What for this SOP8 apparatus?
  • Kemer
    • Apr 2023
    • 42
    • Turkey
    I bought a SOP8 apparatus for CH341A but zero document. What is this part for and may I use it to read and write to 25 series spi flash bios?
  • lotas
    • Jan 2016
    • 4842
    • Russia
    Re: What for this SOP8 apparatus?
    This is an adapter for "clothespins".
    • Kemer
      • Apr 2023
      • 42
      • Turkey
      Thank you but when do we use these? May I use it for laptop bios chip programming?
      • harp
        • Jun 2022
        • 648
        • Planet Earth
        Yes, but it is recomended to desolder chip first from pcb. You can try read chip onboard, and if fail just desolder it.
        This piece is used when you want connect soic-8 clip with programmer ziff socket, both side have pins that fit to. I connect this once and never disconnect from clip.
        • Kemer
          • Apr 2023
          • 42
          • Turkey
          I have 3 small pcb at the moment. One came out of the ch341 package and two from the sop8 clips package. It should have been specified what they were used for.
          Desoldering and re-soldering the bios chip is risky for me. I only have a soldering iron. The clip, on the other hand, is constantly sliding off the chip. The latch design is a lousy idea.
          Thank you.
          • harp
            • Jun 2022
            • 648
            • Planet Earth
            Not necessary, it is kind of logic.
            It is adapters for conection between either ziff and soic-8 clip, or ziff and bios chip soldered directly to adapter pcb.
            Are you absolutely shure there you using your clip specificaly on soic-8 bios package, and not to some other, eg wson8-mlf8-dfn8-tdfn8-qfn8-dip8?
            Clip shoud fit only to specific soic8, sop8 package, but must be flat to pcb and straight. Plastics claw hold chip underneath, next to pcb board, sliding off is not posible happen if claw is not damaged or wrongly placed.
            BTW, you can desoldered soic8 package from pcb using soldering iron, just make some pretinned thick wire formed to rectangular ring that meet to touch all chip legs, than fill all with solder and when melted lift up chip... just first try to some scrap pcb to get experiance.
            And BTW2, when useing clip and adapters, wires etc, pay special attention to orientation of chip legs - pin#1 (marked with small dot) must be connected to specific place on programmer. On ch341a is a two different place for 24xx and 25xx chips.
            • Kemer
              • Apr 2023
              • 42
              • Turkey
              Are you absolutely sure you're using your clip specifically in the soic-8 bios package and not in another package like wson8-mlf8-dfn8-tdfn8-qfn8-dip8?
              Yes, I am. There is a small pcb that is most common in youtube videos, as well as the above apparatus.
              Hm, if it's not possible, it means I couldn't do it. Ok, it's hard to see the contacts when latching. I try again.
              I like it. I'll first find another card and try it on.
              Again thank you for your time.
                • 31283
                the problem with soic8 chips is they come in 2 widths, and the difference is enough to make those clips tricky to use on the wide version.
                • harp
                  • Jun 2022
                  • 648
                  • Planet Earth
                  the problem with this soic8 clip is they come with too strong loaded spring. In mechanic point of view, I choose as light spring as possible, just to hold clip in place. Any spring can bent inter contact pin for good contact, and no bigger force can ensure better contact, only have stronger grip with package, and much more force necessery lead to gnaw off and to wear out plastics claw quickly...
                  https://dzrmo.wordpress.com/2017/07/04/chinese-soic-8-test-clips-for-in-circuit-programming-part-2/
                  • Kemer
                    • Apr 2023
                    • 42
                    • Turkey
                    I guess I found out when it was too late. There was nothing written on the package and I don't know how I could have known the difference. I'm not sure if the part I have is wrong, but when I look at it through the lens, I see that the plastic surface has worn off. I'll ask where I bought it. Thank you very much.
                    • Kemer
                      • Apr 2023
                      • 42
                      • Turkey
                      Thanks for the photos. I can see how the clip is supposed to hold the chip. On mine, retention spurs look worse than that. The piece in the photo looks great. But I didn't think to look it before use.
                      Your opinion on strong loaded spring seemed appropriate to me as well. The chip legs look a little squashed.
                      I suppose, would do it in the form of a frame instead of that clip. It's hard to describe but I'd seen an adapter plugged into the programmer. It was locking when pushed the chip in. It would be something like this but with a much more thin frame.
                      I also would add a led for each contact. Maybe I exaggerated a bit, but it would be nice.
                      I wish I knew these earlier. Thank you again.
                      • harp
                        • Jun 2022
                        • 648
                        • Planet Earth
                        And here it is!
                        How to save SOIC8 clip from wearing, when using on SOP-8W BIOS package...
                        https://www.youtube.com/watch?v=SrAzVT1OKEA
                        If the clip was designed better (longer gap below legs - longer free space to stretch) this is not be necesary, and will be compatibile witc soic8 normal and wide package.
                        • harp
                          • Jun 2022
                          • 648
                          • Planet Earth
                          See example
                          https://www.youtube.com/watch?v=bAlwiAeVVgM
                          You can do that trick on what ever package find (with exposed legs) and you can use a thin wire also, wraped many time around and soaked with tin... principe is the same.
                          Or use piece of used soldering wick, it is flexible and thick together, even prepared with tin to use out the box...
                          • Kemer
                            • Apr 2023
                            • 42
                            • Turkey
                            And here it is!
                            This video is perfect. Very helpful. That fishing line trick is also wonderful. Thank you. BTW, my SOIC8 clip spurs looking terrible
                            See example
                            This is another good one. However, I can not understand those subtitles. In fact, I tried to make the same thing with a 2.5mm dia wire but looking a bit oversize. Thanks again.
                            • harp
                              • Jun 2022
                              • 648
                              • Planet Earth
                              Thank you, I am glad to hear that
                              2.5mm is to big. I use 1.5mm for "rectangle O ring" or 1.0mm for "loop soldering iron tip" copper wire. You may do some other form, U, C, M, Z... specific to your case, that fit on particular space in pcb...
                              The spring is from hp inkjet printer.
                              I always try to present full idea on video independent of understanding some language. Just look to see point, and brain will do rest
                              • Kemer
                                • Apr 2023
                                • 42
                                • Turkey
                                OK, I already did it with a U shape (for bios chip). I will try it after find a scrap board.
                                I liked your idea, solution. I hope my 40W solder iron could be enough. Thank you dear harp.
                                  • 31283
                                  you should really be lifting the chips
                                  • md500
                                    [Question] Ch341a and 5v to 3.3v with logic converter
                                    by md500
                                    zz0.8tpitu4y0i8zzI bought a ch341a (I'm waiting for it to arrive) and I noticed that the programmer has a bug that the data pins go to 5v when the VCC pin is at 3.3v (which is the voltage I'm looking for).
                                    Instead of doing the 3.3v mod, I'm thinking of converting the 5v to 3.3v with an 8 channel TXS0108E through the ZIF socket but I don't know if that would work, because it has to circulate voltage and also information.
                                    What I am looking for is something that will convert from 5v to 3.3v but without modifying the ch341a.
                                    I can't buy the ch341a 1.6v that has...
                                    05-24-2024, 06:51 PM
                                  • Jérémy Vanbaelinghem
                                    The CH341A doesn't read anything, but maybe that's because I'm a noob :D
                                    by Jérémy Vanbaelinghem
                                    I'm desperately trying to get my CH341A to work, but it seems that all my attempts have failed. Despite everything, I want to check that it works, the aim being to read at least one chip and “screenshot” the configuration for me to use as a reference.
                                    Here are the steps (software part):
                                    - I'm running Windows 11 Pro 64-bit (10.0 build 26100)
                                    - Drivers are installed (no error messages) and there are no problems in the Device Manager.
                                    - Set the language to English (to avoid the CH341A's basic software bug)
                                    - Does not work on AsProgrammer...
                                    05-05-2025, 02:30 AM
                                  • Andreasbest
                                    Flashing 25Q256JVEQ with CH341A ?
                                    by Andreasbest
                                    Hello.
                                    I try to flash a 25Q256JVEQ with CH341A but i can't, the content is written successfully but on verify i get match error.
                                    Anyone knows if it's possible to flash 25Q256JVEQ with CH341A or not?
                                    Thank you in advance!
                                    12-21-2024, 11:11 AM
                                  • shuten
                                    acer XC-605 CH341A Programs Correctly but BIOS Still Won't Work
                                    by shuten
                                    hi all, so i have an acer XC-605 desktop which i believe had a bad bios flash.
                                    i setup an ssd for it and it didnt get recognized in the bios so i attempted a bios update with the provided gui from acers website (going from P11.A2 to P11.B4). i rebooted and it seemed the bios update was successful but when i turned off the pc, it would no longer turn on properly and gave me one long beep (fan goes on, maintains power but no display etc, seems to fail post).
                                    i tried a bunch of stuff like reseating ram etc and tried to reflash from usb but since nothing worked i eventually just...
                                    12-05-2022, 10:58 PM
                                  • EbrahimSiami
                                    Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                                    by EbrahimSiami
                                    I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                                    **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                                    **What I have tried so far:**
                                    1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                                    07-02-2025, 02:31 PM
