Sloppy de-soldering 😩
  • x_orange90_x
    • May 2015
    • 727
    I was removing some bad caps last night on a tv PSU and accidently got solder bridged to something unintentionally. There are little elongated pads by the legs off each capacitor, and I accidently got solder onto one bridging it to the leg. I know I CAN remove the solder, but what are the pads and is it an issue if I leave it be? There are no components on the top side connecting to those pads, but there is a bridge from the trace itself to another one. Pictures are attached.
    • 31196
    Re: Sloppy de-soldering 😩
    desoldering braid/wick
    best one is made by chemtronics
    • x_orange90_x
      • May 2015
      • 727
      Thanks for the reply! I only had copper wire on hand and was able to remove some but not all. I scraped between them a little bit, put the new caps on and it appears to work fine. I think those pads are just little conductors in the trace.
        • 31196
        the braid has flux in it.
        • dbuergi
          Restore solder pads for SMC on MacBook A1466
          by dbuergi
          i got a A1466 logic board for spare parts but it looks like the SMC ist bad. I got several spares but somehow i was too fast while removing it and ripped some pads off. You can see the damage attached.
          Just for experience i would like to restore the lost pads but before i start (haven't done this before) do you have some hints or tutorials how to do it?
          As written i want to improve skills so it doesnt matter if it takes longer.
          12-29-2024, 10:24 AM
        • acedogblast
          by acedogblast
          11-02-2024, 05:13 PM
        • corrize
          Best way to solder LVDS connector for beginner (and qfn) ?
          by corrize
          Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
          I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
          I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
          See the test :
          https://youtu.be/bNAzC-EvqHs?t=1767
          With hot air from bellow the board, that's...
          03-09-2023, 02:57 AM
        • akwky
          by akwky
          Hi!
          04-14-2025, 01:56 PM
        • myth77
          UV solder mask - high temp resistent, recomendation?
          by myth77
          Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
          Is there any solder mask...
          03-28-2022, 04:04 AM
