Anybody build this ESR meter...
  • richr69
    • Jul 2010
    • 58
    I was curious if anybody actually built this ESR meter
    http://kripton2035.free.fr/digital%2...o-russian.html
  • Agent24
    I see dead caps
    • Oct 2007
    • 4939
    • New Zealand
    Re: Anybody build this ESR meter...
    I haven't but going by the photos it doesn't look too bad really - it would no doubt be better than nothing, and you get the added bonus of capacitance measurement too!
    If it's cheap enough, I'd say go for it
    -David VanHorn
    • chth96
      by chth96
      03-09-2024, 10:03 PM
      12-31-2023, 06:04 AM
    • jorpec
      by jorpec
      Hi
      Thnaks
      01-23-2023, 10:37 AM
      Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
      12-14-2023, 07:45 PM
    • Stephan Mathers
      EDMI ATLAS MK10 Electronic Meter Discussion
      by Stephan Mathers
      Greetings, new guy here but always interested in the crazy universe of modding
      We just finished construction of around 25 vacation houses, all inside the same private area.
      Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
      The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
      Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
      05-20-2025, 09:09 AM
