newbie needs help
  • knotman
    • Aug 2006
    • 6
    newbie needs help
    i recently blew out a cap on my vid card and i found the same exact one on an old mother board my problem is that i took a pic to make sure of the pos. and neg. sides now the side i thought for sure was the neg. has what looks like a pos. sign next to it i just want to make sure that it is the neg. side before i do more dammage or any damage to the motherboard
    here is a pic of the card
    http://img243.*************/img243/3228/dscn1369pk8.jpg
    in the white area it looks like it has the pos.sign but if you look at the cap on top it is sitting the same way and it is neg.
    any help would be greatful
  • knotman
    • Aug 2006
    • 6
    Re: newbie needs help
    fixed the img code.
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      is it an asus video card?
      what about the other caps, how are they aligned? show another pic of some other caps.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        the white area denotes the - of a thruhole part.the+ you see is for a sm part.board can use either.
        an exception is asus.
        they mark thiers ass backwards from eveyone else.
        • knotman
          • Aug 2006
          • 6
          nah its a cheapie mx 400 gforce 2 agp the only other cap going the same way is the one on top this is why i think the neg. is on the bottom
          • knotman
            • Aug 2006
            • 6
            so i am right then ??? the bottom is the neg.
            • knotman
              • Aug 2006
              • 6
              i tried to use an ohm meter to see where i would get the reading
              i grounded one wire and touched the holes and got a reading on both witch im thinking that the pos. side would not give me a reading
              • knotman
                • Aug 2006
                • 6
                i do believe that it worked
                i will know if or when the puter freezes up that is what happened last time the puter keep freezing up and after an extensive search i found the cap on the vid card popped but now it is back in and working
                way kool!!!!!
                • Spacedye69
                  • Nov 2005
                  • 698
                  • US
                  Congrats! Nothing like resurrecting dead components.
                  • tranquility
                    newbie needs capacitor sizes. HP Spectre X360. schematic maybe available
                    by tranquility
                    hello, i am very new to laptop repair and generell electronics
                    i have a HP Spectre X360 Convertible 13 - ap0016ng
                    motherboard number DA0X36MBAE0 REV E
                    massive burned and shortet mosfets. after removing them still shortet in the i think "main power rail"
                    found a shorted capacitor. removed it and the short is gone.
                    i want to try a crazy repair which is hard because the mosfets are like welded on one side to the track. is there a method to get this loose ?
                    in this area another capacitor was shortet.
                    12-06-2024, 04:12 AM
                  • UL161
                    Need Help Identifying Parts on a crossover and a few other newbie questions
                    by UL161
                    Hi I am trying to refurbish this crossover with some higher quality poly-caps/parts... The speaker is a in-wall Polk 65-RT... Key questions I have are:
                    1) What in the world is the yellow part on the board (label is MET 1.0J 100V)?... Should I even consider replacing it?
                    2) The 470uF cap.... Does anyone know have a suggestion as to where I can find a reasonable audio quality polycap near that value? (or at least 3 160s or the like?) { I don't want to spend $70 just to replace this one if I can) (maybe even someone looking at this circuit could even tell if this cap is important...
                    09-29-2024, 03:17 PM
                  • cloghin
                    newbie questions
                    by cloghin
                    Apologies if I am asking the wrong questions , but not sure how else to start:
                    I have an A2251 / 820-01949 Mac book pro with no power, 20 v on USBC meter and 0.05 Amps. Following this link ( below)
                    * Do I need to remove the board from case so I can access its other side ? The link calls for measuring PP3v3_S5 ( I suppose this is in diode mode with positive probe on ground) , but I don't know how to do that without removing the board from case.
                    * I have the FlexBV board , are the values displayed in volts diode mode only ? Because my etekcity multimeter shows...
                    09-26-2024, 11:48 AM
                  • Cappy Oligan
                    Newbie about to dive in with the leads. Safety advice please.
                    by Cappy Oligan
                    I'm new to electronic repair. Trying to troubleshoot a Dell monitor that only has an AC port for power. I'm concerned about safety and not getting shocked. Should I order an isolation transformer and plug in the monitor into that and proceed with testing the board inside? Or should I get a DC power supply and limit the amps and connect the voltage to a pin somewhere inside where 19V DC is first expected? Or both? Thanks.
                    08-30-2024, 05:40 PM
                  • Jofo
                    eVGA GTX 970 - newbie fixing
                    by Jofo
                    I am a newbie and this is my first repair attempt on eVGA GTX 970 that I bought from one guy. He said that his power supply died and took the graphics card with it and smelled smoke from the card too. When I took the card apart, one of the high-side MOSFETs was obviously damaged and there was a short on one of the PCIe connectors.
                    The situation now is as follows:
                    - The choke was already damaged when I disassembled the card
                    - I've desoldered the high-side MOSFET "H" that was damaged, short gone...
                    09-29-2022, 03:22 AM
