Testing lighbulb using multimeter
  • zillah
    • May 2009
    • 11
    Hi Experts
    I have got DIGITECH Cat: QM-1536 Multimeter bought around $80 from
    http://www.jaycar.com/splash.html
    Tried to test two types of bulbs to check if it is burned out or not ?
    The first type Compact fluorescent light bulbs (CFL) similar to one in the link below :
    http://www.ehow.com/facts_6019356_en..._-mercury.html
    The second one typical incandescent bulb ( I guess it is called light bulb) the one similar in the link below :
    http://www.ehow.com/how_7526571_test...ity-meter.html
    When I did the test I followed the instruction in the links below :
    http://www.ehow.com/how_5193668_chec...ight-bulb.html
    My digital multimeter wouldn't be able to read resistance nor continuity,,,,,I couldn't figure out where is the problem !!!!!
  • ComputerGeek
    • Oct 2011
    • 262
    Re: Testing lighbulb using multimeter
    Why Bother? Just screw it into another fixture that you know is working. Then you will know if its good or not.
    • mariushm
      • May 2011
      • 3799
      Can't measure a CFL lightbulb from outside.
      There's electronic circuits inside it that generate an impulse of around 700v to start the whole process... so basically the two "terminals" you have access to from outside (the metal screw and the metal tip of the bulb) end up connected to some electronic parts and then other things inside may be broken or not.
      The regular light bulb is basically a wire under inert gases ... when electricity passes through it it heats up until it becomes incandescent. If the wire is continuous the bulb is good, so set the meter on continuity and touch the terminals of the bulb.
      From the picture I see on google, you have to set the meter on resistance (ohm) and then press a button to switch between modes (resitance, diode, continuity). When set on continuity the meter should beep if it has a beeper.
      This is what's inside a CFL lamp, the red wires go to the outside terminals, all the way on the other side the tubes are connected to the small board:
      The large green capacitors are often the reason why the lamps stop lightning up - no way to test those from outside the lamp.
      • retiredcaps
        • Apr 2010
        • 9271
        You should get an ohms reading for the above bulb. A good bulb might read less than 25 ohms.
        --- begin sig file ---
        --- end sig file ---
        • zillah
          • May 2009
          • 11
          Thanks retiredcaps
          I did but still I wasn't able to read ohms
          • zillah
            • May 2009
            • 11
            Noted. Thanks for that
            I did and it didn't work as well
            Note: Just for my knowledge.
            You said terminal of the bulb do you mean the two terminals when we have a pin type lightbulb and I guess we should touch one probe from the multimeter to the very bottom center of the light bulb and touch the remaining probe from the multimeter to the side of the light bulb base if you we a screw type lightbulb
            Read more: How to Test a Light Bulb's Continuity With a Meter | eHow.com http://www.ehow.com/how_7526571_test...#ixzz1o7B4Q3Fx
            or you meant one terminal and
            Cheers
            • zillah
              • May 2009
              • 11
              Yes you are right this is an easy option but i tried to use technology and enjoy its benefit.
              Regards
              • retiredcaps
                • Apr 2010
                • 9271
                1) Put your multimeter on ohms. Touch your two probes together. What reading do you get?
                2) Take a known good bulb. Put one probe at the tip of the bulb. Put the other probe anywhere on the screw threads. What reading do you get?
                • zillah
                  • May 2009
                  • 11
                  the reading flips between many values from ohms to Kilo ohms to Mega ohms, is this what suppose to be ?
                  Yes
                  I did , reading is 0.L Mega Ohms,,,,,,,,,,,,,I used pin (Bayonet type is push-turn) light bulb not screw type
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    On a working multimeter, it should be around 0.3 ohms. Either your probes or bad or your multimeter is not functioning properly. Try reseating your probes into the multimeter.
                    As another test, try measuring a standard AA battery. A fresh ununsed battery should measure more than 1.5V DC.
                    • zillah
                      • May 2009
                      • 11
                      Reset multimeter fixed the issue now reading 0.3 and 0.4.
                      For known working lightbulb still it was reading 0.L Mega Ohms,,,,,,,,,,,,,I used pin (Bayonet type is push-turn) light bulb not screw type
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        I noticed that your multimeter has a reset button. I have never seen that function before on a multimeter.
                        0.3 to 0.4 ohms indicate good probes and that your multimeter is working properly.
                        Sorry, I'm not familiar with that style of bulb. I have a few screw types and they all measure around 20 to 30 ohms.
                        • zillah
                          • May 2009
                          • 11
                          Okay I am going to buy a one that you are familiar with it and let us see how it goes with reading.
                          Right now I don't have a car handy to drive to any place to get that, hopefully withing 3 hours I will reply you with the outcome.
                          Regards
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            Why buy a bulb that you don't need?
                            There are lots of things around the house that you can measure. If you have an old motherboard or any piece of old electronics gear, there are plenty of resistors to measure.
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              Multimeter tutorial at (less than 5 minutes)
                              http://www.youtube.com/watch?v=bF3OyQ3HwfU
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                BTW, if you are in Australia, your fellow Aussie, Dave Jones, has a video blog called eevblog.com where he talks about multimeters a LOT. He has shootouts, beginners guide to buying a multimeter, teardowns, etc. Well worth the time if you want to find out more about electronics.
                                http://www.eevblog.com/episodes/
                                I'm guessing Australia due to the Jaycar reference in post #1.
                                • zillah
                                  • May 2009
                                  • 11
                                  Yes I am in Australia
                                  By the way JayCar is USA and Canada and NZ and UK and AUS,,,,not only in Australia
                                  Regards
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    If I go to jaycar.com and click on Canada, it takes me to an .au site. In addition, if I go to stores there is nothing listed for Canada. Jaycar may have a website in Canadian pricing, but that is all I can see.
                                    • zillah
                                      • May 2009
                                      • 11
                                      Yes you are right.
                                      • Agent24
                                        I see dead caps
                                        • Oct 2007
                                        • 4977
                                        • New Zealand
                                        Is your multimeter auto-ranging?
                                        -David VanHorn
                                        • repair-it
                                          TOSHIBA DLP 52HM95 How to reset timer module on bulb
                                          by repair-it
                                          I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
                                          Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
                                          10-11-2023, 07:18 PM
                                        • ezenia
                                          LUMIMAN Smart Bulb IC ID?
                                          by ezenia
                                          I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
                                          In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
                                          04-28-2025, 05:56 PM
                                        • Kosala Balasooriya
                                          What is the best multimeter can be used to check laptop mother bord testing
                                          by Kosala Balasooriya
                                          I am a new student.I am looking for repairing tools..What is the best multimeter testing mother bord
                                          02-28-2023, 10:27 AM
                                        • dj8452000
                                          How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                                          by dj8452000
                                          I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                                          02-18-2025, 08:28 AM
                                        • trex66
                                          Craftsman 82345 Multimeter broke!
                                          by trex66
                                          My daily carry just stopped working only me. Started last week with the voltage flickering. Found one lead was broken and I ordered new ones. New leads didn't change anything, it displays “-1” on all settings but on continuity will give the tone when touching. Checked battery and found the fuse blown. Replaced fuse but same results. Cleaned the dial and led display and its parts. Board looks nice and clean no burned or broken components. Nothing traumatic happened to this multimeter I put it aside when I found the lead broken and didn't touch it until I got the neAnyone have any ideas what's...
                                          03-04-2025, 04:26 PM
