removing solder
  • Proxyep
    • Nov 2010
    • 14
    removing solder
    this is not simple solder removing I'm talking about
    I'm talking about removing ALL traces of solder on say a copper contact that wasn't supposed to have solder, see I accidentally split solder on a little copper contact, I wicked away the excess but there are still little traces of solder on it any Ideas on how to remove traces of solder? this is purely cosmetic and the item in question is still functional
  • ant3202
    • Jun 2006
    • 275
    • Singapore
    Re: removing solder
    try using use desoldering wick...
    http://en.wikipedia.org/wiki/Desoldering#Solder_wick
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Re: removing solder
      Braid with plenty of flux.
      Move it around a little for kind of a sandpaper effect.
      If need be buff it with dry braid [and optionally toothpaste] for the last traces.
      Mann-Made Global Warming.
      - Dr Seuss
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
      • jshhh
        Help repairing Yamaha RM1X synthesizer/groovebox - PCB trace for capacitor has been pulled off
        by jshhh
        Hi guys,
        I've been trying to restore this Yamaha RM1X groove-box I bought, and the first thing on my agenda was to replace a bad capacitor that was making it so that the screen was super dim. As I'm a complete novice I went and accidentally pulled off one of the trace pads for the SMD capacitor as I was removing it, pulling up some of the green PCB with it. I've been trying to repair it by gluing down copper tape from where it began to pull off and solder the capacitor on after...atm I've just been attempting to do the same kind of thing on rubbish PCBs I got at a recycling place,...
        03-26-2025, 07:05 PM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • corrize
        Best way to solder LVDS connector for beginner (and qfn) ?
        by corrize
        Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
        I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
        I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
        See the test :
        https://youtu.be/bNAzC-EvqHs?t=1767
        With hot air from bellow the board, that's...
        03-09-2023, 02:57 AM
      • re-atari
        Gigabyte GA-H110-D3A schematic/boardview needed
        by re-atari
        Hello all,
        Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
        This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
        02-24-2025, 06:45 PM
