TG210 2MHz Function Generator
  • tmcw
    • Oct 2010
    • 382
    • Ireland
    Wasn't sure where was the most appropriate forum to post this, but since it's test equipment, I thought here...
    Anyway, I got donated one of these boxes today, it's blowing fuses.
    Anyone familiar with these instruments, and might be able to provide me with some starting points for testing?
    Thanks.
    EDIT: Also, does anyone know what the thing in the photo is called/used for? It was in a kit, and has thin bits of metal at both ends, which don't seem to be connected.
  • cmj21973
    • 267
    Re: TG210 2MHz Function Generator
    This is about the tool .
    A picture of the TG210 2MHz Function Generator and who made it would be helpful.
    • tmcw
      • Oct 2010
      • 382
      • Ireland
      Thanks for the link about the tool.
      I've attached a photo of the front and inside of the instrument. Made by Thurlby Thandar Instruments. Voltage is selected (230V/115V) by flipping the fuse holder, and was set correctly for our 230V here.
      From the power connector, I guess the fuse position directs the juice either through the red or orange wire. Blue comes from the on/off switch. Then from the other side of the windings to the board on the 3-wire connector. The 2 fuses there are still intact. With a good fuse in, power momentarily gets to the power LED, but the fuse blows pretty quick.
      • Tube_Dude
        • Feb 2011
        • 51
        Disconnect the 3 wires that come from the secondary of the mains transformer (red-black-red) and see if the fuse burn again.
        That way you can, or not, put the transformer out of the equation...
        • cmj21973
          • 267
          Here is the manaual. Does it have the correct fuses(see pg-8)?
          • tmcw
            • Oct 2010
            • 382
            • Ireland
            Thanks, yes, both fuses were the correct rating (125mA), the connected one was blown, the spare blew when I swapped it in, I have no more fuses of that type. I'll get a box of new fuses, and see what happens when I disconnect the board from the transformer. If it doesn't blow the fuse, I guess the transformer should be good?
            • Tube_Dude
              • Feb 2011
              • 51
              Yes!!
              • Radio Fox
                • Jan 2010
                • 281
                Make sure you get the time-lag fuses (T125mA).
                ________________________________________________
                Invisible airwaves crackle with life
                Bright antennae bristle with the energy
                • tmcw
                  • Oct 2010
                  • 382
                  • Ireland
                  Ok, got the T125mA fuses, disconnected the 3-wire connector, and the fuse gets blown.
                  I guess this means the transformer is bad.
                  The label in the transformer reads as follows:
                  22115-0180/3/3
                  19.10.:5
                  The plastic moulding has some markings that can be seen highlighted in the composite photo of both sides. I also tried to highlight what I think is the manufacturers logo (CVP or CVD, maybe).
                  Anyone know how to interpret these numbers so I can get a replacement.
                  • jason123
                    Agilent 33220A 20 MHz Function Generator
                    by jason123
                    I can't find a forum to discuss "instrumentation Troubleshooting", but PS maybe the closest.
                    So, I'm having an issue with about 13 year old Agilent Function Generator. it works, passes self-test, but it has an annoying "audible" noise, that changes as I change the output frequency setting of the instrument. Prominent around 600 Hz and up (at least that's what my ears are picking up.) I saw on some forms that it could be fan, linear regulator, dried up caps,... I can't seem to find the source of audible noise. Here is what I tried:
                    1. Turn the output off - still...
                    07-01-2025, 08:12 AM
                  • corrize
                    A funny fuse story – Lumix LX100 II
                    by corrize
                    Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                    I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                    The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                    There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                    And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                    10-19-2023, 09:58 AM
                  • Nevillet
                    Square wave (from a function generator) Vs a pulse generator
                    by Nevillet
                    Hi All,
                    Can someone please explain the difference between a 1kH square waveform with a 50% duty cycle and a similar waveform from a pulse generator?
                    Many thanks,
                    10-09-2022, 02:39 AM
                  • jesterace
                    Samsung UE46ES8000 Blown fuse but no other signs of short
                    by jesterace
                    Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                    09-11-2024, 03:14 PM
                  • SolomonMan
                    Function Signal Generator Some Questions...
                    by SolomonMan
                    All,
                    I have been collecting/purchasing equipment as I go along my "Electronics Journey". Thanks for all those who have helped me on this Journey and have educated me... I really appreciate this guidance!
                    Also the fixing of many of my household finds have kept the wife happy as well as I buy said new electronic equipment.
                    I have read and heard that every electronics workshop should have a Function Signal Generator or more than one.
                    As I barely understand the use of such a piece of equipment can someone educate me first on what this...
                    12-15-2020, 01:38 PM
