For people that wants to build their own meter
DIY Ringer tester info
http://www.badcaps.net/forum/showthread.php?t=24809Tags: None -
Re: DIY Ringer tester info
I have SENCORE 75, but I may build it since it is so much more portable than my SENCORE. I will make the PCB layout for it first since I have the diagram now. But then again, you can buy it for about $60.Never stop learning
by LifeisfunHi folks!
I have some kind of memory problem on Lenovo laptop. I was initially able to install windows after several tries since the laptop did freeze in middle of those attempts.
Eventually I discovered that it was related to moving the laptop.
Later on it even stopped booting unless I pressed around the memory slot. (no keyboard LEDs only power button responds)
If I remove the RAM I get the beeps that RAM is missing. Inserting the RAM there is silence and it will not boot most of the time. No picture.
I removed the board got one of those memory slot testers... -
Hi friends
I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board... -
by sam_sam_samhttps://www.ebay.com/itm/405035016711
I got this device yesterday and did some testing on some tabbing and some incandescent light bulbs and it seems to work very well from what I can tell but how do I know how accurate the m-ohms section is what can I use to verify it accurately I also tested some li-ion battery cells and this seems to be fairly accurate because I have another tester and they seem to agree with each other
I also checked some capacitors with it that were brand new and seem to show about what I expected to see with my blue capacitor tester so I think it... -
by DobrowolHello. Ive got problem with Dell Latitude 3520. After power on, no display and fan goes crazy. Standard job, I exported a clean bios from update via pfs extract.
Steps i done and results:
I exported a clean bios from update file via pfs extract.
1. Build clean bios with clean ME, PMC, PCH in flash image tool.
Result: Dead
2. Build clean bios with no changes in ME, new PMC, PCH
Result: Dead
3. Build old bios with clean ME, new PMC, PCH
Result: The same
Channel: BIOS Requests ONLY!
This specification for the ACER Revo M2-601 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Revo M2-601 boardview and Revo M2-601 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ACER Revo...09-12-2024, 03:28 PM
- Loading...
