Function Signal Generator Some Questions...
  • SolomonMan
    • Apr 2019
    • 206
    All,
    I have been collecting/purchasing equipment as I go along my "Electronics Journey". Thanks for all those who have helped me on this Journey and have educated me... I really appreciate this guidance!
    Also the fixing of many of my household finds have kept the wife happy as well as I buy said new electronic equipment.
    I have read and heard that every electronics workshop should have a Function Signal Generator or more than one.
    As I barely understand the use of such a piece of equipment can someone educate me first on what this piece of equipment is commonly used for in electronic repair/design?
    Also assuming mostly household electronic repair with possibly automotive applications (not that I have ever needed anything more than basic electronics to keep my daily driver running) what should I look for in a Function Signal Generator?
    I find myself commonly fixing TVs, radios (amps), Computers (including vintage/retro), Tablets, Phones, and have found myself doing DIY kits recently.
    Thanks for the help,
    Chris
    • 30952
    Re: Function Signal Generator Some Questions...
    do you have an oscilloscope??
    because if not you dont need a signal generator - they are used together.
    • SolomonMan
      • Apr 2019
      • 206
      STJ,
      Yes, I have a Rigol DS1054Z with all the "Keys" installed. Also Probes etc.
      I have used it a time or two just for educational purposes but not really much on troubleshooting things.
      Chris
      • SolomonMan
        • Apr 2019
        • 206
        All,
        Does anyone have any experience with a Function Signal Generator and how to use one with a Oscilloscopt to troubleshoot issues?
        Also what I should look for in my first one. Like many of my earlier purchases I assume I will upgrade over time.
        I have seen a couple "Classroom" type scenarios with the oscilloscopt but not much when they (Oscilloscope and Signal Generator) play together.
        Chris
          • 30952
          it depends what your repairing,
          for anything with analog amplifiers or filters you can feed in a generated signal and then scope the output to see if it is o.k. or distorted in some way.
          • SolomonMan
            • Apr 2019
            • 206
            STJ,
            For household repair items what Frequency should I look for on my first function Signal Generator. I assume the different types of "Waves" are fairly standard.
            Any speicific brands?
            Should I get a DIY Kit..I know the lower end ones are probably not worth the effort.
            Chris
              • 30952
              household??
              what does that mean?
              unless your repairing audio amplifiers or radio transmitters to dont have a use for a sig-gen.
              i dont have one and i'v been repairing stuff for a very long time.
              • SolomonMan
                • Apr 2019
                • 206
                household??
                STJ,
                Thanks for the response again!
                I actually do have a small stack of projects that are Audio/Amplifier related. Covid-19 has had me organize the workshop and garage and I had more than a few projects stacking up. I focused previously on the larger ones (TVs and Monitors). Now we are on the smaller items. One of the biggest now is a Onkyo HTR-290 Amplifier which turned out to be a bad Amplifier IC. Its on order and is supposed to arrive before Christmas.
                The other are a couple older (circa 1980s) Radios. These are portable units and at least one is a Multiband radio. Weather band, shortwave, AM, and FM. My favorite is little JCPenny Multiband radio and I like to get that working again. The others are slightly newer and mostly small boom boxes which I could let the kids use in the barn. Keep in mind these projects are for learning experiences. Sounds like the Function Signal Generator would be of limited use for these.
                I will mention that I have some interest in HAM radio. My Step-Dad is big on Ham Radios. 30 plus years in the Military/Civilian contractor as a Electrical Engineer. He is involved in the early radio stuff. Including refurbishing and refinishing 1920-1930 radios (maybe even radios before that). He recently won some award by some National Radio group. He is about to move back to my area, previously lived about a days drive away, and I figure that will spark my interest some more in HAM.
                I do a lot with Retro-Computers. C64, Atari 8 bit, VCS2600, and a few Apples. Just starting to get these organized now.
                I am getting into the Arduino scene for a couple small projects as well. Not to mention I have more than a few Raspberry Pis that I am looking to play with the GPIO. They do not seem to be using a Function Signal Generator much. I have seen a couple projects that it was mentioned but not demonstrated.
                So it sounds like if I get Function Signal Generator it will be mostly a shelf queen.
                I am also looking at a https://www.ebay.com/itm/US-STOCK-MA...r/313014474073. I will probably purchase Mastech MS8911 before any Function Signal Generator.
                Basically this is Birthday present to myself at the end of the month and I have decided it will electronic related.
                Chris
                  • 30952
                  i dont see what that mastech does from the link.
                  it's expensive though.
                  do you have a component tester?
                  and for old computers you probably want to build a logic pulser
                  i can give you the details for that.
                  • SolomonMan
                    • Apr 2019
                    • 206
                    STJ,
                    The video below gives a rough review of it;
                    https://www.youtube.com/watch?v=96XTelPZnfA
                    Basically its a LCR (Inductance (l), Capacitance (C), and Resistance (R))) meter. There are quite a few out there (cheaper ~$20) not to mention the tweezer probes you can get for your Multimeter. The Mastech 8911 has a decent review from what I have seen/gather.
                    I do have a component tester.
                    I would be interested in the logic pulser.
                    Chris
                    • SolomonMan
                      • Apr 2019
                      • 206
                      STJ,
                      Are these the same as a Logic Analyzer Probe Kit?
                      I have one of these in the works to be purchased.
                      Chris
                        • 30952
                        no, a logic analyzer can record multiple channels at once,
                        a logic probe shows the state of a pin/signal
                        and a pulser injects pulses into a circuit.
                        you use a pulser in conjunction with a probe - the pulser injects a signal and the probe is to see if the chips output changes in response.
                        • SolomonMan
                          • Apr 2019
                          • 206
                          STJ,
                          I ended up picking up a LOGICAL ANALYSIS TEST KIT LTC-2 made by Continental Specialities. Its identical to the One from Global Specialities.
                          A couple of my firiends (local) have these kits and they use them commonly on old Arcade machines. After seeing them in action I decided to get one over the Holiday.
                          I also ended up picking up a Isolation Transformer for a upcoming project.
                          A Good Birthday Present.
                          Chris
                            • 30952
                            HMMM...
                            i prefer to make my own for under 10€ and spend the other 90 on beer and rum!
                            http://users.tpg.com.au/users/talkin...ser-Intro.html
                            • SolomonMan
                              • Apr 2019
                              • 206
                              HMMM...
                              Thanks for the link...I will keep that in mind when I am looking for another project to solder up...
                              Happy New Year,
                              Chris
