Puzzling result from ESR Meter
+ More Options
Posts
  • MrPhil
    • Jan 2012
    • 3
    Hi I'v just finished an ESR meter based on Ludens circuit, which seems to work very well. I did a small mod to broaden the range a bit, so 4.7 ohm is below mid scale great. Works fine.
    Here's the Puzzle!.
    I short the test leads out to zero the meter fine.
    Then If I measure a 'NON Polarized' 1.5uf polycarb capacitor it takes the meter about 5mm Past the zero point!, It also goes over the zero on another 2.2uf non polar cap I have?
    How can this be?. If a short circuit limits the meter to Zero FSD. how can measuring a non Polar cap send it further over the Zero?
    As for electrolytics the meter works fine.
    Any Info would be much appreciated.
    Thanks all
  • multimeter
    • Jan 2011
    • 739
    • united kingdom
    Re: Puzzling result from ESR Meter
    is the cap fully discharged?,and tried reversing the leads to the cap?(even though it might not make a difference because of a non polar cap)?,try those couple of things
    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
    • MrPhil
      • Jan 2012
      • 3
      Hi Multimeter, Yes that was my 1st thought when I saw the pointer fly over the zero, but no it's not that, and I have tried another NP cap several times with the same result.
      Cheers
      • multimeter
        • Jan 2011
        • 739
        • united kingdom
        do you get same results with a digital esr meter,if you have one?
        • Agent24
          I see dead caps
          • Oct 2007
          • 4913
          • New Zealand
          Don't think there are any digital ESR meters that will measure negative ESR? (which shouldn't exist)
          -David VanHorn
          • multimeter
            • Jan 2011
            • 739
            • united kingdom
            maybee the 5mm off zero is showing its %tolerance in the cap....
            • MrPhil
              • Jan 2012
              • 3
              Problem Sorted..!!!
              It seems the over reading was caused by the leakage inductance of the transformer, where the capacitor partially resonates with the inductive component to give a greater current than the short circuit.
              Many thanks to 'Jimmc' from EEVblog for this insite.
              This has now been turned to my advantage by including the best value NON polar polycarb cap in series with the capacitor under test as a permenent mod to my meter.
              Many thanks to all for your comments,
              Cheers
                Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                by sam_sam_sam
                I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                12-31-2023, 06:04 AM
              • jorpec
                Changing the scale of an analog meter
                by jorpec
                Hi
                I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
                I wonder how i can accomplish this so the meter would be precise at any temperature ?
                Thnaks
                01-23-2023, 10:37 AM
                How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                by sam_sam_sam
                About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                12-14-2023, 07:45 PM
              • chth96
                Is it possible to test small ceramic disc capacitor with analogue meter?
                by chth96
                I read EBOOK of Testing Electronic Component and found that
                "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                Is it really possible to test small ceramic disc capacitor with analogue...
                03-09-2024, 10:03 PM
              • Stephan Mathers
                EDMI ATLAS MK10 Electronic Meter Discussion
                by Stephan Mathers
                Greetings, new guy here but always interested in the crazy universe of modding
                We just finished construction of around 25 vacation houses, all inside the same private area.
                Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
                The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
                Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
                05-20-2025, 09:09 AM
