutes at the most to do. And those bigger reballing stencils are usually similarly priced to the ones he has too.
              The lifting/flowing part isn't that hard. I've done RAM chip removal on a nVidia 7600GT on an electric stove top. Plenty of heat and if I had a proper hot air station with me at that time rather than a clumsy heatgun, it could probably have been even easier.
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5042
                • US
                how did you know what chip it was?
                  master hoarder
                  • May 2008
                  • 12164
                  For the 7600GT?
                  All 4 of the RAM chips were bad except for 1. Shorted Vdd to ground. Sacon FZ caps can obviously cause quite a bit of havok. The RAM Vdd was only filtered by one Sacon FZ cap, and when it went bad, the buck regulator circuit probably sent a huge voltage spike to the RAM.
                  Still don't know if that could have damaged the GPU chip as well. Resistances seemed okay with the RAM chips removed, though. So I am hopeful.
                  • Uranium-235
                    Comrade Glimmer
                    • Aug 2007
                    • 5042
                    • US
                    well I practiced on a bad GF 9400, heated under the chip to 100C, got foil, and cut the square for the chip, slowly got it to 220C...but i'm not sure I did it right. I'm not sure the flux got even under the chip, there was probably a few gaps. In the end, a small ball rolled out under the chip. Probably not a good sign. just guessing.
                    I have a few other bad laptop motherboards to mess with.
                    what it is is the MG chemicals rosin flux mentioned above, put in a syringe, and injected to one side of the chip, with the board leaning a little to let it move down, then putting it the next side and let it go down again
                    all I know is it takes only a few seconds for the flux to smoke into nothing. Should I have the foil block the air from getting under the chip?
                      master hoarder
                      • May 2008
                      • 12164
                      220C is a little low, especially with those hand-held hot air wands. If you move the wand away from the chip, did the temperature stay at 220C or did it drop a few degrees immediately? If it drops, it means you need higher heat flow (i.e. more air moving at the same temperature). Having some type of bottom heater for the board is crucial. Also, try going for 225-230C. Do not go over 240C, though, because around 250C you'll cook the chip. Also, you don't really need to put foil around the chip - in fact, I advise against doing so unless you have electrolytic capacitors that will get popped from the heat. Not having the foil allows the board to heat more evenly.
                      When you heated the chip, did you see the flux melt? If yes, it probably went under.
                      I've never seen that happen before. I'm not even sure if the balls can get detached (and if so, how). I guess lifting the chip will confirm it. If you do it really carefully, you'll be able to do a clean lift (i.e. the balls won't clump to each other).
                      Before doing that, though - did the board work? Or is it still dead?
                      If the 9400 board is still dead, and you think you messed it up even more, then keep practicing on it. This will get you more experienced for the other boards.
                      Interesting. My MG Chemicals liquid flux also evaporates fairly quickly. I've done reflows with it, but only on leaded boards where the temperature was much lower (200C tops). Perhaps yours isn't suitable for reflow either.
                      • Uranium-235
                        Comrade Glimmer
                        • Aug 2007
                        • 5042
                        • US
                        maybe that one wasn't suitable. I still have a DV 9000 given to me with pieces lost that i'm sure isn't leaded.
                        problem with not using foil, sometimes there are plastic connectors close enough to the NB to melt
                        I still haven't touched the sony yet
                        and yet the temp drops immediately after
                        • Uranium-235
                          Comrade Glimmer
                          • Aug 2007
                          • 5042
                          • US
                          well I got the motherboard out. There seems to be an electrolytic cap on it, it looks like a polymer casing but its got a vent. Probably 105 max. Not sure what I should do. Still cooking it at 100C is awful close to max, and its close enough to the chip to get hit by the gun
                          also, what is the melting point of all these plastic connectors?
                          • Uranium-235
                            Comrade Glimmer
                            • Aug 2007
                            • 5042
                            • US
                            helloo?
                              master hoarder
                              • May 2008
                              • 12164
                              100C is quite safe as long as the oven doesn't go much over that. It takes a lot more to pop a cap. At 105C, you will just shorten the life of the cap by a small amount (probably too small to even matter in the useful lifetime of the laptop). I think 150C and over is where they may start to pressurize quite a bit.
                              If it's just that cap, you can try removing it for the reflow and then putting in back on after it. Normally when there are a lot of caps around, I just cover them with aluminum foil and/or aluminum tape, along with any large copper traces they are connected to on the bottom side.
                              • sasser
                                • Dec 2012
                                • 364
                                • Malaysia
                                For reballing some method need bake the board fisrt before lift and place back bga. If use ir rework machie this must do for remove bga moisture. Different with hot air rework machine no need bake the board. The airflie from hot air remove moisture bga and board. Agree ?
                                • Th3_uN1Qu3
                                  Believe in
                                  • Jul 2010
                                  • 6031
                                  Cover the capacitor with aluminum foil if you're worried about it.
                                  A working TV? How boring!
                                    master hoarder
                                    • May 2008
                                    • 12164
                                    I don't know. My thinking is, regardless of whether you use IR or hot air, the board will be heated above 100C, and when that happens, moisture should evaporate all by itself (unless there is just too much).
                                    But again, I don't know. What do you think of that theory?
                                    Also, for really small chips, I don't think it matters. I just removed 4 dead RAM chips from another E-VGA 7600 GT on the stove yesterday. With the hot air wand blowing on top of them for a few seconds, the slid off like butter. With bigger chips, you need more heat, so I can see how that can be a problem.
                                    Yes, but don't squish the aluminum foil tightly on them. In fact, don't squish it at all. Just cover so it deflects hot air and heat out of the way.
                                    • Th3_uN1Qu3
                                      Believe in
                                      • Jul 2010
                                      • 6031
                                      If there's any significant moisture in it, heat it up too quickly and it will go POP... That's why it is recommended to "bake" boards and chips that have been stored in unknown conditions before attempting a reflow or reball.
                                        master hoarder
                                        • May 2008
                                        • 12164
                                        ^Yes, I've seen it happen too on some boards I worked on. The state I am in, Virginia, it is quite humid in the Summer.
                                        But my question was, why would hot air not do that vs. IR?
                                        • chth96
                                          Is it good to use chemistronic flux off es835b for flux remover?
                                          by chth96
                                          I want to purchase any good flux remover But "chemistronic flux off es835b" is the most common flux remover in my nation..
                                          Or I have to purchase "3m novec flux remover" which is quite expensive in my nation?
                                          11-17-2023, 07:25 AM
                                        • tony359
                                          Reflow equipment
                                          by tony359
                                          Hello all,
                                          I am experimenting a bit with reflowing larger components - ideally I'd like to reflow a PS4 APU or a GPU for example.
                                          I know it's impossible to reflow such large components with just hot air so I bought a pre-heating plate, T-8280 classic Chinese machine, which seems to be working fine besides it's a little slow, which shouldn't be a big deal.
                                          Now, my hot air station is a Aoyue 852A++ and I feel it's a bit weak when used with larger nozzle. I tried reflowing a laptop chipset using one of those large, rectangular, nozzles and I failed miserably,...
                                          12-25-2021, 01:29 PM
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
                                        • evilkitty
                                          Flux causing high resistance short?
                                          by evilkitty
                                          Now that my de-soldering gun is working i was able to remove this panel i made about a week before i noticed a issue the F segment of digits 2 and 3 would go out, digit 2 would go before digit 3, but would come back after the humidity got down from running the ac (note the weather outside is 30.5 / 74%; panel data is from a BME280)
                                          Temp is on the left humidity is on the right
                                          i noticed when the humidity got up one or 2 of the center digits on the right panel would loose a segment
                                          The pin out looking down from the top is (note this is common cathode)...
                                          07-17-2024, 09:38 AM
                                          Multifix 425-01 and 450-01 Rework Flux Datasheet
                                          REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                                          - No Clean Formulations
                                          - Low residue
                                          - Range of activity to deal with different component solderability
                                          - Halide free
                                          - Suitable for dispensing
                                          - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                                          Both products are supplied in syringes or cartridges for application by dispensing....
                                          10-07-2024, 06:02 AM
