Flashing 25Q256JVEQ with CH341A ?
  • Andreasbest
    • Aug 2014
    • 1219
    • Hellas ( Greece )
    Hello.
    I try to flash a 25Q256JVEQ with CH341A but i can't, the content is written successfully but on verify i get match error.
    Anyone knows if it's possible to flash 25Q256JVEQ with CH341A or not?
    Thank you in advance!
  • truclacicr
    • Apr 2019
    • 356
    • australia
    Just FYI, that's a 3.3V chip:
    https://www.mouser.com/datasheet/2/9...17-1489574.pdf
    • Andreasbest
      • Aug 2014
      • 1219
      • Hellas ( Greece )
      Originally posted by truclacicr
      So i just destroyed it with the 5v CH341A?
      But how is this possible ? i keep read it and write it 6 hours now trying to figure out the problem.
      • truclacicr
        • Apr 2019
        • 356
        • australia
        Absolute maximum is 4.6V. It could just be that the chip behaves unreliably at this voltage.
        • Andreasbest
          • Aug 2014
          • 1219
          • Hellas ( Greece )
          Ok, confirmed the chip is good, no hard from 5v.
          Main issue moved on laptop repair section https://www.badcaps.net/forum/troubl...ton-is-pressed
          Thank you for answering!
          • what_1282105
            Thinkpad t480s, completely dead after BIOS flash using CH341A programmer
            by what_1282105
            Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
            02-14-2025, 07:27 PM
          • cr4zychriss
            by cr4zychriss
            • Rebrand: PC Specialist
            11-14-2025, 04:04 PM
          • corrize
            Nikon D800 camera - flash don’t work and capacitor don’t charge
            by corrize
            Hello, I'm stuck in troubleshooting…
            The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
            In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
            When I press the flash button, it's detected by the system, flash icon appear on LDC display....
            10-01-2022, 10:02 AM
          • ekozeko333
            by ekozeko333
            🧠 What I’ve Done So Far
            Flashed...
            06-21-2025, 02:48 AM
          • Exim
            ASRock N100M, no picture no boot, but semi-alive
            by Exim
            Hi guys,
            I managed to semi-kill an ASRock N100M board after updating Bios from 1.10 to 2.01. It's a zombie now, dead, but not dead.
            ASRock N100M special features:
            - CPU soldered to board, small Intel 12th gen
            - iGPU
            - four POST LEDs
            Problem after updating Bios to 2.01 using the in-Bios update tool: no picture, no boot.
            I am not sure anymore if it booted at least once successfully after updating the bios to 2.01, maybe not, I can't remember. I think it did not.
            Symptoms:
            - no picture/signal on any of the display connectors,...
            04-01-2025, 02:36 PM
