ESR meter circuit
    ESR meter circuit
    Hello
    Here is an 555 ESR meter circuit I just got working:
    http://koti.mbnet.fi/hsahko/elek/kv/esr/
    Actually it is not a meter in itself but a converter for multimeter.
    It can measure ESR from 1 ohm to about 0.01 ohms or so.
    Re: ESR meter circuit
    Nice!
      I added analog panel meter to it, so it don't need multimeter anymore.
      As you can see from the photo, it still needs some little finishing like a pcb or a case...
        I can't quite understand what IC1B does - it appears to be over-riding the feedback around IC1A..
        Also, the user is expected to peel off the protective plastic film from the display on multimeters, or it becomes all bubbled and gooey....
        It is a good shrubbery. I like the laurels particularly...
          Oops, sorry. It is a drawing mistake, that is because I first build the meter and then afterwards drew the schematic...
          IC1B just buffers the potentiometer for zero adjust.
          No, no, you remove it when it has too much scratches on it and then... TADAA you have like a new display again
          But indeed it starts to be that time because of those bubles.
          On mobile phones those films are much better. They last two or three years before the films needs to be removed and never any bubling.
            Ah, now it looks right. Thanks.
            This is very true. It should not be left there for many years because then it's very hard to remove the film and its glue.
              Finally got enought time to draw a PCB for the meter and to put it into a box.
              I used a TSH22 opamp but it needs a pulldown resistor to make IC1B go under 150 mV
                TSH22 need diferential power supply?
