Fluke 337 Clamp Ammeter - zeroing/taring
  • tiresias
    • Feb 2006
    • 489
    Hi guys,
    For a little over three years I've been the proud owner of a Fluke model 337 Clamp current meter.
    While it's always given me excellent service, and greatly aided in measuring current loads of all kinds (although I've never gone anywhere near its rated max of 1000A!) , and troubleshooting hardware from my PSUs to my neighbour's car's starter motor, there's a little issue that I've been wondering about for some time...
    When one sets the dial for either AC or DC current measurements the display rests at a "zero" of about 0.3 or 0.4A. While the DC Amps reading can be 'tared' on the spot by pressing the 'Zero' button, this cannot be done with the AC Amps setting.
    Can someone advise me with regard to this issue? Would this be a matter for "recalibration", or is there some other way by which it can be addressed?
    If any should wish me to do so, I can take and upload pictures of any part of the Fluke.
    PS. Note that this zeroing issue seems to exclusively be affecting the AC Amps setting.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Fluke 337 Clamp Ammeter - zeroing/taring
    zero function is only available on 336 and 337 in that series. the models which measure dc amps. the ad refers specifically to dc amps also.
    there must be a reason for that. ask fluke i guess
    nice toy tiresias, i threw away the fluke catalogue a while ago. it was disturbing me. damn techno porn.
    • tiresias
      • Feb 2006
      • 489
      Yes, I've always found fluke's 'devices' to be extremely well made - I've actually been considering one of their DMMs for some time, to replace the array of half-broken $10 meters I have gradually "built up" over the years.
      As for this 337, I've found it extremely convenient for, for example, noninvasively determining the exact amount of load each of a PSU's "rails" is placed under in a particular system/setting. It's one of the reasons I consider braided ATX cables something of a drawback.
      I shall be contacting Fluke themselves though, I'm sure they can point me in the right direction... although I still don't understand why it should be, by design, easy to tare the DC current measurement but not AC... Any ideas?
      • davmax
        • Dec 2005
        • 899
        I have just checked my Mastech clamp meter. The AC zero is fine and there is an auto zero button for DC. Normally AC measurement does not need to be set to zero. If there is an error it has to be in the latter processing stage of the instrument. DC offest adjust is always required by the very nature of DC value drift, essentially this compensation is at the input level, different from the AC situation.
        You do need to check with Fluke re the AC offset.
        Gigabyte EP45-DS3L Ultra Reliable (Power saver)
        Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12
        160Gb WD SATAII Server grade
        Nvidia 8500GT 256Mb
        160Gb WD eSATAII Server grade for backup.
        Samsung 18x DVD writer
        Pioneer 16x DVD writer + 6x Dual layer
        33 way card reader
        Windows XP Pro SP3
        Thermaltake Matrix case with 430W Silent Power
        17" Benq FP737s LCD monitor
        HP Officejet Pro K5300 with refillable tanks
        • tiresias
          • Feb 2006
          • 489
          I was indeed wondering about that... many thanks for your cogent explanation!
          I shall definitely be doing that - and I'll be letting you know in this thread what they advise.
          • Baldbentley
            repairing a Fluke 335 clamp meter
            by Baldbentley
            I am repairing a Fluke 335 clamp meter. After contacting fluke it appears there is no service manual or circuit board/ component list available. I have determined that there us a faulty PNP bipolar junction transistors shown in the pictures. I am having trouble sourcing this transistor. I pulled a good one off of the board and tested it with my component analyzer but I cannot find anything that matches the specifications. Any help locating this part or a replacement would be greatly appreciated.
            Thanks...
            10-18-2023, 02:05 AM
          • caspian
            Can Ammeter damage Power Supply?
            by caspian
            Dear Members,
            My DC linear Lab Power Supply does not display the current and voltage correctly. Thus, I am going to connect an Ammeter/Voltmeter Module to the DC output of the power supply. Then, a load will be connected the takes about 1-5volts with 0.1-1.5Amps.
            But I heard If I connect an Ammeter to the output of the power supply, then the Ammeter module is not isolated from the power supply so that the Ammeter can damage the power supply.
            Is this true?
            I have attached the photo of a sample Ammeter module that I am going to buy....
            06-05-2022, 01:42 AM
          • Khoja
            Fluke 123 no image on the screen
            by Khoja
            Hello experts,
            I recently purchased a used Fluke 123 Industrial Scopemeter from an online Japanese auction site (jauce.com). It has now been delivered. Unfortunately, I overlooked the fact that the seller neither guarantees its working condition nor accepts returns.
            When I power it on, the backlight comes on, but there is no image on the screen. After opening the device, I noticed clear signs of previous soldering in several areas (photos attached). It seems someone attempted repairs before.
            At this point, I'll have to try and fix it myself. Has anyone here...
            04-10-2025, 09:24 AM
          • Sparklingx
            CH341 disconnects, test clamp not working, soldered bios chip but not erasing/writing how I fixed
            by Sparklingx
            So i've bough a ch341 programmer, and the chip was CH341B . the test clamp was not working( when connecting bios using test clamp, ch341 device was disconnecting) I tried soldering the bios on the provided board, soldering the bios I could read the chip but could not write or erase. ASprogrammer , neo, ch341a programmer... all programmer software was hanging and device was disconnecting after few second of erase/write operating.
            So then I have soldered a capacitor(whatever I had..[10v ~470uf ] ) from VCC to GND on my provided pcb where you solder the bios
            now all...
            08-29-2024, 01:53 PM
          • marce002
            UT210e clamp revival eeprom
            by marce002
            Hi
            I was trying to flash the chip in the board with my ch341a programmer, wiring as documented by https://www.youtube.com/watch?v=fX-Fhq9R4uY
            it did not read anything so desoldered the chip from the clamp and put into my programmer board and also not reading real data, it only brings emptyness...
            maybe i ruined the memory? turning the clamwith no chip shows Error and a beep wich is correct.
            put chip back to the clamp, and shows some random numbers like calibrating and offers a 0.000 DC display and nothing else can be selected...
            10-05-2023, 01:28 PM
