DIYPHONE Store and AIXUN T420D
  • Sudoer
    • Sep 2019
    • 36
    • Israel
    I've seen enough reviews of AIXUN T420D on YouTube and decided to try it. One handle defective from the inside, ruined 3 JBC tips, just destroyed the plastic on the tips. One stand does not work, the soldering handle not drop the temperature. Because the seller refused to return the money, and AliExpress supported him and even PayPal did not help, I can disassemble this piece of shit and see what inside, if anyone is interested. The seller said that the station does not work with JBC handles, but I checked that it works. It's just a pity to connect the original handle to this shit. Beware of order from DIYPHONE store on Alixpress!
    • Jul 2011
    • 6040
    Re: DIYPHONE Store and AIXUN T420D
    Take a look at this link
    https://www.ebay.com/itm/27538817510...Bk9SR86j_o_-YQ
    When you receive the item from AliExpress did you let them know receive the item if you did if you have done this is this is the reason you have no leg to stand on
    The next time you receive something from AliExpress do not respond that you received the item or items until you have tried it out and make sure that torque test it before the 15 day window has expired before you say that you received it I have personally experienced this crap from them before ( I once ordered something from them that I responded that I had received it but after a couple of days it stopped working contacted AliExpress and was told that because I had responded that I had received the item that I was on my own )
    Case in point I ordered some Milwaukee M18 battery enclosures with the BMS protection board and all tabbing for the battery cells and the battery cell holder and the screws for the enclosure well everything went great until it was time to charge the battery pack the BMS protection board would not charge at all even with the seller information the way you are supposed to handle the BMS protection board I did not respond that I received them because I had ordered 4 of them all four of them did not work I sent AliExpress an email about this issue and I had to send them a video clip showing how the BMS protection board would not work correctly at all
    The only thing I wanted from the seller was $16.00 for each BMS protection board ( the same seller was also offering the BMS protection board by itself for this price ) that I ordered that did not work correctly everything else did work properly the way it supposed to I received about half of what I paid for once I received the refund of what AliExpress had offered me I then responded that I had received the order
    I hope this helps you the next time that you order from AliExpress
      • Jul 2011
      • 6040
      Thank you for sharing what PayPal responds was about this issue I am a little surprised by there response not wanting to help you with your issue I would have thought that they would have at least offered you what it would cost for a new handle for the soldering iron station
      By the way when I bought items from EBay I also do the same thing I do not respond that I have received the item from the seller sometimes I wait a couple of months before I give them a review because Ebay does the same thing about handling issues with what you have bought
      Yes I know that in some cases the seller has to wait to receive the money for your purchase but I am not going to give away my rights about getting a refund if the product does not work correctly I am sorry that it is this way
      Banggood is the same way and in some ways and in some cases they are worse than EBay and AliExpress are
      Alibaba.com they are sometimes even worse when it comes to when you have an issue with something you bought from them as well when I buy something from a seller I make sure they understand what I am buying from them what the shipping cost are and what if the item does not function correctly what options do I have at this point before I purchase anything from them
      • Sudoer
        • Sep 2019
        • 36
        • Israel
        DHL shipping. Of course, they knew that I had received the package. And I recorded the unboxing video and all the problems. But! About JBC tips, the seller said, "you can't use JBC tips". And he said a lot more. But the saddest thing is that PayPal's decision on an open case - I have to send the goods back, but I do not know the address of the seller. The seller knows this and refused to give me the address! So no one will refund my money
        • Sudoer
          • Sep 2019
          • 36
          • Israel
          Ali offered to return the goods. But this is a problem. First, sending the item back costs money. Secondly, the money will be returned only when the seller checks the goods. And if the money is returned, then only for the goods, and not for delivery + the cost of re-delivery back.
          I expected PayPal to be more customer oriented, but they aren't.
          So I'm trying to warn everyone to avoid this seller, at the least.
          • diif
            • Feb 2014
            • 6978
            • England
            Check the resistance between the piece the holder sits in and the base, in a certain position it is high for some reason and sleep doesn't work.
            When I have had to return something i have been offed an adress in my country to keep shipping low, with Aliexpress covering the international shipping cost.
            The non genuine tips are ok but genuine JBC tips are noticeably better, I don't think you've lost much due to the crappy handle if you have a genuine JBC handle that works with it.
            • Sudoer
              • Sep 2019
              • 36
              • Israel
              I'll wait and figure it out, 100% nothing complicated that I can't fix. But using aixun handle is a terrible idea. I have two JBC 245 and 210, but there is not enough space on the table, I wanted a two-channel station. I still want a two-channel station, but JBC only.
              • acedogblast
                by acedogblast
                11-02-2024, 05:13 PM
              • spleenharvester
                Making a Handskit hot air station a bit less stupid
                by spleenharvester
                I bought one of these as it was the only one I could find that is compact enough to fit in my toolbox (though I've since found KSGER make a substantially safer looking one). It's one of those fan-in-handle things that has the 230V element in the handle. Quecoo briefly sold a similar unit but discontinued it.. maybe they couldn't find solutions to these problems. I'm aware these fan-in-handle things are garbage compared to a good air pump station but I only really use this for occasional QFN work etc.
                I did not realise at the time of buying that its design is... interesting, to say...
                05-09-2024, 09:09 AM
              • tony359
                Aixun T3A overshooting?
                by tony359
                I've just purchased an Aixun T3A T245 soldering station and I am pretty happy with it, coming from a Hakko knockoff.
                However, I purchased a genuine JBC tip and the temp massively overshoots with it. I can see a similar behaviour with the Aixun tips but not so horrible.
                With the JBC tip on the thermometer I see the temp more or less stable but slowly dropping. At some point there is a 100% power spike and the registered temp goes +40C from where it was - obviously the display doesn't show anything!
                Is this "expected"?...
                09-12-2023, 10:19 AM
              • h0m3w0rk
                Repairing a Music Store Professional GO! SUB 18A
                by h0m3w0rk
                I'm working on repairing a Music Store Professional GO! SUB 18A bass subwoofer, and I need some help troubleshooting an issue with the power amplifier board. The board uses an IR2153 driver and originally had two SLW20N50C MOSFETs. Unfortunately, these MOSFETs burned out. I replaced them with two TK20J60W MOSFETs; however, these also failed almost immediately.
                Here are some details:
                • SLW20N50C (original):
                  • Rated for 500 V
                  • Typical RDS(ON): 0.21 Ω
                  • Continuous Drain Current: 20 A at 25°C (13 A at 100°C)
                  • Pulsed Drain Current: 80 A
                  • Avalanche
                02-27-2025, 07:42 AM
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
