Beckman Industrial 320B
  • smason
    • 1652
    Re: Beckman Industrial 320B
    I used to have a Beckman, can't remember the model, is had pushbuttons along the left side instead of a rotary switch.
    Love the Micronta. I have 2 of those
    • DavidOH
      • May 2012
      • 105
      Well I got the Beckman to work the way it should. The fix was to remove the strips and reset them. I don't know how many times it took. The last time the numbers were there but jumpimg just a little. So I smacked the side of it on my hand. It stopped and now the readings are what they should be. ACV on the outlet is 120 +/-. Note to self and others. What those darn zebra strips.
      • modemhead
        Lurking
        • 52
        Glad you got it sorted!
        I forgot to post this but I looked through the 300/310/330 document posted above and it shows that the AC converter is built-in to the processor chip, so it makes sense that the zebra strips could screw up the AC readings.
        I have two Beckmans and a Wavetek with this design and I have noted that all of them will respond to physical shocks more than other brands/types. But they are accurate if not shaken (or stirred) while measuring.
        I definitely hesitated to post the last-ditch idea I had in the back of my head, which was to slit those strips with a very sharp blade and insert shim strips to fatten them up.
        • retiredcaps
          • Apr 2010
          • 9271
          This particular multimeter sounds destined to be a "bench" multimeter never to be moved or used outside or in a toolbox.
          Good job on the repair.
          --- begin sig file ---
          --- end sig file ---
          • DavidOH
            • May 2012
            • 105
            I just squeezed them with my fingers. I had another z-strip from a non-working sperry meter I forgot I had. I think cutting the strip would have worked if I'd taken more time to think about how to cut it to size only one time. My first cut was too big and triming it was not good. So I'll save that fix should I have to do it again.
            • retiredcaps
              • Apr 2010
              • 9271
              #26
              If you are interested in potentially getting it fixed, start a new thread for the Sperry multimeter.
              • DavidOH
                • May 2012
                • 105
                The Sperry was a cheap one that was given to me. It wasn't working and is now spare parts.
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #28
                  Nowadays, I'm more interested and motivated in spending my time and effort fixing even the cheapest multimeter rather than the most expensive TV.
                  • Kiriakos GR
                    Banned
                    • May 2012
                    • 940
                    • Greece
                    #29
                    I am a sentimental in a way too, but I prefer to go fishing, instead dealing with items of such quality ( example bellow).
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      #30
                      Still want an auto range one. Oh well I needed a hobby.
                      I have a Fluke 117 and the 115 is identical minus the non contact voltage detector and loZ.
                      If you can get it for $51.15 + $7 s/h and don't mind the missing rubber holster, I think it will suffice for badcaps troublehsooting purposes.
                      http://www.ebay.com/itm/181070316858
                      The most obvious missing feature is the mA/uA range, but we rarely require current measurement on this forum.
                      Alternatively, you can try and be patient and get a Fluke 83 in the $50 price range.
                      PS. I have no financial affiliation with the seller and I cannot vouch that it is a working multimeter, so do your own due diligence.
                      • DavidOH
                        • May 2012
                        • 105
                        I bought a Fluke 115 today. SearsOutlet website listed a 115 at a store 20 miles from me over the weekend for $63.93. Said it was a floor model. Work gave me today off so I looked to see if it was still there. It was and now listed for $47.93. Got there and they had one unopened one hanging. After asking it turns out that was it. So $51.05 out the door. Don't need the detector, but it does do the loZ.
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          #32
                          I bought a Fluke 115 today. So $51.05 out the door.
                          Excellent deal for a new 115.
                          Congratulations.
                          Better than the ebay auction I listed even though it went for $45.
                          Sears Canada are closing many of their stores, but I don't think my Sears sells any multimeters?
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            #33
                            BTW, in theory, your Fluke 115 should be calibrated since it is new from the factory.
                            You can use the 115 to compare with the Beckman and see if DC volts is within spec like this thread
                            https://www.badcaps.net/forum/showthread.php?t=24239
                            • kc8adu
                              • Nov 2003
                              • 8832
                              • U.S.A!
                              #34
                              if anyone has a beckman that has a good case but bad internals pm me.
                              my case is shot.i think mine is more ca and epoxy now than original plastic.
                              • DavidOH
                                • May 2012
                                • 105
                                Checking a 9v and AA the Beckman is pretty much dead on.
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  #36
                                  I have been buying a few 20+ year old reputable name brand multimeters and I'm continually amazed at how long and well they hold their calibration.
                                  Many of the ones I buy are beat-up with no history of calibration but they are usually within 1 to 2 mV compared to my newer multimeters in the DC voltage range.
                                    Kinda makes me wonder if yearly calibration is a bit of a con.
                                    • redwire
                                      • 3908
                                      A single trimpot - that's it for calibration. I think the Beck's are laser-trimmed and I've never seen any drift... unless the input resistor is smoked (500V on the 0.2V range). Oops.
                                      • DavidOH
                                        • May 2012
                                        • 105
                                        Is there a way to make the beep louder on the 115? I know my hearing isn't what it use to be. I hear the Beckman just fine but the 115 can't be heard a foot away.
                                        • retiredcaps
                                          • Apr 2010
                                          • 9271
                                          #40
                                          Not that I know of. A fresh 9V battery might make a slight difference?
                                          I just got an old Simpson 467 digital multimeter and the beeper almost sounds like a fire alarm going off. It is too loud for my tastes. However, the continuity is really fast. Really fast.
                                          It is also within spec too.
                                          • mholin
                                            Beckman Industrial/(later Wavetek) Digital Multimeter DM27XT Repair
                                            by mholin
                                            Was testing to see if a bug zapper grid voltage (=< 2800VDC) had discharged yet. Set meter to highest range (1000 VDC) and probed across the grid. Heard an audible arc so voltage must have discharged into something in the front end of the meter. Now all functions that use the V-Ohm/Com input just reads "OL" (over range). Even the continuity test with the probes shorted reads OL with no beep. Opened it up and found input resistor R31 47 ohms, completely open. Replaced with new resistor but meter still reads "OL". The low battery icon on the display is visible even...
                                            08-18-2024, 12:58 PM
                                          • I8jjrnhh4thvtl0dWZoY
                                            Repair Manual for Bosch SHX55M05UC/46 Dishwasher (702_58300000148618_ara_en_a)
                                            by I8jjrnhh4thvtl0dWZoY
                                            Repair manual part number 702_58300000148618_ara_en_a
                                            It took way too much effort to find this manual so I am sharing it here so the next person can find it easily. Also, I am mad at Bosch for not publishing it on their website, so they deserve to have it leaked....
                                            07-14-2025, 07:36 PM
                                            STM32F103C8, STM32F103R8, STM32F103V8, STM32F103T8, STM32F103RB, STM32F103VB, STM32F103CB, STM32F103TB Datasheet
                                            The STM32F103C8, STM32F103R8, STM32F103V8, STM32F103T8, STM32F103RB, STM32F103VB, STM32F103CB, STM32F103TB medium-density performance line family incorporates the high-performance Arm Cortex-M3 32-bit RISC core operating at a 72 MHz frequency, high-speed embedded memories (Flash memory up to 128 Kbytes and SRAM up to 20 Kbytes), and an extensive range of enhanced I/Os and peripherals connected to two APB buses. All devices offer two 12-bit ADCs, three general purpose 16-bit timers plus one PWM timer, as well as standard and advanced communication interfaces: up to two I2Cs and SPIs, three USARTs,...
                                            10-07-2024, 04:40 AM
                                          • abhorsen
                                            Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
                                            by abhorsen
                                            Hey guys,
                                            Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
                                            Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
                                            Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
                                            07-06-2023, 10:22 AM
                                            Postcard 32 4-Bit 4-Digit Diagnostic Card PC Analyzer Manual
                                            Diagnostic Card is a powerful diagnostic tool for technicians and administrators to troubleshoot
                                            various problems of IBM compatible PCs. It is easy to install, yet extremely powerful to use. With
                                            Diagnostic Card in hand, you no longer have to go through tedious and time consuming process of
                                            trying to figure out what is wrong with your PC hardware. Diagnostic Card will tell you exactly
                                            what is wrong with your PC in just seconds. It saves you time and money.
                                            Our new and improved design...
                                            11-01-2024, 06:29 AM
