What is the best multimeter can be used to check laptop mother bord testing
  • Kosala Balasooriya
    • Feb 2023
    I am a new student.I am looking for repairing tools..What is the best multimeter testing mother bord
  • mon2
    • 14794
    Re: What is the best multimeter can be used to check laptop mother bord testing
    https://www.badcaps.net/forum/showth...hlight=eevblog
    • dj8452000
      How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
      by dj8452000
      I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
      02-18-2025, 08:28 AM
    • trex66
      Craftsman 82345 Multimeter broke!
      by trex66
      My daily carry just stopped working only me. Started last week with the voltage flickering. Found one lead was broken and I ordered new ones. New leads didn't change anything, it displays “-1” on all settings but on continuity will give the tone when touching. Checked battery and found the fuse blown. Replaced fuse but same results. Cleaned the dial and led display and its parts. Board looks nice and clean no burned or broken components. Nothing traumatic happened to this multimeter I put it aside when I found the lead broken and didn't touch it until I got the neAnyone have any ideas what's...
      03-04-2025, 04:26 PM
    • Jane
      How do you test MOSFET in laptops ?
      by Jane
      I tried to use this method:
      Testing an N-channel MOSFET:
      Step 1: Discharge the Gate (turn off the MOSFET)
      Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
      Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
      Step 2: Charge the Gate (turn on the MOSFET)
      Now, place the red probe on the Gate (G) and the black probe on the
      09-27-2024, 03:31 AM
      I found this video when looking for something else but this is how to use a phone charger for testing LED light bulbs
      Here is the website link for this project that I plan on making
      https://www.youtube.com/watch?v=atLERDZx0Q8
      But I going to use a different enclosure for this project and make it more professional looking and use safety features that was not used in this video
      I have some 24 volt switching power supply from my battery testing machine that I modified for a different switching power supply that is more suited for my new application and new purpose for testing BMS protection boards
      If can find one that I can modify the voltage output on I have a...
      09-09-2024, 04:47 AM
      Some New Preliminary testing of 21700 Tool battery cells to 2.00
      I decided to try a new approach to testing unbalanced battery cells with my battery testing machine that has more graph curve information and it looks like if you discharge them to 2.00 volts if the battery voltage does not come back to over 3.something volts you have some kind of issue with that battery cell
      I going to do more testing and see if is the case or not
      More to come later
      05-04-2023, 05:11 AM
