acer XC-605 CH341A Programs Correctly but BIOS Still Won't Work
  • shuten
    • Dec 2022
    • 9
    • united states
    hi all, so i have an acer XC-605 desktop which i believe had a bad bios flash.
    i setup an ssd for it and it didnt get recognized in the bios so i attempted a bios update with the provided gui from acers website (going from P11.A2 to P11.B4). i rebooted and it seemed the bios update was successful but when i turned off the pc, it would no longer turn on properly and gave me one long beep (fan goes on, maintains power but no display etc, seems to fail post).
    i tried a bunch of stuff like reseating ram etc and tried to reflash from usb but since nothing worked i eventually just bought a ch341a and tried to manually flash it.
    so when i connect the clips and run the ch341a software, everything looks fine, i can read the chip (MX25L6473E) and write to it, and the software verifies and shows me successful prompts, however the PC still does not start up. i no longer get the beep at startup so i know something definitely changed, but i still get nothing on display.
    i tried multiple programmer software and various bios versions but get the same results.
    ive used, asProgrammer, NeoProgrammer, CH341A programmer by Shichang Zhou, but no difference.
    even tried changing the chip size in the software to 4MB since the bios file is 4MB.
    mobo model is MS-7869 v1.0 for reference
    im sure it must just be something im missing but i have no idea, anyone have any ideas or suggestions?
    thank you!
  • hoaca388
    Badcaps
    • Jan 2022
    • 12420
    Re: CH341A Programs Correctly but BIOS Still Won't Work
    thank you!
    Why you know bios file is 4MB ?
    Where bios file which did you read from the chip? How many MB is that file ?
    Can you tell if the bios file is read successfully or no ( because sometimes CH341A just gives us a junk file ) ?
    With the MX25L6473E chip, it must contain 8MB of data and the bios downloaded from the ACER homepage is only half of the required bios file.
    • shuten
      • Dec 2022
      • 9
      • united states
      thanks for the reply, below are the answers to your questions:
      im just assuming the bios file is 4mb since thats the size i get on all the bios files i downloaded from acer
      i dont have the file i originally read from the chip since i figured the original flash was already corrupted
      the read itself looks to be successful since the programs match and verify with the files i try to flash
      if the acer file is 4mb but i should be writing 8mb of data, how or where do i get the remaining 4mb from?
      • hoaca388
        Badcaps
        • Jan 2022
        • 12420
        Get it from the original chip, otherwise you have to find the complete bios file somewhere or someone to share it with you.
        Always remember to back up the original bios even if it's broken before flashing a new bios.
        The steps to program the bios chip are: READ ( for backup ) --> Erase --> Blank check --> Write --> Verify
        • shuten
          • Dec 2022
          • 9
          • united states
          ya, unfortunately i didnt make the smart decision to back up the bios before erasing/writing
          i'll try to find if someone else can provide a dump for the acer XC-605 system
          • ASB
            • Dec 2020
            • 142
            • Pakistan
            Try this one.
            • shuten
              • Dec 2022
              • 9
              • united states
              Originally posted by ASB
              Try this one.
              Thanks for the help ASB, i flashed it with NeoProgrammer, everything went successfully (unprotect-erase-write-verify), but the same thing happens when i start the system
              fan goes on, but no display or other feedback
                • 22121
                there are 2 different motherboard versions,and differing bios versions afaik. try this bios ,its the same as you had originally P11.A2
                Remove the CMOS battery and press the power button a few times to discharge the board, flash the bios and replace the CMOS battery.Make sure the battery voltage is over 3 volts, if its under 3 replace it with a new one
                • shuten
                  • Dec 2022
                  • 9
                  • united states
                  Originally posted by SMDFlea
                  there are 2 different motherboard versions,and differing bios versions. try this bios ,its the same as you had originally P11.A2
                  Thanks for the reply SMDFlea!
                  Unfortunately i've tried all the P11 bios's from acer's site to no avail
                  i retried with the one you sent and still getting the same issue
                  battery looks to be working well and read/write to the chip is successful but i still get nothing apart from the fans going on
                    • 22121
                    sorry i only posted the update,by mistake . I have a P11-B4 bios you can try.Select the MX25L6473E chip manually with NeoProgrammer/ASProg don`t use auto-detect.
                    Do you know if your CPU is a haswell. The P11-B has haswell microcode
                    I`ll add the info you posted in your other thread,and you also posted at win-raid.....
                    chip is MX25L6473E (i believe this is 8mb)
                    mobo is MS-7869 v1.0
                    PC is Acer Aspire XC-605-EB13
                    SN on the case is DTSRPAA00435100C0C300
                    SN sticker on mobo is DBSRPCN00135002608EE00
                    • shuten
                      • Dec 2022
                      • 9
                      • united states
                      Thanks, i just came across a telegram channel that had a bios for my device as well and flashed to the chip, cleared the cmos and, lo-and-behold, it worked!! im back into the computer!
                      Learned a very valuable lesson to always backup the running bios even if the flashing fails lol
                      Thanks again for all your time and help SDMFlea!
                        • 22121
                        Its a valuable lesson that everyone learns when its too late .Never happened to me,no never
                        Can you post the bios version you found to help others, it will be interesting to see if its an A version, and what microcode it has or any other differences.
                        • shuten
                          • Dec 2022
                          • 9
                          • united states
                          haha definitely!
                          for sure! this was a P11.B4 version
                          • piernov
                            • Jan 2016
                            • 4439
                            • France
                            Re: acer XC-605 CH341A Programs Correctly but BIOS Still Won't Work
                            ME isn't clean in that file.
                            • shuten
                              • Dec 2022
                              • 9
                              • united states
                              hi piernov, thank you for your reply. i have no knowledge about cleaning the ME or modifying BIOS files myself sadly, is an unclean ME a major issue? the computer does work in general
                              edit: because of your reply, i tried the BIOS that SMDFlea posted above, with the one i found online i did notice POST was a bit slower than usual (20s vs 5s before), but now with the BIOS SMDFlea posted it works perfectly and POST is much faster!
                              Thank you both for your help! big thanks to SMDFlea as well for taking the time to help with the clean bios file!!
                              • EbrahimSiami
                                Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                                by EbrahimSiami
                                I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                                **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                                **What I have tried so far:**
                                1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                                07-02-2025, 02:31 PM
                              • hotcrossedbuns999
                                M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                                by hotcrossedbuns999
                                My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                                1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                                2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                                3. I could only locate two chips that look like bios chips. Could someone verify this
                                01-03-2025, 12:32 PM
                                by Vesko356
                                08-11-2023, 03:27 AM
                              • what_1282105
                                Thinkpad t480s, completely dead after BIOS flash using CH341A programmer
                                by what_1282105
                                Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
                                02-14-2025, 07:27 PM
                              • jbonavita
                                by jbonavita
                                Some issues
                                Things I tried
                                04-29-2025, 09:38 PM
