anyone use this esr meter?
  • Bonjing
    • Nov 2006
    anyone use this esr meter ?
    http://www.ebay.com/itm/In-circuit-C...ht_1360wt_1343
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: anyone use this esr meter?
    no not that one but i am thinking of getting this
    capacitor and esr
    http://www.ebay.co.uk/itm/3208623148...84.m1438.l2649
    • mariushm
      • May 2011
      • 3799
      The first is probably a clone of Bob Parker's ESR meter, made from his article from Silicon Chips magazine.
      The second one is good - but you might wanna PM RusMike (https://www.badcaps.net/forum/member.php?u=12802) and buy it directly from the source instead of a third party from eBay. That's also an older version of the meter - he might be able to sell you the latest version for a similar price.
      • chth96
        by chth96
        03-09-2024, 10:03 PM
        12-31-2023, 06:04 AM
      • jorpec
        by jorpec
        Hi
        Thnaks
        01-23-2023, 10:37 AM
        Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
        12-14-2023, 07:45 PM
      • Stephan Mathers
        EDMI ATLAS MK10 Electronic Meter Discussion
        by Stephan Mathers
        Greetings, new guy here but always interested in the crazy universe of modding
        We just finished construction of around 25 vacation houses, all inside the same private area.
        Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
        The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
        Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
        05-20-2025, 09:09 AM
