Unsolder Technique for Through-Hole Jacks
  • bgavin
    • Jan 2007
    • 1355
    I'm looking for advice on how to properly de-solder a through-hole multi-pin jack from a board.
    This is a "pod" type modular jack with two rows of three flat pins.
    Mounting style is "through hole".
    My question is about the right tool for solder removal, and a technique for cleanly removing the old jack.
    I was able to remove the part with my Hakko 936 and a sucker bulb, but it was ugly work.
    I'd like to know how to cleanly remove all the old solder without risking damage to the solder pads.
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: Unsolder Technique for Through-Hole Jacks
    would ChipQuik work?
    • cmj21973
      • 267
      To clean solder pads & traces:
      Flux (paste or liquid), solder wick, rubbing alcohol (70% some stores carry 91%)
      http://www.bing.com/videos/search?q=...t=0&FORM=LKVR2
      To remove most components:
      1) Always add flux and leaded solder when desoldering. Helps old solder and lead-free solder to melt.
      2) If a component has a heatsink attached, remove it.
      3) If it's on a large ground plane and you don't have a hot air rework station, preheat the board with a hair dryer or heatgun. Becareful, very careful if using a heatgun.
      While board is warm, work quickly with disoldering tools to remove component.
      http://www.bing.com/videos/search?q=...nts&FORM=BVFD#
      • mockingbird
        • Dec 2008
        • 5484
        That's called a 'teardrop' lead... I imagine wick would suffice here.
        • Agent24
          I see dead caps
          • Oct 2007
          • 4940
          • New Zealand
          If you aren't worried about the jack itself you can cut it up until you're left with just the leads and then you can desolder those one at a time.
          A vacuum-pump desoldering tool would be good too because you get heat and continuous suction at the same time.
          Other option is a small solder pot, heat all the leads at once and just pull it out.
          -David VanHorn
          • Uranium-235
            Comrade Glimmer
            • Aug 2007
            • 5042
            • US
            if its a bad component with as many legs as that, it does present itself a problem. I noticed this problem when replacing laptop power jacks. Many pins, going down, hard to 'walk out' cause other pins were dry. The solution I came up with doesn't work in all cases..
            destroy the f'n thing. Its bad, right? I used a pair of dykes to literally cut the jack in half, and (carefully) cut and pull pieces of it off till I could take a pair of pliers and pull each leg out individually /w your iron. Doesn't work in all cases, and you need to be careful. If you break off the top of one of those pins going into the motherboard, it can be a serious pain in the ass to get it out
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              Uh... what's wrong with desoldering braid aka solder wick? Pumps tend to be messy, as they always drop small bits and pieces of solder everywhere.
              A working TV? How boring!
              • corrize
                Best way to solder LVDS connector for beginner (and qfn) ?
                by corrize
                Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                See the test :
                https://youtu.be/bNAzC-EvqHs?t=1767
                With hot air from bellow the board, that's...
                03-09-2023, 02:57 AM
              • myth77
                UV solder mask - high temp resistent, recomendation?
                by myth77
                Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                Is there any solder mask...
                03-28-2022, 04:04 AM
              • petemanuk
                BGA solder balls not connecting - help pls
                by petemanuk
                So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                11-16-2022, 05:21 AM
              • acedogblast
                by acedogblast
                11-02-2024, 05:13 PM
              • sircastor
                Solder not reflowing - what am I doing wrong?
                by sircastor
                I'm trying to fix a broken MacBook Air, and got a parts board to salvage components from. Following the suggestions of many folks here, I wanted to get in a little practice of using my hot air station (A Quick 957DW+) on the parts board so I know what kind of behavior to expect.
                For the life of me, I can't get anything done with this thing. I have tried multiple temperatures (from 210-425c), different air speeds, preheating the board (with the hot air, just warming it all around). I have applied what feels like excessive amounts of flux (Amtech V2-TF-559) and the solder on these components...
                03-03-2024, 02:44 AM
