Oscilloscope: Which one should I choose?
  • LDSisHere
    • May 2012
    • 727
    • U.S.A.
    I have been wanting to get an oscilloscope for a long time but I have now come to the point where I need one. Since money is an object I do not want to spend any more of than necessary but I want to get something that I can depend on when I need it.
    At first I was looking at old used Teks on Ebay but I have enough stuff to repair as it is so I decided my best bet would be to get a new one with a warranty.
    I have narrowed my choices down to two models although I am still open to suggestions. My initial choice was the Rigol DS1102E for $399. I am now leaning toward the Owon SDS7102 at $429. I am leaning toward the Owon for several reasons: Screen size and resolution, memory depth, and the fact it can operate on battery power. I know this model had problems in the past but it is my understanding that most of these issues have been resolved since its' introduction.
    Before I go spending this kind of money on a piece of equipment, I wanted to get some input on what I should buy.
    Thanks.
  • Kiriakos GR
    Banned
    • May 2012
    • 940
    • Greece
    Re: Oscilloscope: Which one should I choose?
    The DS1102E is near to it end of life as model & the Owon is equally outdated and with poor reputation.
    If your budget can not pass the 500$ mark, then close your eyes and get what ever has the lesser shipping cost to your end.
    • MDOC
      EngineeringTech
      • Mar 2010
      • 146
      I haven't developed an opinion on either/or, but I've seen both the Rigol and Owon reviews and at first didn't like the Owon much.
      For Rigol, end of life doesn't mean anything because there will still be repair support even if not at Rigol locations. End of life just means no longer supported by the manufacturer.
      If you get one from Saelig, both the Rigol and Owon have free shipping, free carry case, and 5% educational discount. Carries a 3-year warranty, too.
      But, having also seen the Rigol review, I can see why you'd go for the Owon instead. So I'd go for the Owon, mostly because of the higher sampling rate and battery operation. The Owon review showed a blank space where the Ethernet port option would be, but at Saelig, that is included at no additional cost, along with the USB and VGA ports.
      • LDSisHere
        • May 2012
        • 727
        • U.S.A.
        Thanks for responding.
        Saelig was the site where I was looking to buy from if I get one of these two models. At first I did not like the Owon either from the reviews but then I realized they were from a few years ago and some of the newer ones talk about them being much improved. I also read that the newer SDS7102's are actually good for up to 150 to 200Mhz even if they are only rated for 100Mhz. I am not sure how true that is but it would be a great bonus if it is true. I think the bigger, better screen is one of the big selling points for me. I was not planning on spending more than $400 and that is really pushing it for me, but since it is only $30 more I am not going to let that be a deal breaker. If I get this one, I will just have to get a battery later when the wife is not looking as she thinks this "toy" is too expensive as it is.
        I think if I went for the Rigol I would just get the DS1052E and mod it into a 100Mhz model. Saelig, however no longer carries the DS1052E and moding it would cause me problems if I needed warranty work done.
        It is my understanding that at this price point any choice is a compromises but from my point of view it will be better than nothing and it should do all I need for a few years while I figure out how to use it properly.
        • japlytic
          • Oct 2005
          • 2086
          Generally, it depends what application you want to use it for.
          Notably, I found that many of the Chinese brand units have FFT as standard.
          Rigol and Owon (as mentioned earlier) are on my list of respectable Chinese brands.
          • MDOC
            EngineeringTech
            • Mar 2010
            • 146
            Well, look at it this way: back in my day, scopes (Tek scopes) cost thousands if not tens of thousands. This one is cheap.
            • Kiriakos GR
              Banned
              • May 2012
              • 940
              • Greece
              Even if Saelig is an respectable retailer which we do communicate from time to time due Tweeter, the latest Owon scopes comes with significant signs of imperfection.
              My view on the subject will be to move on the 1000$ price tag of the true modern scopes like the GDS-2000A.
              If you insist to get today an low badged and outdated scope, you will not even get some money back if you try to resale it after two years, so to get a better one.
              http://www.eevblog.com/forum/testgea...seen#msg230797
              • LDSisHere
                • May 2012
                • 727
                • U.S.A.
                I think new Tek scopes are still priced in this range which is why I cannot consider getting one. I was looking at old ones on Ebay before I decided I would rather have a new DSO if I could find a decent one cheap enough.
                If I was willing to spend $1000+ dollars on a a scope my list of choices would have reflected scopes in that price range. However if you are willing to donate $600+ dollars toward me getting a scope that will meet your approval I will definitely put it to good use.
                I had been reading a lot of the threads on EEVblog forum about the Owon including the one you linked. However I had not seen the recent post from yesterday morning from a guy that bought an Owon from Saelig last week. I had thought the ground noise issue had been fixed but it is apparently still a problem. So instead of buying the Owon today like I had been thinking of doing, I emailed Saelig about the ground noise problem with a link to the thread you posted. I am curious as to their response, if they do actually respond. Their response or lack thereof will determine if I back up and reevaluate my options in both product and/or retailer.
                • Kiriakos GR
                  Banned
                  • May 2012
                  • 940
                  • Greece
                  When you are a millionaire industrial electrician like me, naturally the cost is not an issue.
                  But I will say that me and some thousands others we did pass from the roads that you are right now, and our final selection was made by the stronger argument of all times.
                  Which is : Fresh , Fast , Reliable , Affordable, Lots of active warranty time.
                  I will totally agree with you, that you can not buy that with 400$, but nothing stopping you, from setting a target today, and start savings so to get a nice scope that you will grow with it.
                  From the other hand nothing stopping you from getting a used DS1102E on eBay, with some luck you will hit a bargain for much less than 400$.
                  As you can see I have use an DS1102E, it is good for educational purposes,
                  but when it comes to repairs and troubleshooting it does not deliver the power so to see on the screen the unknown with it.
                  It is a very different concept to expect to see and measure a given waveform at a specific test point when the repair manual informs you about it.
                  And a totally different one to actually use the scope so to evaluate the quality and the form of the waveform, plus fast glitches and measurements that their accuracy are acceptable in the range of DSO scopes.
                  FYI the latest GDS-2000A and RIGOL DS2000 they called as third generation of DSO and they did pop-up in the market just few months ago.
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    Any scopes at the local pawn shop?
                    --- begin sig file ---
                    --- end sig file ---
                    • LDSisHere
                      • May 2012
                      • 727
                      • U.S.A.
                      No, I have never seen one at a pawn shop. I have only seen a handful on Craigslist in the past year and they were either way over priced and/or look to be from the 40's or 50's. They seem to be scarce in my part of the country. Most people I know have never even heard of one and will look at you like an alien form outer space if you mention buying one.
                      I have not seen many Flukes at the pawn shops lately either and if I do they are not there for very long.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        Do you have a local hamfest or electronics club? Some of the members are likely to have a scope which might be for sale?
                        • LDSisHere
                          • May 2012
                          • 727
                          • U.S.A.
                          I do not know of anything like this in my area, not saying there isn't one.
                          I did hear back from Saleig and I was impressed with the depth and effort they put into the response. I sent a follow up question but I have not gotten a response on that one. I am ready to go for the Owon, but I want to make sure it is capable of at least doing the following:
                          1. Check and adjust the waveforms on plasma TV sets
                          2. Check waveforms of the clock and data output of a parallel port driven C2 (no not I2C) programmer
                          3. Check the output ripple of ATX power supplies which is supposed to be less than 50mV 10 - 20 Mhz on most rails.
                          I think it should be capable of all the above with no problems but I want to make sure before I spend my money.
                          • Kiriakos GR
                            Banned
                            • May 2012
                            • 940
                            • Greece
                            @LDS I think that you are a bit lucky, this video is very fresh and talks about the needs of modern PSU in the regard of measurements by an Oscilloscope.
                            http://www.youtube.com/watch?v=S6WTqGUo1xU
                            Forget the fact that is 60% technical video + 40% advertising, and focus your attention in the details regarding measurements.
                            By the way regarding dedicated software on the scopes about measurements on pulsing PSU's are always an extra option at the expensive scopes.
                            For Example GW Instek has such a software package for their GDS-3000 scopes, but they do not look to offer it for the GDS-2000A.
                            At about the 90% of the above video comes in the game the information that just the scope probes are not enough for such measurements, and an additional amount of 400-600$ for an active & isolated (AC phase /mains) voltage probe is a must have.
                            Bottom line other than the cost of ownership for a scope, there is a need for additional gear about it as probes, which comes close to 1000$.
                            Additional tips about Switching Mode PSU, by GW Instek you can find here.
                            http://www.ittsb.eu/forum/index.php?topic=426.0
                            • LDSisHere
                              • May 2012
                              • 727
                              • U.S.A.
                              Well I went ahead and bought the Owon SDS7102 yesterday, it is supposed to arrive tomorrow. Salieg really impressed me with their responses, you do not find that kind of service very often these days.
                              Kiriankos, I have not had a chance to watch the videos you linked but I intend to do so soon.
                              • Kiriakos GR
                                Banned
                                • May 2012
                                • 940
                                • Greece
                                Every new scope will open the door to you so to explore a new world. :-)
                                Congrats for getting one!
                                Tip of the day: Invest couple months so to learn how to use it.
                                This is what I do too. ;-)
                                • danro
                                  Owon HDS2202S oscilloscope
                                  by danro
                                  I have this OWON HDS2202S oscilloscope that worked fine until it was used with the wrong probes mounted in the wrong place.
                                  It is not completely dead, it still fulfills some functions. I opened it and found some damaged components inside. I have identified the rest but I cannot identify this IC. I don't think I can find the diagram, but can someone help me identify this component?
                                  It seems to be an LDO regulator. I identified it like this:
                                  Pin1 - Vin
                                  Pin2 - GND
                                  Pin3 - ? (connected with pin1)
                                  Pin4 - ADJ ? (resistive divider between Vout and...
                                  07-25-2024, 10:46 AM
                                • irnard
                                  Micro SMD probe tip for Rigol oscilloscope ?
                                  by irnard
                                  Any advice where can I find micro SMD probe tip for Rigol oscilloscope ? Can't find anything online and factory one is just too fat to fit in some tight spaces on logic board. Thx
                                  02-09-2023, 09:22 AM
                                • Tarot Superstars
                                  How not to Damage an Oscilloscope
                                  by Tarot Superstars
                                  Hello.
                                  I have jut got my first analogue oscilloscope. An Isotech 620 20MHz.
                                  I want to learn how not to damage it, and I found instructions on the internet obscure.
                                  They talk about ground, earth, floating ground, this, that....
                                  But they don't actually say anything anything useful so far.
                                  I want to know:
                                  Don't connect exactly this to exactly there or it blows up.
                                  For example, I am tracing a signal from a function generator in an audio amp, or testing for voltages in different parts of a circuit.
                                  I want to know what not to connect...
                                  08-29-2023, 02:27 PM
                                • Evets
                                  Dynamco analogue oscilloscope
                                  by Evets
                                  I have recently acquired a Dynamco D7100 analogue oscilloscope without a user manual. As this is the first time I have owned or used an oscilloscope I would like to try and find an instruction book. The manufacturers no longer hold any information and a Google search only found one site but when I downloaded a 'service manual' all I got was gobbledegook. Any help would be gratefully appreciated or even pointers to a generic manual where I could learn more.
                                  08-30-2024, 06:54 AM
                                • Bartoloni
                                  Lenovo S145 -15iwl vcore inductor warm.. looking with oscilloscope there is a spike.
                                  by Bartoloni
                                  Hi, i have a Lenovo S145 that after 20 seconds shutdown and restart (it's working correctly on thse 20 seconds)
                                  everything seems ok, but on Vcore inductor ( this is an i3 with just 1 switching power supply for CPU)
                                  there is an output to teh CPU with a spike.. seems that inductor can't handle the input...
                                  replaced the capacitor (330) and the inductor (R15) without any change
                                  any idea? very thank you!
                                  input of the inductor seems as usual... only strange thing is that the upper/lower voltages seems to be 21V (main power line is 19.3) ... but not sure this...
                                  12-09-2024, 12:42 PM
